I am trying to collect some aerodynamic outputs to plot. I am running the 5MW wind turbine NREL model in FAST with AeroDyn. In reading the AeroDyn manual, the description of the output (.opt) file is completely different from what I’m getting. The manual describes a file with a header and then columns of data corresponding to those in Table 10.1. I have selected USE_CM. Here is what my .opt file looks like after running the simulation:
This file was generated by AeroDyn (v13.00.00a-bjj, 31-Mar-2010) on 08-Apr-2011 at 11:01:52.
Inputs read in from the AeroDyn input file:
NREL 5.0 MW offshore baseline aerodynamic input properties; Compatible with AeroDyn v12.58.
SI Units for input and output
BEDDOES Dynamic stall model [Beddoes]
USE_CM Aerodynamic pitching moment model [Pitching Moments calculated]
EQUIL Inflow model [Equilibrium]
SWIRL Induction factor model [Normal and Radial flow induction factors calculated]
5.00000E-03 Convergence tolerance for induction factor
PRAND Tip-loss model [Prandtl model]
PRAND Hub-loss model [Prandtl model]
“12mps.wnd” Wind file name
90 Wind reference (hub) height, m
0 Tower shadow centerline velocity deficit
9999.9 Tower shadow half width, m
9999.9 Tower shadow reference point, m
1.225 Air density, kg/m^3
1.46400E-05 Kinematic air viscosity, m^2/sec
2.47900E-02 Time interval for aerodynamic calculations, sec
8 Number of airfoil files used. Files listed below:
“AeroData\Cylinder1.dat”
“AeroData\Cylinder2.dat”
“AeroData\DU40_A17.dat”
“AeroData\DU35_A17.dat”
“AeroData\DU30_A17.dat”
“AeroData\DU25_A17.dat”
“AeroData\DU21_A17.dat”
“AeroData\NACA64_A17.dat”
17 Number of blade elements per blade
Element RELM Twist DR Chord NFoil Print? Tip-loss Hub-loss
(-) (m) (deg) (m) (m) (-) (Yes/No) constant constant
1 2.86670 13.30800 2.73330 3.54200 1 No 31.46474 1.36670
2 5.60000 13.30800 2.73330 3.85400 1 No 15.37500 4.10000
3 8.33330 13.30800 2.73330 4.16700 2 No 9.84005 6.83330
4 11.75000 13.30800 4.10000 4.55700 3 No 6.54255 10.25000
5 15.85000 11.48000 4.10000 4.65200 4 No 4.46215 14.35000
6 19.95000 10.16200 4.10000 4.45800 4 No 3.23684 18.45000
7 24.05000 9.01100 4.10000 4.24900 5 No 2.42931 22.55000
8 28.15000 7.79500 4.10000 4.00700 6 No 1.85702 26.65000
9 32.25000 6.54400 4.10000 3.74800 6 No 1.43023 30.75000
10 36.35000 5.36100 4.10000 3.50200 7 No 1.09973 34.85000
11 40.45000 4.18800 4.10000 3.25600 7 No 0.83622 38.95000
12 44.55000 3.12500 4.10000 3.01000 8 No 0.62121 43.05000
13 48.65000 2.31900 4.10000 2.76400 8 No 0.44245 47.15000
14 52.75000 1.52600 4.10000 2.51800 8 No 0.29147 51.25000
15 56.16670 0.86300 2.73330 2.31300 8 No 0.18249 54.66670
16 58.90000 0.37000 2.73330 2.08600 8 No 0.10441 57.40000
17 61.63330 0.10600 2.73330 1.41900 8 No 0.03326 60.13330
Rotor radius = 62.940 m
Hub radius = 1.499 m
Number of blades = 3
BEDDOES DYNAMIC STALL PARAMETERS:
CN SLOPE 0.0000 0.0000 7.4888 7.1838 7.3326 6.4462 6.2047 6.0031
STALL CN (UPPER) 0.0000 0.0000 1.3519 1.6717 1.4490 1.4336 1.4144 1.4073
STALL CN (LOWER) 0.0000 0.0000 -0.3226 -0.3075 -0.6138 -0.6873 -0.5324 -0.7945
ZERO LIFT AOA 0.0000 0.0000 -1.3430 -1.8330 -2.3220 -4.2422 -5.0609 -4.4320
MIN DRAG AOA 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 -1.5000 -1.0000
MIN DRAG COEFF 0.5000 0.3500 0.0113 0.0094 0.0087 0.0065 0.0057 0.0052
VORTEX TRANSIT TIME FROM LE TO TE 11.00000
PRESSURE TIME CONSTANT 1.700000
VORTEX TIME CONSTANT 6.000000
F-PARAMETER TIME CONSTANT 3.000000
Am I doing something wrong?
