I have set up a simple OpenFAST simulation and got some strange output of the azimuthal angle.
I wanted to simulate a small wind turbine at a fixed rotational speed and I set:
- The total simulation time (TMax) equal to 10 rotor revolutions,
- The time step size (DT) equal to 0.1 degree,
- The output time step size (DT_Out) equal to 1.0 degree,
- And the starting time for the output (TStart) equal to 9 rotor revolutions.
Using this setup with a constant wind speed I get only zeros as azimuth values:
Time Wind1VelX RotSpeed RtTSR B1Azimuth
(s) (m/s) (rpm) (-) (deg)
8.0304 5.000E+00 6.725E+01 5.007E+00 -0.000E+00
8.0328 5.000E+00 6.725E+01 5.007E+00 -0.000E+00
8.0352 5.000E+00 6.725E+01 5.007E+00 -0.000E+00
8.0376 5.000E+00 6.725E+01 5.007E+00 -0.000E+00
8.0400 5.000E+00 6.725E+01 5.007E+00 -0.000E+00
8.0424 5.000E+00 6.725E+01 5.007E+00 -0.000E+00
With a turbulent inflow, generated by TurbSim, I get the following values:
8.0304 7.541E+00 6.725E+01 3.697E+00 -1.348E+02
8.0328 7.552E+00 6.725E+01 3.692E+00 -1.381E+02
8.0352 7.563E+00 6.725E+01 3.687E+00 -1.415E+02
8.0376 7.574E+00 6.725E+01 3.681E+00 -1.422E+02
8.0400 7.585E+00 6.725E+01 3.677E+00 -1.391E+02
8.0424 7.596E+00 6.725E+01 3.673E+00 -1.332E+02
8.0448 7.607E+00 6.725E+01 3.669E+00 -1.241E+02
8.0472 7.618E+00 6.725E+01 3.664E+00 -1.102E+02
Both results are not what I expected. Does anybody has an idea what could be wrong with my setup or is there a bug in OpenFAST?
Matthias
