WindCrete (Corewind project) version update. Openfast 2.1.0 to 3.5.4 to 4.2.0
For my master thesis, I’m researching multiple floaters for the IEA 15 MW turbine.
To be able to compare the different floaters more easily, I’m converting all my floaters to the latest version of OpenFAST.
When I update the version of the WindCrete floater (Home - COREWIND), I run in to a numerical stability issue of the code.
In the figures below, I have plotted the simulation results of a single input for different version of openfast: 2.1.0, 3.5.4 and 4.2.0.
This simulation shows the output for a windspeed of 8 m/s, Hs = 3.0 m, Tp = 8s, regular waves.
En zoomed in:
However, the simulation behaves as normal before the crash. For example, the nacelle movement is almost identical:
For all simulations, I use the same inputs, such as the controller or hydrodynamic inputs. To rule out any problems in the modules, I ran the simulation without Hydrodyn and Moordyn and the platform DOF turned off. For a windspeed of 8 m/s, the results for the power are as follows:
To rule out the moordyn file, I used the same file in version 3.5.4 (which worked correctly). I now think the problem lies in the Hydrodyn/Seastate file or in the coupling between all modules. The files are attached below.
I was hoping someone could help with solving this issue.
Thanks in advance!
Hydrodyn file Openfast 2.1.0:
IEA 15 MW WindCrete Gran Canaria COREWIND, Climent Molins (Climent.Molins@upc.edu), Pau Trubat (Pau.Trubat.Casal@upc.edu). M.Youssef Mahfouz (mahfouz@IFB.Uni-Stuttgart.de)
False Echo - Echo the input file data (flag)
200 WtrDpth - Water depth (meters)
0 MSL2SWL - Offset between still-water level and mean sea level (meters) [positive upward; unused when WaveMod = 6; must be zero if PotMod=1 or 2]
2 WaveMod - Incident wave kinematics model {0: none=still water, 1: regular (periodic), 1P#: regular with user-specified phase, 2: JONSWAP/Pierson-Moskowitz spectrum (irregular), 3: White noise spectrum (irregular), 4: user-defined spectrum from routine UserWaveSpctrm (irregular), 5: Externally generated wave-elevation time series, 6: Externally generated full wave-kinematics time series [option 6 is invalid for PotMod/=0]} (switch)
10000 WaveTMax - Analysis time for incident wave calculations (sec) [unused when WaveMod=0; determines WaveDOmega=2Pi/WaveTMax in the IFFT]
0.0125 WaveDT - Time step for incident wave calculations (sec) [unused when WaveMod=0; 0.1<=WaveDT<=1.0 recommended; determines WaveOmegaMax=Pi/WaveDT in the IFFT]
2 WaveHs - Significant wave height of incident waves (meters) [used only when WaveMod=1, 2, or 3]
10 WaveTp - Peak-spectral period of incident waves (sec) [used only when WaveMod=1 or 2]
“DEFAULT” WavePkShp - Peak-shape parameter of incident wave spectrum (-) or DEFAULT (string) [used only when WaveMod=2; use 1.0 for Pierson-Moskowitz]
0.15708 WvLowCOff - Low cut-off frequency or lower frequency limit of the wave spectrum beyond which the wave spectrum is zeroed (rad/s) [unused when WaveMod=0, 1, or 6]
3.2 WvHiCOff - High cut-off frequency or upper frequency limit of the wave spectrum beyond which the wave spectrum is zeroed (rad/s) [unused when WaveMod=0, 1, or 6]
0 WaveDir - Incident wave propagation heading direction (degrees) [unused when WaveMod=0 or 6]
0 WaveDirMod - Directional spreading function {0: none, 1: COS2S} (-) [only used when WaveMod=2,3, or 4]
1 WaveDirSpread - Wave direction spreading coefficient ( > 0 ) (-) [only used when WaveMod=2,3, or 4 and WaveDirMod=1]
1 WaveNDir - Number of wave directions (-) [only used when WaveMod=2,3, or 4 and WaveDirMod=1; odd number only]
90 WaveDirRange - Range of wave directions (full range: WaveDir +/- 1/2*WaveDirRange) (degrees) [only used when WaveMod=2,3,or 4 and WaveDirMod=1]
123456789 WaveSeed(1) - First random seed of incident waves [-2147483648 to 2147483647] (-) [unused when WaveMod=0, 5, or 6]
1011121314 WaveSeed(2) - Second random seed of incident waves [-2147483648 to 2147483647] (-) [unused when WaveMod=0, 5, or 6]
