Dear Sir,
it would help if you can confirm which controllers are active/compiled with FAST v7 Seismic module. Till now I have only used the .exe with bladed dll for my investigations.
I see that no yaw control is active. Is that how it should be?
Thanking You
Subham
Dear @Kashyap.Subham,
FAST v7 has similar controls capability as newer versions of OpenFAST including simple built-in options, user-defined routines, an interface to MATLAB/Simulink, and the Bladed-style DLL controller (DISCON). The Seismic version of FAST v7 should support all of this options, depending on the compile options you’ve set. If you are using the precompiled binary executable of the Seismic version of FAST v7 provided by NREL, this will support a Bladed-style DLL controller, but not the user-defined routines or MATLAB/Simulink interface.
NREL has not provided a baseline yaw controller except for what is provided in ROSCO: GitHub - NREL/ROSCO: A Reference Open Source Controller for Wind Turbines. You can also use the override yaw maneuvers controlled directly through the input file of FAST v7.
Bets regards,
Dear Sir,
If I understand correctly, should a DLL compiled with the ROCSO run similarly to the DLL with which the FAST v7 Seismic has been compiled?
In the FAST v7 Seismic Archive, I see a DFORRT.DLL and a DISCON.DLL.What is the difference between the two? In addition, I also see a DISCON.f90 which has the parameters with the Bladed style DLL.
Can you give me an overview of how these files are utilized/instead used? I am sorry for asking such broad questions. Is there any advantage to using a Bladed style DLL?
I also came across your paper on a floating wind turbine investigating the influence of control on the damping of pitch motion. You had incorporated different sensor measurements in the controller, such as tower motion. Can you share any files from that project that can serve me as study material, especially the control files?
Also, how can I generate damping ratios at different wind speeds using FAST v7 for a specific mode of the system? Something similar was done in your paper (as mentioned in 3).
Well, I believe it’s a lot of questions. Each day with FAST has been enriching. I am just learning by trial and error. I would appreciate your help.
Subham
Dear Sir,
I have highlighted the two ways mentioned for measuring thrust sensitivity using FAST. Method 1, I believe, is calculated by running a typical simulation with a uniform wind field while I keep the control systems (gen torq and blade-pitch switched on). Am I correct?
Method 2, I completely fail to understand. So, I set up a linearization study. Wherein I keep the blade pitch at the desired pitch angle and run the simulation? And the thrust sensitivity calculation using the central difference scheme. How is that implemented?
Is It possible to assess tower/aerodynamic damping ratios using the above methods for a bottom-fixed offshore wind turbine with seismic loads?
Subham
In Method 1, I agree that you run time-domain solutions with uniform wind input. Run separate simulations at each wind speed and record the steady-state response (of thrust) after all transients die out. Plot the curve of thrust versus wind speed and find the derivative of this curve.
In Method 2, the derivative is calculated directly by the linearization functionality of FAST v7. If you select rotor thrust as an output and include wind speed perturbations as input, then the derivative of the thrust with respect to wind speed is included in the linearized output-transmission (D) matrix. Again, OpenFAST computes this far better than FAST v7.
Tower/aerodynamic damping is a property of the full-system modes of the system, independent of the source of excitation.
