Compile FAST using CVF
I am a novice in using FAST and I am a bit stuck at the moment. The problem that I can´t compile FAST using compaq visual fortran. The compile_FAST.bat file that I am using is added below. I think my mistake is in the 14th line, starting with “SET COMPOPTS=/…”.
I would be grateful for any advice to guide me in the direction.
regards
Lene
@ECHO OFF
REM The calling syntax for this script is
REM Compile_FAST [dll]
REM
REM Add the “dll” to the command line to compile FAST for the Bladed-style dll.
REM ----------------------------------------------------------------------------
REM -------------------- LOCAL VARIABLES ---------------------------------------
SET ROOT_NAME=FAST
SET COMPOPTS=/threads /inline:speed /optimize:5 /traceback /real_size:32 /assume:byterecl /nostand
rem SET LINKOPTS=/link /stack:64000000
SET LINKOPTS=/link
REM ------------------------- LOCAL PATHS --------------------------------------
REM – USERS WILL NEED TO EDIT THESE PATHS TO POINT TO FOLDERS ON THEIR LOCAL –
REM ------- NOTE: do not use quotation marks around the path names!!! ---------
REM CVF_LOC is the location of the Compaq Visual Fortran files (DFVARS.bat and F90.exe).
REM AeroDyn_Loc is the location of the AeroDyn source files
REM Wind_Loc is the location of the AeroDyn wind inflow source files
REM FAST_LOC is the location of the FAST source files
REM NWTC_Lib_Loc is the location of the NWTC subroutine library files
SET IVF_LOC=C:\Program Files\Microsoft Visual Studio\DF98\BIN
SET NWTC_Lib_Loc=C:\NREL\NWTC\Source
SET AeroDyn_Loc=C:\NREL\AeroDyn\Source
SET Wind_Loc=C:\NREL\AeroDyn\Source\InflowWind\Source
SET FAST_Loc=C:\NREL\FAST\Source
SET IVF=“%IVF_LOC%\F90.EXE”
SET NWTC_Files=
SET NWTC_Files=%NWTC_Files% “%NWTC_Lib_Loc%\SingPrec.f90”
SET NWTC_Files=%NWTC_Files% “%NWTC_Lib_Loc%\SysCVF.f90”
SET NWTC_Files=%NWTC_Files% “%NWTC_Lib_Loc%\NWTC_IO.f90”
SET NWTC_Files=%NWTC_Files% “%NWTC_Lib_Loc%\NWTC_Num.f90”
SET NWTC_Files=%NWTC_Files% “%NWTC_Lib_Loc%\NWTC_Aero.f90”
SET NWTC_Files=%NWTC_Files% “%NWTC_Lib_Loc%\NWTC_Library.f90”
SET Wind_Files=
SET Wind_Files=%Wind_Files% “%Wind_Loc%\SharedInflowDefs.f90”
SET Wind_Files=%Wind_Files% “%Wind_Loc%\HHWind.f90”
SET Wind_Files=%Wind_Files% “%Wind_Loc%\FFWind.f90”
SET Wind_Files=%Wind_Files% “%Wind_Loc%\FDWind.f90”
SET Wind_Files=%Wind_Files% “%Wind_Loc%\CTWind.f90”
SET Wind_Files=%Wind_Files% “%Wind_Loc%\UserWind.f90”
SET Wind_Files=%Wind_Files% “%Wind_Loc%\InflowWindMod.f90”
SET AeroDyn_Files=
SET AeroDyn_Files=%AeroDyn_Files% “%AeroDyn_Loc%\SharedTypes.f90”
SET AeroDyn_Files=%AeroDyn_Files% “%AeroDyn_Loc%\AeroMods.f90”
SET AeroDyn_Files=%AeroDyn_Files% “%AeroDyn_Loc%\GenSubs.f90”
SET AeroDyn_Files=%AeroDyn_Files% “%AeroDyn_Loc%\AeroSubs.f90”
SET AeroDyn_Files=%AeroDyn_Files% “%AeroDyn_Loc%\AeroDyn.f90”
SET FAST_Files=
SET FAST_Files=%FAST_Files% “%FAST_LOC%\fftpack.f”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\FFTMod.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\HydroCalc.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\FAST_Mods.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\Noise.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\FAST_IO.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\FAST.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\FAST_Lin.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\FAST2ADAMS.f90”
IF /I “%1”==“DLL” GOTO dllFiles
SET FAST_Files=%FAST_Files% “%FAST_LOC%\PitchCntrl_ACH.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\UserSubs.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\UserVSCont_KP.f90”
GOTO endFASTfiles
:dllFiles
SET FAST_Files=%FAST_Files% “%FAST_LOC%\BladedDLLInterface.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\UserSubs_forBladedDLL.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\UserVSCont_KP_forBladedDLL.f90”
REM NOTE: UserSubs_forBladedDLL.f90 is a copy of UserSubs.f90 with SUBROUTINES UserHSSBr() and UserYawCont() commented out
REM UserVSCont_KP_forBladedDLL.f90 is a copy of UserVSCont_KP.f90 with SUBROUTINE UserVSCont() commented out
SET ROOT_NAME=%ROOT_NAME%_DLL
:endFASTfiles
SET FAST_Files=%FAST_Files% “%FAST_LOC%\AeroCalc.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\SetVersion.f90”
SET FAST_Files=%FAST_Files% “%FAST_LOC%\FAST_Prog.f90”
:ivf
REM ---------------- COMPILE WITH compaq VISUAL FORTRAN -------------------------
REM set compiler internal variables
IF “%INTEL_SHARED%”==“” CALL “%IVF_LOC%\DFVARS.BAT”
REM compile
ECHO.
ECHO Compiling FAST, AeroDyn, and NWTC_Library routines to create %ROOT_NAME%.exe:
%IVF% %COMPOPTS% %NWTC_Files% %Wind_Files% %AeroDyn_Files% %FAST_Files% %LINKOPTS% /out:%ROOT_NAME%.exe
:end
REM ------------------------- CLEAR MEMORY -------------------------------------
REM ------------- and delete all .mod and .obj files ---------------------------
ECHO a
DEL *.mod
DEL *.obj
SET IVF_LOC=
SET IVF=
SET ROOT_NAME=
SET COPTS=
SET NWTC_Files=
SET Wind_Files=
SET AeroDyn_Files=
SET FAST_Files=
SET A2AD_Files=
SET Fixed_Files=
SET NWTC_Lib_Loc=
SET Wind_Loc=
SET AeroDyn_Loc=
SET A2AD_Loc=
SET FAST_Loc=
SET COMPOPTS=
SET LINKOPTS=
Hi Lene,
Without any error message, it’s difficult to determine exactly what’s wrong, but these two lines of code caught my attention:
The CVF compiler should be DF.exe, not F90.exe, and %INTEL_SHARED% is an environment variable set by the IVF compiler.
I would change them to
SET IVF="%IVF_LOC%\DF.EXE" and
CALL "%IVF_LOC%\DFVARS.BAT"
An alternative (and perhaps easier) method for compiling is to create a new Fortran Console Application Project in CVF’s Developer Studio. The FAST User’s Guide has a chapter on compiling, which may be useful. The user’s guide hasn’t been updated since we’ve modified which files are required to compile it (e.g. you need the NWTC Subroutine Library), but hopefully you will be able to get the gist of it.
Thanks for the help. I chose to use create a new project in Developer Studio, and it ran smoothly :slight_smile:
regards
Lene
