I’m currently evaluating the performance of different sized rotors under one sheared wind. The hub height of these rotors vary a lot, and wanted to asses them under one wind profile. I suspect when I set the wind shear exponent in the WT_Perf input file, the hub height is used as the reference height to model the atmospheric boundary layer, is this true? or is there a constant that is defined within the code? Could I have assess to make this reference height a constant?
I know this can be done using FAST as I could use a single wind file to perform the simulations, however I do not have the structural properties of these turbine.
I was wondering if there is a way to run AeroDyn without running FAST? or can I run FAST and gain the steady outputs from AeroDyn that are not influenced by FAST? i.e. I’m thinking of prescribing any false structural properties and turning off all the DOF for the simulations, is this the way to do it, in the FAST input file:
False YawDOF - Yaw DOF (flag)
Is this is sufficient for the FAST code to not influence the AeroDyn results, or is there other flags/quantities I should change?
Any help is greatly appreciated,
Thank you,
Kishore
