Dear Sir
In my simulation of Wind Pack wind turbine model I have recounted a problem where an image of matlab error is given below:
Can you please help to fix the causes of the problem:
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 3, Blade = 1
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 4, Blade = 1
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 5, Blade = 1
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 6, Blade = 1
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 7, Blade = 1
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 8, Blade = 1
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 9, Blade = 1
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 10, Blade = 1
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 11, Blade = 1
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 12, Blade = 1
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 13, Blade = 1
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 14, Blade = 1
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 15, Blade = 1
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 16, Blade = 1
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 17, Blade = 1
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 3, Blade = 2
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 4, Blade = 2
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 5, Blade = 2
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 6, Blade = 2
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 7, Blade = 2
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 8, Blade = 2
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 9, Blade = 2
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 10, Blade = 2
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 11, Blade = 2
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 12, Blade = 2
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 13, Blade = 2
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 14, Blade = 2
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 15, Blade = 2
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 16, Blade = 2
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 17, Blade = 2
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 3, Blade = 3
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 4, Blade = 3
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 5, Blade = 3
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 6, Blade = 3
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 7, Blade = 3
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 8, Blade = 3
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 9, Blade = 3
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 10, Blade = 3
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 11, Blade = 3
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 12, Blade = 3
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 13, Blade = 3
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 14, Blade = 3
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 15, Blade = 3
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 16, Blade = 3
Warning: Turning off Unsteady Aerodynamics due to high angle-of-attack. BladeNode = 17, Blade = 3
FAST completed.