False WaveNDAmp - Flag for normally distributed amplitudes (flag) [only used when WaveMod=2, 3, or 4]
“” WvKinFile - Root name of externally generated wave data file(s) (quoted string) [used only when WaveMod=5 or 6]
1 NWaveElev - Number of points where the incident wave elevations can be computed (-) [maximum of 9 output locations]
0 WaveElevxi - List of xi-coordinates for points where the incident wave elevations can be output (meters) [NWaveElev points, separated by commas or white space; usused if NWaveElev = 0]
0 WaveElevyi - List of yi-coordinates for points where the incident wave elevations can be output (meters) [NWaveElev points, separated by commas or white space; usused if NWaveElev = 0]
False WvDiffQTF - Full difference-frequency 2nd-order wave kinematics (flag)
False WvSumQTF - Full summation-frequency 2nd-order wave kinematics (flag)
0.1 WvLowCOffD - Low frequency cutoff used in the difference-frequencies (rad/s) [Only used with a difference-frequency method]
2.5 WvHiCOffD - High frequency cutoff used in the difference-frequencies (rad/s) [Only used with a difference-frequency method]
0.314159 WvLowCOffS - Low frequency cutoff used in the summation-frequencies (rad/s) [Only used with a summation-frequency method]
3.2 WvHiCOffS - High frequency cutoff used in the summation-frequencies (rad/s) [Only used with a summation-frequency method]
0 CurrMod - Current profile model {0: none=no current, 1: standard, 2: user-defined from routine UserCurrent} (switch)
0 CurrSSV0 - Sub-surface current velocity at still water level (m/s) [used only when CurrMod=1]
“DEFAULT” CurrSSDir - Sub-surface current heading direction (degrees) or DEFAULT (string) [used only when CurrMod=1]
20 CurrNSRef - Near-surface current reference depth (meters) [used only when CurrMod=1]
0 CurrNSV0 - Near-surface current velocity at still water level (m/s) [used only when CurrMod=1]
0 CurrNSDir - Near-surface current heading direction (degrees) [used only when CurrMod=1]
0 CurrDIV - Depth-independent current velocity (m/s) [used only when CurrMod=1]
0 CurrDIDir - Depth-independent current heading direction (degrees) [used only when CurrMod=1]
1 PotMod - Potential-flow model {0: none=no potential flow, 1: frequency-to-time-domain transforms based on WAMIT output, 2: fluid-impulse theory (FIT)} (switch)
“HydroData\windcrete15MW” PotFile - Root name of potential-flow model data; WAMIT output files containing the linear, nondimensionalized, hydrostatic restoring matrix (.hst), frequency-dependent hydrodynamic added mass matrix and damping matrix (.1), and frequency- and direction-dependent wave excitation force vector per unit wave amplitude (.3) (quoted string) [MAKE SURE THE FREQUENCIES INHERENT IN THESE WAMIT FILES SPAN THE PHYSICALLY-SIGNIFICANT RANGE OF FREQUENCIES FOR THE GIVEN PLATFORM; THEY MUST CONTAIN THE ZERO- AND INFINITE-FREQUENCY LIMITS!]
1 WAMITULEN - Characteristic body length scale used to redimensionalize WAMIT output (meters) [only used when PotMod=1]
4.054e+04 PtfmVol0 - Displaced volume of water when the platform is in its undisplaced position (m^3) [only used when PotMod=1; USE THE SAME VALUE COMPUTED BY WAMIT AS OUTPUT IN THE .OUT FILE!]
0 PtfmCOBxt - The xt offset of the center of buoyancy (COB) from the platform reference point (meters) [only used when PotMod=1]
0 PtfmCOByt - The yt offset of the center of buoyancy (COB) from the platform reference point (meters) [only used when PotMod=1]
1 RdtnMod - Radiation memory-effect model {0: no memory-effect calculation, 1: convolution, 2: state-space} (switch) [only used when PotMod=1; STATE-SPACE REQUIRES *.ss INPUT FILE]
60 RdtnTMax - Analysis time for wave radiation kernel calculations (sec) [only used when PotMod=1; determines RdtnDOmega=Pi/RdtnTMax in the cosine transform; MAKE SURE THIS IS LONG ENOUGH FOR THE RADIATION IMPULSE RESPONSE FUNCTIONS TO DECAY TO NEAR-ZERO FOR THE GIVEN PLATFORM!]
