I’m posting the inputs below. They were originally written for OpenFAST 2.1 so I had to add/remove some variables for compatibility with 2.4. Also, a non-functional libdiscon.so was provided with the model, so I’m using the one from the IEA Wind 15 MW from Github.
— ServoDyn
------- SERVODYN v1.05.* INPUT FILE --------------------------------------------
IEA 15 MW WindCrete Gran Canaria COREWIND, Climent Molins (Climent.Molins@upc.edu), Pau Trubat (Pau.Trubat.Casal@upc.edu). M.Youssef Mahfouz (mahfouz@IFB.Uni-Stuttgart.de)
False Echo - Echo input data to <RootName>.ech (flag)
"default" DT - Communication interval for controllers (s) (or "default")
5 PCMode - Pitch control mode {0: none, 3: user-defined from routine PitchCntrl, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
2.0 PitManRat(1) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 1 (deg/s)
2.0 PitManRat(2) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 2 (deg/s)
2.0 PitManRat(3) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 3 (deg/s) [unused for 2 blades]
0.0 BlPitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
0.0 BlPitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
0.0 BlPitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
5 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 3: user-defined from routine UserVSCont, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
96.55 GenEff - Generator efficiency [ignored by the Thevenin and user-defined generator models] (%)
0.0 YawNeut - Neutral yaw position--yaw spring force is zero at this yaw (degrees)
4.6273E+10 YawSpr - Nacelle-yaw spring constant (N-m/rad)
3.9088E+07 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
2.0 YawManRat - Yaw maneuver rate (in absolute value) (deg/s)
---------------------- TUNED MASS DAMPER ---------------------------------------
False CompNTMD - Compute nacelle tuned mass damper {true/false} (flag)
"unused" NTMDfile - Name of the file for nacelle tuned mass damper (quoted string) [unused when CompNTMD is false]
False CompTTMD - Compute tower tuned mass damper {true/false} (flag)
"unused" TTMDfile - Name of the file for tower tuned mass damper (quoted string) [unused when CompTTMD is false]
"/home/ramaral/T_IEA-15-240-RWT/OpenFAST/WindcreteSPAR/DataServo/libdiscon_IEA15Github.so" DLL_FileName - Name/location of the dynamic library {.dll [Windows] or .so [Linux]} in the Bladed-DLL format (-) [used only with Bladed Interface]
"/home/ramaral/T_IEA-15-240-RWT/OpenFAST/WindcreteSPAR/DataServo/DISCON.IN" DLL_InFile - Name of input file sent to the DLL (-) [used only with Bladed Interface]
"DISCON" DLL_ProcName - Name of procedure in DLL to be called (-) [case sensitive; used only with DLL Interface]
"default" DLL_DT - Communication interval for dynamic library (s) (or "default") [used only with Bladed Interface]
True DLL_Ramp - Whether a linear ramp should be used between DLL_DT time steps [introduces time shift when true] (flag) [used only with Bladed Interface]
9999.9 BPCutoff - Cuttoff frequency for low-pass filter on blade pitch from DLL (Hz) [used only with Bladed Interface]
0.0 NacYaw_North - Reference yaw angle of the nacelle when the upwind end points due North (deg) [used only with Bladed Interface]
0.0 Ptch_SetPnt - Record 5: Below-rated pitch angle set-point (deg) [used only with Bladed Interface]
0.0 Ptch_Min - Record 6: Minimum pitch angle (deg) [used only with Bladed Interface]
0.0 Ptch_Max - Record 7: Maximum pitch angle (deg) [used only with Bladed Interface]
0.0 PtchRate_Min - Record 8: Minimum pitch rate (most negative value allowed) (deg/s) [used only with Bladed Interface]
0.0 PtchRate_Max - Record 9: Maximum pitch rate (deg/s) [used only with Bladed Interface]
0.0 Gain_OM - Record 16: Optimal mode gain (Nm/(rad/s)^2) [used only with Bladed Interface]
0.0 GenSpd_MinOM - Record 17: Minimum generator speed (rpm) [used only with Bladed Interface]
0.0 GenSpd_MaxOM - Record 18: Optimal mode maximum speed (rpm) [used only with Bladed Interface]
0.0 GenSpd_Dem - Record 19: Demanded generator speed above rated (rpm) [used only with Bladed Interface]
0.0 GenTrq_Dem - Record 22: Demanded generator torque above rated (Nm) [used only with Bladed Interface]
0.0 GenPwr_Dem - Record 13: Demanded power (W) [used only with Bladed Interface]
GenSpd_TLU GenTrq_TLU
(rpm) (Nm)
False SumPrint - Print summary data to <RootName>.sum (flag) (currently unused)
