Hi everybody,
It would be appreciated if anybody let me know whether the aerodynamic data of a 900 kw wind turbine blades(lift, drag coefficients,…) is available by NREL or not, and how I can access them.
Best Regards
Sara Salehyar
Hi everybody,
Best Regards
Sara Salehyar
Dear Sara,
We don’t have any example turbine models (in WT_Perf or FAST) of a 900-kW turbine. That said, airfoil data (lift, drag coefficients) need not be customized to a specific turbine power rating. So, perhaps the airfoil data we do include in our sample models (with WT_Perf or FAST) would be useful to you?
Thanks for your reply. The blade length of the 900kw wind turbine I want to model is 25m. In the FAST samples, test11 wind turbine has a blade length of 35m. I think using the aerodynamic data of the airfoils of this turbine, and eliminating some blade elements to reach 25m length can be helpful.
Best Regards
Sara
