I got a problem in simulating the parked turbine. I used Test13(WP 1.5 MW). I disabled all DOFs and I also set NacYaw=0,Azimuth=270,BlPitch(1)、(2)、(3)=90. I set WindType=1(steady),HWindSpeed=30. After running,drag force(RtAeroFzh)=-81900N,lift force(RtAeroFxh)=244.9N.
I also estimated the mean wind load on blades with Matlab. The drag force and lift force on each blade element per unit length is calculated as FD=0.5ρ(U^2)CD; FL=0.5ρ(U^2)CL. In this way,drag force is about -81091N(agree well with OpenFast),lift force is about -8663N.
I checked CD and CL in OpenFast and MATLAB,they agree well. I don’t know why the lift force differs so greatly.But I think the lift force from OPenFast seems too little. Do you think the result from OpenFast credible?
Sincerely