“default” RdtnDT - Time step for wave radiation kernel calculations (sec) [only used when PotMod=1; DT<=RdtnDT<=0.1 recommended; determines RdtnOmegaMax=Pi/RdtnDT in the cosine transform]
0 MnDrift - Mean-drift 2nd-order forces computed {0: None; [7, 8, 9, 10, 11, or 12]: WAMIT file to use} [Only one of MnDrift, NewmanApp, or DiffQTF can be non-zero]
0 NewmanApp - Mean- and slow-drift 2nd-order forces computed with Newman’s approximation {0: None; [7, 8, 9, 10, 11, or 12]: WAMIT file to use} [Only one of MnDrift, NewmanApp, or DiffQTF can be non-zero. Used only when WaveDirMod=0]
0 DiffQTF - Full difference-frequency 2nd-order forces computed with full QTF {0: None; [10, 11, or 12]: WAMIT file to use} [Only one of MnDrift, NewmanApp, or DiffQTF can be non-zero]
0 SumQTF - Full summation -frequency 2nd-order forces computed with full QTF {0: None; [10, 11, or 12]: WAMIT file to use}
---------------------- FLOATING PLATFORM FORCE FLAGS -------------------------- [unused with WaveMod=6]
True PtfmSgF - Platform horizontal surge translation force (flag) or DEFAULT
True PtfmSwF - Platform horizontal sway translation force (flag) or DEFAULT
True PtfmHvF - Platform vertical heave translation force (flag) or DEFAULT
True PtfmRF - Platform roll tilt rotation force (flag) or DEFAULT
True PtfmPF - Platform pitch tilt rotation force (flag) or DEFAULT
True PtfmYF - Platform yaw rotation force (flag) or DEFAULT
---------------------- PLATFORM ADDITIONAL STIFFNESS AND DAMPING --------------
0 0 0 0 0 0 AddF0 - Additional preload (N, N-m)
0 0 0 0 0 0 AddCLin - Additional linear stiffness (N/m, N/rad, N-m/m, N-m/rad)
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0 AddBLin - Additional linear damping(N/(m/s), N/(rad/s), N-m/(m/s), N-m/(rad/s))
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0 AddBQuad - Additional quadratic drag(N/(m/s)^2, N/(rad/s)^2, N-m(m/s)^2, N-m/(rad/s)^2)
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
2 NAxCoef - Number of axial coefficients (-)
AxCoefID AxCd AxCa AxCp
1 0.00 0.00 1.00
2 0.20 0.00 1.00
5 NJoints - Number of joints (-) [must be exactly 0 or at least 2]
JointID Jointxi Jointyi Jointzi JointAxID JointOvrlp [JointOvrlp= 0: do nothing at joint, 1: eliminate overlaps by calculating super member]
(-) (m) (m) (m) (-) (switch)
1 0.00000 0.00000 -155.00000 2 0
2 0.00000 0.00000 -145.7000 1 0
3 0.00000 0.00000 -10.00000 1 0
4 0.00000 0.00000 0.00000 1 0
5 0.00000 0.00000 15.00000 1 0
4 NPropSets - Number of member property sets (-)
PropSetID PropD PropThck
(-) (m) (m)
1 15.1868 0.5000
2 18.60 0.5000
3 13.2 0.5000
4 12.42 0.4000
---------------------- SIMPLE HYDRODYNAMIC COEFFICIENTS (model 1) --------------
SimplCd SimplCdMG SimplCa SimplCaMG SimplCp SimplCpMG SimplAxCa SimplAxCaMG SimplAxCp SimplAxCpMG
0.70 0.00 1.00 0.00 1.00 0.00 0.00 0.00 0.00 0.00
---------------------- DEPTH-BASED HYDRODYNAMIC COEFFICIENTS (model 2) ---------
0 NCoefDpth - Number of depth-dependent coefficients (-)
Dpth DpthCd DpthCdMG DpthCa DpthCaMG DpthCp DpthCpMG DpthAxCa DpthAxCaMG DpthAxCp DpthAxCpMG
(m) (-) (-) (-) (-) (-) (-) (-) (-) (-) (-)
---------------------- MEMBER-BASED HYDRODYNAMIC COEFFICIENTS (model 3) --------
4 NCoefMembers - Number of member-based coefficients (-)
MemberID MemberCd1 MemberCd2 MemberCdMG1 MemberCdMG2 MemberCa1 MemberCa2 MemberCaMG1 MemberCaMG2 MemberCp1 MemberCp2 MemberCpMG1 MemberCpMG2 MemberAxCa1 MemberAxCa2 MemberAxCaMG1 MemberAxCaMG2 MemberAxCp1 MemberAxCp2 MemberAxCpMG1 MemberAxCpMG2
1 0.7 0.7 0.00 0.00 1.0 1.0 0.00 0.00 1.00 1.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
2 0.7 0.7 0.00 0.00 1.0 1.0 0.00 0.00 1.00 1.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
3 0.7 0.7 0.00 0.00 1.0 1.0 0.00 0.00 1.00 1.00 0.00 0.00 1.00 1.00 0.00 0.00 0.00 0.00 0.00 0.00
4 0.7 0.7 0.00 0.00 1.0 1.0 0.00 0.00 1.00 1.00 0.00 0.00 1.00 1.00 0.00 0.00 0.00 0.00 0.00 0.00
