One elemetary question:
Does any one know how can I run FAST with constant (not turbulent) wind speed? For example 18m/s.
Do I must create a *.wnd file through TurbSim for constant wind speed like turbulent one? If yes how?
Dear Mehdi,
Please see the forum topic found here for an answer to a nearly identical question: Creating wind speed without turbulent.
Thanks Jason,
I used following hub height *.wnd file for running OC3Hywind by FAST:
! Steady wind file
! Time Wind Wind Vert. Horiz. Vert. LinV Gust
! Speed Dir Speed Shear Shear Shear Speed
0.0 30 0 -1 0.1 0.14 0 0
But FAST failed as below:
It seem the problem is due to DISCON.dll file.
What do you think about that problem? Your help is so appreciable.
regards,
The problem is not the controller. As discussed here: New versions of FAST, ADAMS2AD, AeroDyn, and NWTC Library).
