Characteristic Curve Differences Between AeroDyn and Tidal Bladed
Hi everyone,
I’m having some difficulty getting the characteristic curves between AeroDyn and Tidal Bladed to match up. They have the same blades, polars, inputs and similar axial induction, tangential induction, AoA and Reynolds Number across the span, yet the characteristic curves aren’t even close. I know that AD and TB use different Tip and Hub loss models so I tried turning those off and they still don’t match up. Does anyone know what could be causing this discrepancy?
Conor
Dear @Conor.McCune,
The axial and tangential induction, angle of attack, and Re # are quite close in your plots, other than at the root and tip, which surprises me that the resulting Cp is so different.
In your first plot of Cp vs TSR for different RPMs, I see 4 labels, but 3 plots. Are the two AeroDyn results on top of each other? I would expect that, unless structural deflection is considered. Could that be the cause of the differences–i.e., that structural deflection is considered in your Tidal Bladed results, but not in your AeroDyn results? I.e., are you using the standalone driver for AeroDyn rather than AeroDyn within OpenFAST?
It would also be helpful to compare the normal and tangential force per unit length between the two solutions.
Hi @Jason.Jonkman,
Thanks for getting back to me so quickly. I was running AeroDyn with a standalone driver. I did have mass properties included for Tidal Bladed but blade flexibility disabled. I then ran a simulation in TB with both blade mass and flexibility disabled and still saw a discrepancy between 12 and 24 RPM.
I am using polars with multiple reynolds numbers but am not sure why AeroDyn doesn’t see a difference in Cp between different RPM but TB does?
Here’s what I found for the normal and tangential force relative to the chord.
I used Tidal Bladed’s Hydrodynamic Axes and took the negative of the y direction for tangential.
Thanks for the help,
Conor
Dear @Conor.McCune,
With the same airfoil data and a rigid rotor, I would expect the BEM solution to depend only on pitch and TSR, not on rotor speed. I’m not sure how much your airfoil data is changing between the different Reynold’s number to comment on what effect that may have.
Regarding the normal and tangential forces, the normal force from AeroDyn is definitely what I would expect to see–with a peak around 70% span. The tangential force is also what I expect, other the sign is backwards, but I guess this depends on what coordinate system you are using. The results from Tidal Bladed look odd to me, but perhaps you the Tidal Bladed output you are using is not the applied aerodynamic forces per unit length, but rather some reaction load in the blade. I would double check.
Morning @Jason.Jonkman,
I hope you had a nice weekend. It was a reactionary load, here is the correct normal and tangential force per unit length this time relative to the rotor plane.
Here is also a plot comparing the lift and drag coefficients for the three Reynolds numbers that Tidal Bladed is interpolating between.
This is for the final 3 stations of the blade closest to the tip which is about 15% of the blade length.
Conor
Dear @Conor.McCune,
Indeed, the Tidal Bladed results now make a lot more sense. The results appear to match AeroDyn up to about 3.2 m radius; beyond that, I’m not sure why the two codes are yielding different results. Are you using multiple Reynolds numbers in AeroDyn like you are in Tidal Bladed? Perhaps there is a problem in the blade definition (chord, twist, airfoil data) in AeroDyn beyond 3.2 m?
Hi @Jason.Jonkman ,
Thanks for the recommendation. I can’t believe I didn’t find it earlier but my AeroDyn file was only pulling the lowest of the Reynolds number polars.
Thanks for all your help,
Conor
