10kW wind turbine power curve
I have plotted power-rotor speed for 10 kW wind turbine under 8m/s, 9 m/s, 10 m/s and 11.5 m/s wind speeds. The rated wind speed for this turbine is 11.5 m/s in which the power should reach maximum 10kW but in the figure it is less than 10 kW. Generator efficiency and gearbox efficiency is 100%.
The power is obtained through RtAeroPwr in Aerodyn.
Please let me know what could be the problem?
Babak
Dear Babak,
When you say:
are you referring to a report, measured data, or simulation results?
Are you confident that the turbine is being modeled in a way that would give the power curve you are expecting?