4 NMembers - Number of members (-)
MemberID MJointID1 MJointID2 MPropSetID1 MPropSetID2 MDivSize MCoefMod PropPot [MCoefMod=1: use simple coeff table, 2: use depth-based coeff table, 3: use member-based coeff table] [ PropPot/=0 if member is modeled with potential-flow theory]
(-) (-) (-) (-) (-) (m) (switch) (flag)
1 1 2 1 1 0.5000 3 True
2 2 3 2 2 0.5000 3 True
3 3 4 2 3 0.5000 3 True
4 4 5 3 4 0.5000 3 True
0 NFillGroups - Number of filled member groups (-) [If FillDens = DEFAULT, then FillDens = WtrDens; FillFSLoc is related to MSL2SWL]
FillNumM FillMList FillFSLoc FillDens
(-) (-) (m) (kg/m^3)
---------------------- MARINE GROWTH -------------------------------------------
0 NMGDepths - Number of marine-growth depths specified (-)
MGDpth MGThck MGDens
(m) (m) (kg/m^3)
---------------------- MEMBER OUTPUT LIST --------------------------------------
0 NMOutputs - Number of member outputs (-) [must be < 10]
MemberID NOutLoc NodeLocs [NOutLoc < 10; node locations are normalized distance from the start of the member, and must be >=0 and <= 1] [unused if NMOutputs=0]
---------------------- JOINT OUTPUT LIST ---------------------------------------
0 NJOutputs - Number of joint outputs [Must be < 10]
0 JOutLst - List of JointIDs which are to be output (-)[unused if NJOutputs=0]
True HDSum - Output a summary file [flag]
False OutAll - Output all user-specified member and joint loads (only at each member end, not interior locations) [flag]
2 OutSwtch - Output requested channels to: [1=Hydrodyn.out, 2=GlueCode.out, 3=both files]
“ES11.4e2” OutFmt - Output format for numerical results (quoted string) [not checked for validity!]
“A11” OutSFmt - Output format for header strings (quoted string) [not checked for validity!]
---------------------- OUTPUT CHANNELS -----------------------------------------
“Wave1Elev” - Wave elevation at the WAMIT reference point (0,0)
END of output channels and end of file. (the word “END” must appear in the first 3 columns of this line)
Hydrodyn openfast 4.2.0:
------- HydroDyn v2.05.* Input File --------------------------------------------
1 ExctnMod - Wave-excitation model {0: no wave-excitation calculation, 1: DFT, 2: state-space} (switch) [only used when PotMod=1; STATE-SPACE REQUIRES .ssexctn INPUT FILE]
0 ExctnDisp - Method of computing Wave Excitation {0: use undisplaced position, 1: use displaced position, 2: use low-pass filtered displaced position) [only used when PotMod=1 and ExctnMod>0 and SeaState’s WaveMod>0]} (switch)
10 ExctnCutOff - Cutoff (corner) frequency of the low-pass time-filtered displaced position (Hz) [>0.0] [used only when PotMod=1, ExctnMod>0, and ExctnDisp=2]) [only used when PotMod=1 and ExctnMod>0 and SeaState’s WaveMod>0]} (switch)
0 PtfmYMod - Model for large platform yaw offset {0: Static reference yaw offset based on PtfmRefY, 1: dynamic reference yaw offset based on low-pass filtering the PRP yaw motion with cutoff frequency PtfmYCutOff} (switch)
0 PtfmRefY - Constant (if PtfmYMod=0) or initial (if PtfmYMod=1) platform reference yaw offset (deg)
0.01 PtfmYCutOff - Cutoff frequency for the low-pass filtering of PRP yaw motion when PtfmYMod=1 [unused when PtfmYMod=0] (Hz)
36 NExctnHdg - Number of evenly distributed platform yaw/heading angles over the range of [-180, 180) deg for which the wave excitation shall be computed [only used when PtfmYMod=1] (-)
1 RdtnMod - Radiation memory-effect model {0: no memory-effect calculation, 1: convolution, 2: state-space} (switch) [only used when PotMod=1; STATE-SPACE REQUIRES .ss INPUT FILE]
60 RdtnTMax - Analysis time for wave radiation kernel calculations (sec) [only used when PotMod=1 and RdtnMod>0; determines RdtnDOmega=Pi/RdtnTMax in the cosine transform; MAKE SURE THIS IS LONG ENOUGH FOR THE RADIATION IMPULSE RESPONSE FUNCTIONS TO DECAY TO NEAR-ZERO FOR THE GIVEN PLATFORM!]
