Blade numbering in YAWDYN
I already know that YawDyn is not the highest priority anymore :slight_smile:, but I am using it to make short and simple calculations.
I am trying to obtain the tilt moment making the vector sum of the Pitch moments and of the Out-Of-Plane moments for every blade of a 3-bladed small wind turbine.
I need to know the azimuth angles of the blades 1-2-3, and I would like to confirm the following: when blade 1 has azimuth angle “AzimAngB1D”, is the angle of blade 2:
“AzimAngB1D+120 deg” ?
and then of course that of blade 3:
“AzimAngB1D+240 deg” ?
I searched the user manual but could not find an answer.
Thanks a lot!
Claudio
Claudio,
I really have no idea what the azimuths of the various blades are. I think you can easily tell by looking at the time histories of the root edge bending moments. That’s probably easier than reading the code.
Marshall
