Hello everyone,
I want to get a information about tip and tower top mass. What is criteria to select and assign these values.
Thank you for your consideration.
Kaan Ciloglu
Aerospace Engineer
Hello everyone,
Kaan Ciloglu
Aerospace Engineer
Dear Kaan,
Are you referring to the use of BModes or something else? Please clarify.
Depar Jason,
I meant BModes input parameters that I mentioned
Best Regards
Dear Kaan,
Normally there is no lumped mass at the blade tip, so, the blade-tip mass, center of mass, and inertias can normally be set to zero in BModes. However, the tower-top mass, center of mass, and inertias normally have a strong impact on the tower mode shapes, so, normally these values should be set appropriately when deriving tower mode shapes from BModes.
If that doesn’t answer your question; please clarify.
Dear Jason
Thank you so much for your clarification. So what is the criteria assign the tower-top mass (Does it means nacelle mass?)
Kaan Ciloglu
Dear Kaan,
When deriving tower mode shapes from BModes, you should set the appropriate tower-top mass and inertia in BModes. By “tower-top”, I mean the rotor, drivetrain, and nacelle treated as a single rigid body.
Dear Jason
Thank you so much for your interest.
Kind regards
Kaan Ciloglu
Hi Jason,
and what about the mass and inertia of the blades? Should these also be included in the calculation of the tower-top mass properties? To be specific, should the blade mass be accounted into the tip_mass and the blade moment of inertia be accounted into ixx_tip, iyy_tip and so on?
Dear @Zong.Linyang,
When calculating the mode shapes of the tower in BModes, I agree that the blade mass, center of mass, and inertias should be included in the specification of the tip mass, center of mass, and inertias, along with the mass, center of mass, and inertias of the other tower-top components like the hub, drivetrain, and nacelle.
Hi @Jason.Jonkman,
I am working with BModes_JJ. I am studying the example “OC3Hywind.bmi”, where the NREL 5MW Tower is considered. I am stuck at the tower-top mass properties section, and I think this is a good thread on which to place my doubts.
The data in the example file looks like this:
3.500003109E+005 tip_mass blade-tip or tower-top mass (kg)
-0.4137754432 cm_loc tip-mass c.m. offset from the tower axis measured along x-tower axis (m)
1.9669893542 cm_axial tip-mass c.m. offset tower tip measures axially along the z axis (m)
4.370E7 ixx_tip blade lag mass moment of inertia about the tip-section x reference axis (kg-m^2)
2.353E7 iyy_tip blade flap mass moment of inertia about the tip-section y reference axis (kg-m^2)
2.542E7 izz_tip torsion mass moment of inertia about the tip-section z reference axis (kg-m^2)
0. ixy_tip cross product of inertia about x and y reference axes(kg-m^2)
1.169E6 izx_tip cross product of inertia about z and x reference axes(kg-m^2)
0. iyz_tip cross product of inertia about y and z reference axes(kg-m^2)
However, when I compute the values based on the parameters given in:
I obtain different results for the inertia matrix, computed with respect to the tip-mass c.m, as specified in https://forums.nrel.gov/t/tower-fore-aft-modes-shapes/193/7discussion. In particular, the ixx_tip is considerably off, and I also get a sign inversion for izx_tip.
3.50E+05 tip_mass blade-tip or tower-top mass (kg)
-0.4038582 cm_loc tip-mass c.m. offset from the tower axis measured along x-tower axis (m)
1.96612282 cm_axial tip-mass c.m. offset tower tip measures axially along the z axis (m)
3.528E+07 ixx_tip blade lag mass moment of inertia about the tip-section x reference axis (kg-m^2)
2.177E+07 iyy_tip blade flap mass moment of inertia about the tip-section y reference axis (kg-m^2)
2.447E+07 izz_tip torsion mass moment of inertia about the tip-section z reference axis (kg-m^2)
-1.157E+06 izx_tip cross product of inertia about z and x reference axes(kg-m^2)
In my computations, I:
The values that I use in my computation are displayed here:
-5.0191 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
-5 ShftTilt - Rotor shaft tilt angle (degrees)
56780 HubMass - Hub mass (kg)
2.60789E+06 NacYIner - Nacelle inertia about yaw axis (kg m^2)
0 YawBrMass - Yaw bearing mass (kg)
---------- Table 2-2. Undistributed Blade Structural Properties ---------------
0 BldCMx - Downwind distance from the root along preconed axis to the blade CM (meters)
0 BldCMy - Lateral distance from the root along preconed axis to the blade CM (meters)
20.475 BldCMz - Vertical distance from the root along preconed axis to the blade CM (meters)
17740 BldMass - Blade mass (kg)
11776047 BldRInerRt - Blade inertia for roll tilt rotation about the blade root (kg m^2)
11776047 BldPInerRt - Blade inertia for pitch tilt rotation about the blade root (kg m^2)
0 BldYInerRt - Blade inertia for yaw rotation about the blade root (kg m^2)
!Definition of a 5-MW Reference Wind Turbine for Offshore System Development
I believe that the main contributions to the ixx_tip inertia are given by the blades, and I don’t understand how it can be as high as 4.370E7 kg-m^2
I have a few questions.