“DEFAULT” RdtnDT - Time step for wave radiation kernel calculations (sec) [only used when PotMod=1; DT<=RdtnDT<=0.1 recommended; determines RdtnOmegaMax=Pi/RdtnDT in the cosine transform]
1 NBody - Number of WAMIT bodies to be used (-) [>=1; only used when PotMod=1. If NBodyMod=1, the WAMIT data contains a vector of size 6
NBody x 1 and matrices of size 6NBody x 6NBody; if NBodyMod>1, there are NBody sets of WAMIT data each with a vector of size 6 x 1 and matrices of size 6 x 6]
1 NBodyMod - Body coupling model {1: include coupling terms between each body and NBody in HydroDyn equals NBODY in WAMIT, 2: neglect coupling terms between each body and NBODY=1 with XBODY=0 in WAMIT, 3: Neglect coupling terms between each body and NBODY=1 with XBODY=/0 in WAMIT} (switch) [only used when PotMod=1]
“HydroData/windcrete15MW” PotFile - Root name of potential-flow model data; WAMIT output files containing the linear, nondimensionalized, hydrostatic restoring matrix (.hst), frequency-dependent hydrodynamic added mass matrix and damping matrix (.1), and frequency- and direction-dependent wave excitation force vector per unit wave amplitude (.3) (quoted string) [MAKE SURE THE FREQUENCIES INHERENT IN THESE WAMIT FILES SPAN THE PHYSICALLY-SIGNIFICANT RANGE OF FREQUENCIES FOR THE GIVEN PLATFORM; THEY MUST CONTAIN THE ZERO- AND INFINITE-FREQUENCY LIMITS!]
0 PtfmRefxt - The xt offset of the body reference point(s) from (0,0,0) (meters) [1 to NBody] [only used when PotMod=1]
0 PtfmRefyt - The yt offset of the body reference point(s) from (0,0,0) (meters) [1 to NBody] [only used when PotMod=1]
0 PtfmRefzt - The zt offset of the body reference point(s) from (0,0,0) (meters) [1 to NBody] [only used when PotMod=1. If NBodyMod=2,PtfmRefzt=0.0]
0 PtfmRefztRot - The rotation about zt of the body reference frame(s) from xt/yt (degrees) [1 to NBody] [only used when PotMod=1]
0.0 AddF0 - Additional preload (N, N-m) [If NBodyMod=1, one size 6
NBody x 1 vector; if NBodyMod>1, NBody size 6 x 1 vectors]
0.0
0.0
0.0
0.0
0.0
0 0 0 0 0 0 AddCLin - Additional linear stiffness (N/m, N/rad, N-m/m, N-m/rad) [If NBodyMod=1, one size 6NBody x 6NBody matrix; if NBodyMod>1, NBody size 6 x 6 matrices]
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
---------------------- STRIP THEORY OPTIONS --------------------------------------
0 WaveDisp - Method of computing Wave Kinematics {0: use undisplaced position, 1: use displaced position) } (switch)
0 AMMod - Method of computing distributed added-mass force. (0: Only and always on nodes below SWL at the undisplaced position. 2: Up to the instantaneous free surface) [overwrite to 0 when WaveMod = 0 or 6 or when WaveStMod = 0 in SeaState]
1 0.00 0.00 1.00
2 0.20 0.00 1.00
1 0 0 -155 2 0 !center column top
2 0 0 -145.7 1 0 !centercolumn end of taper
3 0 0 -10 1 0 !1st side column bottom
4 0 0 0 1 0 !1st side column top
5 0 0 15 1 0 !2nd side column bottom
---------------------- CYLINDRICAL MEMBER CROSS-SECTION PROPERTIES -------------------------
4 NPropSetsCyl - Number of member property sets (-)
(-) (m) (m)
1 15.1868 0.5000
2 18.60 0.5000
3 13.2 0.5000
4 12.42 0.4000
---------------------- RECTANGULAR MEMBER CROSS-SECTION PROPERTIES -------------------------
0 NPropSetsRec - Number of member property sets (-)
(-) (m) (m)
---------------------- SIMPLE CYLINDRICAL-MEMBER HYDRODYNAMIC COEFFICIENTS (model 1) --------------
SimplCd SimplCdMG SimplCa SimplCaMG SimplCp SimplCpMG SimplAxCd SimplAxCdMG SimplAxCa SimplAxCaMG SimplAxCp SimplAxCpMG SimplCb SimplCbMG
0.70 0.00 1.00 0.00 1.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
