Dear sir,
I am studying the coherence structure recently. By refering to the user manual about turbsim, I encountered the following questions:
- Does the spatial coherent structure module in turbsim make the wind speed of each point in the wind field consistent with the speed of the reference point (eliminate the difference between the two points? Phase difference)
- If I use the “IECKAI” wind spectrum, can I still consider the coherence structure?
- What is the relationship between the “Non-IEC Meteorological Boundary Conditions” module and the coherence structure?
- I need to use the coherence structure in turbsim Which parameters to adjust? After refering to the help manual about turbsim, I don’t understand “DistScl”, “CTLy”, and “CTLz” very well. Is it the relative position of the reference point?
- Can openfast3.0 perform coherence structure analysis?
There are many problems,thank you for your patience!
Best regard!
