I am going to start working on simulation of a horizontal small wind turbine (3 kw). I have read several papers about the interface between ADAMS and AeroDyn using ADAMS2AD.
I use to work with ADAMS. The version we have is ADAMS 2005 r2. I read something about ADAMS WT. Is this module compatible with my ADAMS? In this case, how could I get this module?
Thank you,
Alex Estevez
FATRONIK-TECNALIA
Dear Alex,
The old ADAMS/WT files can be found here: wind.nrel.gov/designcodes/preprocessors/adamswt/.
That said, NREL no longer supports ADAMS/WT; we have not updated the ADAMS/WT files (e.g., for new versions of ADAMS or AeroDyn) for quite a well and we cannot answer questions on it. (e.g, ADAMS/WT is compatible with a ADAMS 10).
Instead, we have replaced the functionality of ADAMS/WT with an MSC.ADAMS preprocessor that is now built into the FAST code—see: wind.nrel.gov/designcodes/simula … t/FAST.pdf.
Dear Jason:
DO you have adams 2008 r1?
Dear Vahid,
ADAMS 2008R1 was the last version of ADAMS that I had, but I don’t have any license anymore.
