Dear Dr. Jonkman,
Thank you for your reply.
I’m sorry the cited article is indeed incorrect. I cited https://www.osti.gov/servlets/purl/1371521).(Example1)
I changed the British units in the stiffness matrix to the SI. In the first post, I used one element and the lambda was 0.5 and 1.0.
The initial_twist setting was to test its impact on results. I’ve also tested the case where the initial_twist is 0, which doesn’t change the result. I’ve attached my case and results for your reference.
case
------- BEAMDYN V1.00.00 Driver INPUT FILE -------------------------------------
Static analysis of NREL 5MW blade under distributed force
0 t_initial - Starting time of simulation (s)
30.0 t_final - Ending time of simulation (s)
0.002 dt - Time increment size (s)
---------------------- GRAVITY PARAMETER --------------------------------------
0.0 Gx - Component of gravity vector along X direction (m/s^2)
0.0 Gy - Component of gravity vector along Y direction (m/s^2)
0.0 Gz - Component of gravity vector along Z direction (m/s^2)
---------------------- FRAME PARAMETER --------------------------------------
0.0 GlbPos(1) - Component of position vector of the reference blade frame along X direction (m)
0.0 GlbPos(2) - Component of position vector of the reference blade frame along Y direction (m)
0.0 GlbPos(3) - Component of position vector of the reference blade frame along Z direction (m)
---The following 3 by 3 matrix is the direction cosine matirx ,GlbDCM(3,3),
---relates global frame to reference blade frame
1.000E+00 0.000E+00 0.000E+00
0.000E+00 1.000E+00 0.000E+00
0.000E+00 0.000E+00 1.000E+00
---------------------- ROOT VELOCITY PARAMETER ----------------------------------
0.0 RootVel(4) - Component of angular velocity vector of the beam root about X axis (rad/s)
0.0 RootVel(5) - Component of angular velocity vector of the beam root about Y axis (rad/s)
0.0 RootVel(6) - Component of angular velocity vector of the beam root about Z axis (rad/s)
---------------------- APPLIED FORCE ----------------------------------
0.0 DistrLoad(1) - Component of distributed force vector along X direction (N/m)
0.0 DistrLoad(2) - Component of distributed force vector along Y direction (N/m)
0.0 DistrLoad(3) - Component of distributed force vector along Z direction (N/m)
0.0 DistrLoad(4) - Component of distributed moment vector along X direction (N-m/m)
0.0 DistrLoad(5) - Component of distributed moment vector along Y direction (N-m/m)
0.0 DistrLoad(6) - Component of distributed moment vector along Z direction (N-m/m)
0.0 TipLoad(1) - Component of concentrated force vector at blade tip along X direction (N)
0.0 TipLoad(2) - Component of concentrated force vector at blade tip along Y direction (N)
0.0 TipLoad(3) - Component of concentrated force vector at blade tip along Z direction (N)
3084.5196 TipLoad(4) - Component of concentrated moment vector at blade tip along X direction (N-m)
0.0 TipLoad(5) - Component of concentrated moment vector at blade tip along Y direction (N-m)
0.0 TipLoad(6) - Component of concentrated moment vector at blade tip along Z direction (N-m)
---------------------- PRIMARY INPUT FILE --------------------------------------
"bd_primary.inp" InputFile - Name of the primary input file
--------- BEAMDYN V1.01.* INPUT FILE -------------------------------------------
NREL 5MW blade primary input file
True Echo - Echo input data to "<RootName>.ech" (flag)
1 analysis_type - 1: Static analysis; 2: Dynamic analysis (switch)
0.0 rhoinf - Numerical Damping Parameter for Generalized-alpha integrator
1 quadrature - 1: Gauss; 2: Trapezoidal (switch)
DEFAULT refine - Refinement factor for quadrature 2 (-). DEFAULT = 1
DEFAULT n_fact - Factorization frequency (-). DEFAULT = 5
DEFAULT DTBeam - Time step size (s).