---------------------- SIMPLE RECTANGULAR-MEMBER HYDRODYNAMIC COEFFICIENTS (model 1) --------------
SimplCdA SimplCdAMG SimplCdB SimplCdBMG SimplCaA SimplCaAMG SimplCaB SimplCaBMG SimplCp SimplCpMG SimplAxCd SimplAxCdMG SimplAxCa SimplAxCaMG SimplAxCp SimplAxCpMG SimplCb SimplCbMG
0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
---------------------- DEPTH-BASED CYLINDRICAL-MEMBER HYDRODYNAMIC COEFFICIENTS (model 2) ---------
0 NCoefDpthCyl - Number of depth-dependent cylindrical member coefficients (-)
Dpth DpthCd DpthCdMG DpthCa DpthCaMG DpthCp DpthCpMG DpthAxCd DpthAxCdMG DpthAxCa DpthAxCaMG DpthAxCp DpthAxCpMG DpthCb DpthCbMG
(m) (-) (-) (-) (-) (-) (-) (-) (-) (-) (-) (-) (-) (-) (-)
---------------------- DEPTH-BASED RECTANGULAR-MEMBER HYDRODYNAMIC COEFFICIENTS (model 2) ---------
0 NCoefDpthRec - Number of depth-dependent rectangular member coefficients (-)
Dpth DpthCdA DpthCdAMG DpthCdB DpthCdBMG DpthCaA DpthCaAMG DpthCaB DpthCaBMG DpthCp DpthCpMG DpthAxCd DpthAxCdMG DpthAxCa DpthAxCaMG DpthAxCp DpthAxCpMG DpthCb DpthCbMG
(m) (-) (-) (-) (-) (-) (-) (-) (-) (-) (-) (-) (-) (-) (-) (-) (-) (-) (-)
---------------------- MEMBER-BASED CYLINDRICAL-MEMBER HYDRODYNAMIC COEFFICIENTS (model 3) --------
4 NCoefMembersCyl - Number of member-based cylindrical member coefficients (-)
MemberID MemberCd1 MemberCd2 MemberCdMG1 MemberCdMG2 MemberCa1 MemberCa2 MemberCaMG1 MemberCaMG2 MemberCp1 MemberCp2 MemberCpMG1 MemberCpMG2 MemberAxCd1 MemberAxCd2 MemberAxCdMG1 MemberAxCdMG2 MemberAxCa1 MemberAxCa2 MemberAxCaMG1 MemberAxCaMG2 MemberAxCp1 MemberAxCp2 MemberAxCpMG1 MemberAxCpMG2 MemberCb1 MemberCb2 MemberCbMG1 MemberCbMG2
1 0.7 0.7 0.00 0.00 1.00 1.00 0.00 0.00 1.00 1.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
2 0.7 0.7 0.00 0.00 1.00 1.00 0.00 0.00 1.00 1.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
3 0.7 0.7 0.00 0.00 1.00 1.00 0.00 0.00 1.00 1.00 0.00 0.00 0.00 0.00 0.00 0.00 1.00 1.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
4 0.7 0.7 0.00 0.00 1.00 1.00 0.00 0.00 1.00 1.00 0.00 0.00 0.00 0.00 0.00 0.00 1.00 1.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
----------------------- MEMBER-BASED RECTANGULAR-MEMBER HYDRODYNAMIC COEFFICIENTS (model 3) --------
0 NCoefMembersRec - Number of member-based rectangular member coefficients (-)
MemberID MemberCdA1 MemberCdA2 MemberCdAMG1 MemberCdAMG2 MemberCdB1 MemberCdB2 MemberCdBMG1 MemberCdBMG2 MemberCaA1 MemberCaA2 MemberCaAMG1 MemberCaAMG2 MemberCaB1 MemberCaB2 MemberCaBMG1 MemberCaBMG2 MemberCp1 MemberCp2 MemberCpMG1 MemberCpMG2 MemberAxCd1 MemberAxCd2 MemberAxCdMG1 MemberAxCdMG2 MemberAxCa1 MemberAxCa2 MemberAxCaMG1 MemberAxCaMG2 MemberAxCp1 MemberAxCp2 MemberAxCpMG1 MemberAxCpMG2 MemberCb1 MemberCb2 MemberCbMG1 MemberCbMG2
MemberID MJointID1 MJointID2 MPropSetID1 MPropSetID2 MSecGeom MSpinOrient MDivSize MCoefMod MHstLMod PropPot [MCoefMod=1: use simple coeff table, 2: use depth-based coeff table, 3: use member-based coeff table] [ PropPot/=0 if member is modeled with potential-flow theory]
(-) (-) (-) (-) (-) (switch) (deg) (m) (switch) (switch) (flag)
1 1 2 1 1 1 0 0.5 3 1 TRUE
2 2 3 2 2 1 0 0.5 3 1 TRUE
3 3 4 2 3 1 0 0.5 3 1 TRUE
4 4 5 3 4 1 0 0.5 3 1 TRUE
(m) (m) (kg/m^3)
“B1WvsFxi”
“B1WvsFyi”
“B1WvsFzi”
“B1WvsMxi”
“B1WvsMyi”
“B1WvsMzi”
“B1WvsF1xi”
“B1WvsF1yi”
“B1WvsF1zi”
“B1WvsM1xi”
“B1WvsM1yi”
“B1WvsM1zi”
“B1WvsF2xi”
“B1WvsF2yi”
“B1WvsF2zi”
“B1WvsM2xi”
“B1WvsM2yi”
“B1WvsM2zi”
Seastate Openfast 4.2.0:
------- SeaState Input File ----------------------------------------------------
NREL 5.0 MW offshore baseline floating platform HydroDyn input properties for the OC4 Semi-submersible.
