Dear @Jason.Jonkman,
Sorry for opening a new task I’m workin on several things at the same time
i wanna ask you about the BEM implemented In AeroDyn using Ning method:
I obtained singularities at two positions:
at the tip, kappa equals infinity due to the fact that F (hub/tip loss correction) is equal to zero.
at the hub, where fhub<0 and therefore exp(-fhub)>0 and hence inverse cosine will be a complex number.
What do you think ? If i was right, what do you suggest in order to solve this problem ?
Riad
Dear @Riad.Elhamoud,
Actually, at the hub, r=R_hub, and so, f_hub = 0.
In the present version of AeroDyn, there is a special case defined at the hub and tip where the hub and tip loss are zero. That is, at the hub and tip where the hub and tip loss are zero, a=1 and a’=0.
Dear @Jason.Jonkman ,
I am sorry, i would say at the hub, f_hub = 0.
If i understand well, at the tip and the hub, we consider that a=1 and a’=0 which leads us to an indeterminate case of the residual function. We are sure that a solution exists in ]0:pi/2] but due to the fact that R(pi/2)>0 and R(0)<=0 and hence in this case, phi is taken equals to zero right ?
In case of Vx=0 or Vy=0, BEM makes no sense and hence a=0, a’=0 and phi=0 right ?
Riad
I fixed an error in my prior post. When a = 1 and a’ = 0, then phi is 0 or 180 deg based on the sign of Vy.
In addition to the special case where the hub and tip loss are zero at the hub and tip, resulting in a=1 and a’=0, there is another special case. This is the case where phi, Vx, or Vy are zero, in which case AeroDyn uses a=0 and a’=0.