DEFAULT NRMax - Max number of iterations in Newton-Ralphson algorithm (-). DEFAULT = 10
DEFAULT stop_tol - Tolerance for stopping criterion (-)
---------------------- GEOMETRY PARAMETER --------------------------------------
2 member_total - Total number of members (-)
11 kp_total - Total number of key points (-)
1 6 - Member number; Number of key points in this member
2 6
kp_xr kp_yr kp_zr initial_twist
(m) (m) (m) (deg)
0.000000 0.000000 0.000000 0.000000
0.000000 0.000000 0.025400 0.000000
0.000000 0.000000 0.050800 0.000000
0.000000 0.000000 0.076200 0.000000
0.000000 0.000000 0.101600 0.000000
0.000000 0.000000 0.127000 0.000000
0.000000 0.000000 0.152400 0.000000
0.000000 0.000000 0.177800 0.000000
0.000000 0.000000 0.203200 0.000000
0.000000 0.000000 0.228600 0.000000
0.000000 0.000000 0.254000 0.000000
---------------------- MESH PARAMETER ------------------------------------------
5 order_elem - Order of interpolation (basis) function (-)
---------------------- MATERIAL PARAMETER --------------------------------------
"beam_props.inp" BldFile - Name of file containing properties for blade (quoted string)
---------------------- PITCH ACTUATOR PARAMETERS -------------------------------
False UsePitchAct - Whether a pitch actuator should be used (flag)
200 PitchJ - Pitch actuator inertia (kg-m^2) [used only when UsePitchAct is true]
2.0E+7 PitchK - Pitch actuator stiffness (kg-m^2/s^2) [used only when UsePitchAct is true]
5.0E+5 PitchC - Pitch actuator damping (kg-m^2/s) [used only when UsePitchAct is true]
---------------------- OUTPUTS -------------------------------------------------
True SumPrint - Print summary data to "<RootName>.sum" (flag)
"ES10.3E2" OutFmt - Format used for text tabular output, excluding the time channel.
5 NNodeOuts - Number of nodes to output to file [0 - 9] (-)
6,7,8,9,10 OutNd - Nodes whose values will be output (-)
OutList - The next line(s) contains a list of output parameters. See OutListParameters.xlsx.
"N1TDxr,N1TDyr,N1TDzr,N1RDxr,N1RDxr,N1RDxr"
"N2TDxr,N2TDyr,N2TDzr,N2RDxr,N2RDxr,N2RDxr"
"N3TDxr,N3TDyr,N3TDzr,N3RDxr,N3RDxr,N3RDxr"
"N4TDxr,N4TDyr,N4TDzr,N4RDxr,N4RDxr,N4RDxr"
"N5TDxr,N5TDyr,N5TDzr,N5RDxr,N5RDxr,N5RDxr"
"TipTDxr, TipTDyr, TipTDzr"
"TipRDxr, TipRDyr, TipRDzr"
------- BEAMDYN V1.00.* INDIVIDUAL BLADE INPUT FILE --------------------------
NREL5MW Blade
---------------------- BLADE PARAMETERS --------------------------------------
3 station_total - Number of blade input stations (-)
0 damp_type - Damping type (switch): 0: no damping; 1: viscous damping
---------------------- DAMPING COEFFICIENT------------------------------------
mu1 mu2 mu3 mu4 mu5 mu6
(s) (s) (s) (s) (s) (s)
1.0E-03 1.0E-03 1.0E-03 1.0E-03 1.0E-03 1.0E-03
---------------------- DISTRIBUTED PROPERTIES---------------------------------
0.00
7.873300E+06 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 7.873300E+06 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 7.873300E+06 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 2.493856E+02 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 6.170070E+02 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 2.341760E+01
1.975000E+01 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 1.975000E+01 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 1.975000E+01 0.000000E+00 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 6.583333E+00 0.000000E+00 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 6.583333E+00 0.000000E+00
0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00 1.316667E+01
0.50
1.00
I still used lambda equals 1.0 as I can conveniently plot the theoretical solution.
I think there’s still a strange curvature at the last node of the first element, which is causing the same issue at the first node of the second element.
result
I would be extremely grateful if you could offer some guidance and suggestions.