“default” WtrDens - Water density (kg/m^3)
“default” WtrDpth - Water depth (meters) relative to MSL
“default” MSL2SWL - Offset between still-water level and mean sea level (meters) [positive upward; unused when WaveMod = 6; must be zero if PotMod=1 or 2]
---------------------- SPATIAL DISCRETIZATION ---------------------------------------------------
60 X_HalfWidth – Half-width of the domain in the X direction (m) [>0, NOTE: X[nX] = nXdX, where nX = {-NX+1,-NX+2,…,NX-1} and dX = X_HalfWidth/(NX-1)]
60 Y_HalfWidth – Half-width of the domain in the Y direction (m) [>0, NOTE: Y[nY] = nY
dY, where nY = {-NY+1,-NY+2,…,NY-1} and dY = Y_HalfWidth/(NY-1)]
30 Z_Depth – Depth of the domain the Z direction (m) relative to SWL [0 < Z_Depth <= WtrDpth+MSL2SWL; “default”: Z_Depth = WtrDpth+MSL2SWL; Z[nZ] = ( COS( nZdthetaZ ) – 1 )Z_Depth, where nZ = {0,1,…NZ-1} and dthetaZ = pi/( 2(NZ-1) )]
6 NX – Number of nodes in half of the X-direction domain (-) [>=2]
6 NY – Number of nodes in half of the Y-direction domain (-) [>=2]
20 NZ – Number of nodes in the Z direction (-) [>=2]
2 WaveMod - Incident wave kinematics model {0: none=still water, 1: regular (periodic), 1P#: regular with user-specified phase, 2: JONSWAP/Pierson-Moskowitz spectrum (irregular), 3: White noise spectrum (irregular), 4: user-defined spectrum from routine UserWaveSpctrm (irregular), 5: Externally generated wave-elevation time series, 6: Externally generated full wave-kinematics time series, 7: wave frequency components [option 6 is invalid for PotMod/=0]} (switch)
0.0125 WaveDT - Time step for incident wave calculations (sec) [unused when WaveMod=0 or 7; 0.1<=WaveDT<=1.0 recommended; determines WaveOmegaMax=Pi/WaveDT in the IFFT]
0.15708 WvLowCOff - Low cut-off frequency or lower frequency limit of the wave spectrum beyond which the wave spectrum is zeroed (rad/s) [unused when WaveMod=0, 1, 6, or 7]
3.2 WvHiCOff - High cut-off frequency or upper frequency limit of the wave spectrum beyond which the wave spectrum is zeroed (rad/s) [unused when WaveMod=0, 1, 6, or 7]
0 WaveDir - Incident wave propagation heading direction (degrees) [unused when WaveMod=0, 6 or 7]
0 WaveDirRange - Range of wave directions (full range: WaveDir +/- 1/2WaveDirRange) (degrees) [only used when WaveMod=2,3,or 4 and WaveDirMod=1]
1011121314 WaveSeed(2) - Second random seed of incident waves [-2147483648 to 2147483647] for intrinsic pRNG, or an alternative pRNG: “RanLux” (-) [unused when WaveMod=0, 5, or 6]
FALSE WaveNDAmp - Flag for normally distributed amplitudes (flag) [only used when WaveMod=2, 3, or 4]
“” WvKinFile - Root name of externally generated wave data file(s) (quoted string) [used only when WaveMod=5, 6 or 7]
---------------------- CONSTRAINED WAVES ---------------------------------------
0 ConstWaveMod - Constrained wave model: 0=none; 1=Constrained wave with specified crest elevation, alpha; 2=Constrained wave with guaranteed peak-to-trough crest height, HCrest (flag)
1 CrestHmax - Crest height (2*alpha for ConstWaveMod=1 or HCrest for ConstWaveMod=2), must be larger than WaveHs (m) [unused when ConstWaveMod=0]
60 CrestTime - Time at which the crest appears (s) [unused when ConstWaveMod=0]
0 CrestXi - X-position of the crest (m) [unused when ConstWaveMod=0]
0 CrestYi - Y-position of the crest (m) [unused when ConstWaveMod=0]
---------------------- MacCamy-Fuchs diffraction model -------------------------
0 MCFD - MacCamy-Fuchs member radius (ignored if radius <= 0) [must be 0 when WaveMod 0 or 6]
False SeaStSum - Output a summary file [flag]
2 OutSwtch - Output requested channels to: [1=SeaState.out, 2=GlueCode.out, 3=both files]
