Has any one tried to simulate a 2 bladed down wind turbine using FAST ? I am tying to evaluate the difficulties in modeling such a turbine using various solvers.
regards
Satish
regards
Satish
Dear Satish,
In FAST it is quite straightforward to set up a model for a 2-bladed downwind rotor. In fact, the FAST Certification Test includes two examples with downwind 2-bladed rotors – tests 01-05 are for the AWT-27CR2 and test 09 is for the UAE Phase VI downwind configuration.
Are there any reports or any other materials existing for detail specifications of the two 2-bladed wind turbines you mentioned above: the AWT-27CR2 and the UAE Phase VI.
If any, could you attach a link for downloading them? Thanks a lot.
Yingyi Liu
Dear Yingyi Liu,
The AWT-27CR2 model is very old and I was not one who originally assembled the associated FAST model. I don’t know if there is a publicly available report documenting it. I would ask the person who originally made that model, but he has now retired.
The UAE Phase VI turbine is well documented in the following report (particularly Appendix A): nrel.gov/docs/fy02osti/29955.pdf.
Thanks so much for your information about UAE Phase VI turbine.
As for AWT-27CR2, I found the following page for AWT-27 through Google: en.wind-turbine-models.com/turbi … nc.-awt-27
However, it seems that the above turbine AWT-27 is not exactly the one packaged by the FAST CertTest examples, although they are very similar (both 2-bladed).
Yingyi Liu
