I am trying to find moments on the shaft that I expect the bearing will experience. a diagram below for reference:
I was planning on using the forces RtFldFyh and RtFldFzh to find these loads. Upon review I was looking into the effect of blade and hub mass on the force calculations. I had adjusted the AdjBlMs between 2 and 3.5 for a simple comparison.
I have two questions on how these loads are calculated:
- From what I understand
LSSTipand other shaft tip moments are calculated from forces at blade root, and hub radius as the moment arm, does this mean the forces does not include the weight of blades? - similarly for
RtFldFxh, is the weight of hub and blade not being considered in the rotor total force?
Thank you.