Many thanks in advance!
Dear @Juan.LopezMuro,
Your process sounds reasonable to me, but I’m not sure where the issue may lie.
The following forum topics are likely of use to you:
The last in this list explains how to derive the 6x6 mass matrix of the RNA through an OpenFAST linearization analysis. I would suggest following this process to check your hand calculation.
Thank you very much @Jason.Jonkman for your response and all the links!
As you suggested, I followed the process to derive the 6x6 mass matrix of the RNA through an OpenFAST linearization analysis to check my hand calculation.
I ran 2 cases that I think should have given a similar result, but I found interesting differences when I compared them, and I’d like to share and ask about them.
The only difference between the two cases is that I changed the values of the switch CompElast from 1=ElastoDyn to 2=ElastoDyn + BeamDyn for blades in the .fst input file.
To give a little bit of context:
In the .fst file, I set: “ES10.3E2”=OutFmt, True=Linearize, True=CalcSteady, 2=LinInputs, 1=LinOutputs.
In the ElastoDyn file, I only enabled the six Platform degrees of freedom. and I chose the plaform outputs in the inertial frame: “PtfmTAxi”, “PtfmTAyi”, “PtfmTAzi”, “PtfmRAxi”, “PtfmRAyi”, “PtfmRAzi”.
In the ElastoDyn_Tower, I set the TMassDen to 0.1E-13 (kg/m).
The values that I computed from the results with 1=ElastoDyn are:
349390.900 tip_mass blade-tip or tower-top mass (kg)
-0.4052381 cm_loc tip-mass c.m. offset from the tower axis measured along x-tower axis (m)
1.98118111 cm_axial tip-mass c.m. offset tower tip measures axially along the z axis (m)
3.857E+07 ixx_tip blade lag mass moment of inertia about the tip-section x reference axis (kg-m^2)
2.344E+07 iyy_tip blade flap mass moment of inertia about the tip-section y reference axis (kg-m^2)
2.529E+07 izz_tip torsion mass moment of inertia about the tip-section z reference axis (kg-m^2)
-1.298E+06 izx_tip cross product of inertia about z and x reference axes(kg-m^2)
The Inertias now are closer but, on average, still 10% higher than the ones I computed “by hand”.
Q1: In my computations, I am considering that:
Is this correct?
Also, based on my results and after reading the Wikipedia section (and although I have never used Adams software before), I suspect that Adams uses a different convention for the products of inertia, where the minus sign is removed from the product of inertia formulas. That may explain the change in the sign of the izx_tip…?
The values that I computed from the results with 2=ElastoDyn + BeamDyn, are:
299978.467 tip_mass blade-tip or tower-top mass (kg)
0.51966755 cm_loc tip-mass c.m. offset from the tower axis measured along x-tower axis (m)
1.87977266 cm_axial tip-mass c.m. offset tower tip measures axially along the z axis (m)
1.555E+05 ixx_tip blade lag mass moment of inertia about the tip-section x reference axis (kg-m^2)
2.321E+06 iyy_tip blade flap mass moment of inertia about the tip-section y reference axis (kg-m^2)
4.039E+06 izz_tip torsion mass moment of inertia about the tip-section z reference axis (kg-m^2)
2.037E+05 izx_tip cross product of inertia about z and x reference axes(kg-m^2)
When I compare the mass results, the difference is three times 16470.811kg, almost the mass of 16844.752 kg reported in the .sum.yaml information file generated by BeamDyn.
The Inertia tensor reported in the .sum.yaml information file generated by BeamDyn is similar to that reported in Definition of a 5-MW . Still, a note mentions, “NOTE: from mass distribution only, missing some important inertial contributions (see PR#1337)”.
Q2: Is it possible that when BeamDyn is used in a Linearization, the mass and inertia of the blades are not appropriately evaluated or even not considered?
Thanks again!
Overall your approach sounds fine, except that normally I’d suggest including more precision in your output format when generating a linearized solution, such as OutFmt = “ES17.9E2”.
Here are my responses:
Hi @Jason.Jonkman,
I actually did not write my sentence right; I meant to say that in the .fst file, I set: “ES20.12E3”=OutFmt instead of “ES10.3E2”, as I saw in one of your suggestions in the forum since the latter gave me the wrong results. Thanks for that!
I agree that using OutFmt = “ES20.12E3” is more than enough precision.
