Dear @Hussam.Al.Halabi,
This section of the ElastoDyn input file defines initial conditions of the structural model. It does not define controller parameters such as max generator speed. As I said, you should set RotSpeed
and BlPitch
to their expected (mean) values for each simulation, based on the mean hub-height wind speed. At 13 m/s, these should be RotSpeed
= 12.1 and BlPitch
= 6.6deg. See Figure 9-1 of the NREL 5-MW baseline wind turbine specifications report for the values at other wind speeds; the numerical values shown in this Figure are provided in the following forum topic: NREL 5-MW reference turbine.