2 NWaveKin - Number of points where the wave kinematics can be output (-) [maximum of 9 output locations]
14.43376, -18.4752 WaveKinxi - List of xi-coordinates for points where the wave kinematics can be output (meters) [NWaveKin points, separated by commas or white space; usused if NWaveKin = 0]
25, -6 WaveKinyi - List of yi-coordinates for points where the wave kinematics can be output (meters) [NWaveKin points, separated by commas or white space; usused if NWaveKin = 0]
-14, -17 WaveKinzi - List of zi-coordinates for points where the wave kinematics can be output (meters) [NWaveKin points, separated by commas or white space; usused if NWaveKin = 0]
“Wave1Elev” - Wave elevation at the platform reference point (0, 0)
Dear @Ole.Grootes,
I’m not sure yet, but it looks like generator power has suffering a numerical instability, starting at around 85.5 s into the simulation. Are you seeing similar response in the generator speed and generator torque? I would first check if reducing the time step or adding a correction step resolves the issue.
Dear @Jason.Jonkman,
Thank you for your reply. I have looked into your suggestion and down belowed are the detailed answers.
The generator speed is suffering the same instability, but the generator torque has no problem. First an overview of the entire run:
And zoomed in:
Currently, I’m running the simulation with a timestep of 0.0125 s. The generator power switches sign every time step.
Before, I tested with a timestep of 0.005 s:
For now I also tested with a timestep of 0.001 s:
Unfortunately, this behaviour continues to occur with smaller time steps.
Setting the NumCrtn =1 and DT_UJac = 4 (1/10*0.02411) makes the simulation work as expected:
The formula for DT_UJac comes from the Openfast documentation and the natural pitch frequency has been taken from the WindCrete paper.
Some extra information on the numerical instability:
From the github issue forum, I got a version 4.1.2. of the WindCrete floater. When setting the NumCrtn = 0, the same error occurs. For this version, setting NumCrtn =1, solves the problems.
Dear @Ole.Grootes,
I’m glad to hear the problem is now solved.
Can you clarify whether your model has BeamDyn and/or SubDyn enabled, which are typically the reasons why NumCrctn > 0 must be set?
Dear @Jason.Jonkman ,
Both BeamDyn and SubDyn are turned off in all setups in version 2.1.0, 3.5.4 and 4.2.0.
I have uploaded a picture of the .fst file of version 4.2.0 below:
Ole
Dear @Ole.Grootes,
OK, interesting. Can you clarify what aerodynamic options you are using in AeroDyn? Perhaps one of these options is necessitating NumCrctn > 0.
FYI: The release of OpenFAST v5.0 with the new tight coupling algorithm is coming very soon. I’m hoping the updates we’ve made to the algorithm will eliminate the need for the correction step you’ve added. It will be great if you can upgrade and confirm that, once released.
When Openfast v5 is released, I will test if the NumCrctn > 0 is still required. Keep you posted!
I have included screenshot of my Aerodyn input file:
Ole
Dear @Ole.Grootes,
Does using DBEMT_Mod = 0 and/or UA_Mod = 0 allow you to simulate without a correction step?
I have tried all combinations (DBEMT_Mod = 0 & UA_Mod = 0, BEMT_Mod = 0 & UA_Mod = 3, DBEMT_Mod = 2 & UA_Mod = 0, DBEMT_Mod = 2 & UA_Mod = 3) for a moving platform for 4 different cases:
For all combinations Case 0 and 2 are stable, but Case 1 and 3 unstable.
Before I posted the question on the forum, I tried the combinations above with a fixed platform (all DOF = False, MoorDyn = 0, HydroDyn = 0). For the fixed platform, all simulations were stable without a correction step.
Ole
