I have been doing some FAST V8 simulations for a SWT based on the SWRT CertTest data and I have encountered some behaviour that I am sure you could send me help about. The turbine is a 3 bladed, with twisted,tapperded 3.22 m long blades, and I have used the tail geometry of the SWRT furl file in order to keep the rotor orientated to the wind.I have run 3 different simulations:
- EOG with hub height horizontal wind velocity of 13 m/s.
- EDC with hub height horizontal wind velocity of 13 m/s (constant).
- Steady wind with horizontal wind velocity of 13 m/s (no direction change).
My concern is about the NacYawPos channel of FAST outputs (see attached figures). - I would expect the nacelle position angle to remain more or less around 0 degrees of NacYawPos for the EOG simulation, as the incoming wind direction is 0 in ths case. I understand that due to aerodynamic inbalances inherent to a twisted blade the average value of the nacelle position will be different from zero, but the oscillations seen in the figure EOG.png seem excesive for me (up to 50 degrees!).
- For the EDC, a oscillation between -20 and 20 degrees is seen before starting the transient, then it follows more or less correctly the wind direction imposed by the incoming wind. When the transitient ends, the nacelle starts to oscillate around the position where it ended.
- Finally, from the steady 13 m/s wind the first oscillation of the EDC case (before starting the transitient) is seen. Then, the amplitude of this oscillation decreases and it ends with a yaw position of about 16 degrees, which I understand that is the angle that the nacelle rotates due to aerodynamic inbalances at 13 m/s.
To sum up, I would expect the turbine to keep aligneate to the wind more tightly as I understand the tail makes in a real wind turbine. Maybe I am wrong and under EOGs such oscillations are normal due to aerodynamic imbalances. I also notice that I have set by default YawSpr and YawDamp to zero, what makes a no friction, perfect hinge. If the key are these two parameters, do you know some orientative values, or a method to determinate them in order to obtain a quite accurate modelling of what a SWT with tail orientation and free-yaw (like the NREL SWRT) in reality does.
Thank you very much in advance. I really appreciate your help as I am in the last part of my bachellor thesis.
PS: If you need more information, I could show you the FAST input files used for the simulations.
Alvaro Olcoz