"ES10.3E2" OutFmt - Format used for text tabular output (except time). Resulting field should be 10 characters. (quoted string) (currently unused)
30.0 TStart - Time to begin tabular output (s) (currently unused)
"GenPwr"
"GenTq"
— ROSCO
[code]! Controller parameter input file for the IEA-15-240-RWT wind turbine
! - File written using ROSCO Controller tuning logic on 01/26/20
!------- DEBUG ------------------------------------------------------------
0 ! LoggingLevel - {0: write no debug files, 1: write standard output .dbg-file, 2: write standard output .dbg-file and complete avrSWAP-array .dbg2-file}
!------- CONTROLLER FLAGS -------------------------------------------------
2 ! F_LPFType - {1: first-order low-pass filter, 2: second-order low-pass filter}, [rad/s] (currently filters generator speed and pitch control signals
0 ! F_NotchType - Notch on the measured generator speed and/or tower fore-aft motion (for floating) {0: disable, 1: generator speed, 2: tower-top fore-aft motion, 3: generator speed and tower-top fore-aft motion}
0 ! IPC_ControlMode - Turn Individual Pitch Control (IPC) for fatigue load reductions (pitch contribution) {0: off, 1: 1P reductions, 2: 1P+2P reductions}
0 ! VS_ControlMode - Generator torque control mode in above rated conditions {0: constant torque, 1: constant power, 2: TSR tracking PI control}
1 ! PC_ControlMode - Blade pitch control mode {0: No pitch, fix to fine pitch, 1: active PI blade pitch control}
0 ! Y_ControlMode - Yaw control mode {0: no yaw control, 1: yaw rate control, 2: yaw-by-IPC}
1 ! SS_Mode - Setpoint Smoother mode {0: no setpoint smoothing, 1: introduce setpoint smoothing}
0 ! WE_Mode - Wind speed estimator mode {0: One-second low pass filtered hub height wind speed, 1: Immersion and Invariance Estimator, 2: Extended Kalman Filter}
0 ! PS_Mode - Pitch saturation mode {0: no pitch saturation, 1: implement pitch saturation}
0 ! SD_Mode - Shutdown mode {0: no shutdown procedure, 1: pitch to max pitch at shutdown}
0 ! Fl_Mode - Floating specific feedback mode {0: no nacelle velocity feedback, 1: nacelle velocity feedback}
0 ! Flp_Mode - Flap control mode {0: no flap control, 1: steady state flap angle, 2: Proportional flap control}
!------- FILTERS ----------------------------------------------------------
0.4607 ! F_LPFCornerFreq - Corner frequency (-3dB point) in the low-pass filters, [rad/s]
0.70000 ! F_LPFDamping - Damping coefficient [used only when F_FilterType = 2]
0.00000 ! F_NotchCornerFreq - Natural frequency of the notch filter, [rad/s]
0.5 0.6 ! F_NotchBetaNumDen - Two notch damping values (numerator and denominator, resp) - determines the width and depth of the notch, [-]
0.628320000000 ! F_SSCornerFreq - Corner frequency (-3dB point) in the first order low pass filter for the setpoint smoother, [rad/s].
0.21300 1.00000 ! F_FlCornerFreq - Corner frequency and damping in the second order low pass filter of the tower-top fore-aft motion for floating feedback control [rad/s, -].
1.16240 1.00000 ! F_FlpCornerFreq - Corner frequency and damping in the second order low pass filter of the blade root bending moment for flap control [rad/s, -].
!------- BLADE PITCH CONTROL ----------------------------------------------
28 ! PC_GS_n - Amount of gain-scheduling table entries
0.061387 0.089025 0.111184 0.130402 0.147722 0.163680 0.178598 0.192682 0.206100 0.218890 0.231158 0.243041 0.254621 0.265678 0.276596 0.287144 0.297491 0.307602 0.317520 0.327195 0.336859 0.346057 0.355488 0.364400 0.373303 0.382460 0.390818 0.399370 ! PC_GS_angles - Gain-schedule table: pitch angles
-0.4707 -0.3949 -0.3330 -0.2816 -0.2382 -0.2011 -0.1689 -0.1409 -0.1162 -0.0942 -0.0745 -0.0569 -0.0410 -0.0264 -0.0132 -0.0011 0.0101 0.0204 0.0298 0.0387 0.0469 0.0546 0.0618 0.0684 0.0748 0.0807 0.0863 0.0916 ! PC_GS_KP - Gain-schedule table: pitch controller kp gains
-0.0094 -0.0085 -0.0077 -0.0070 -0.0065 -0.0061 -0.0057 -0.0053 -0.0050 -0.0047 -0.0045 -0.0042 -0.0040 -0.0039 -0.0036 -0.0035 -0.0034 -0.0033 -0.0031 -0.0030 -0.0029 -0.0028 -0.0027 -0.0027 -0.0025 -0.0024 -0.0024 -0.0023 ! PC_GS_KI - Gain-schedule table: pitch controller ki gains
0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 ! PC_GS_KD - Gain-schedule table: pitch controller kd gains
0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 ! PC_GS_TF - Gain-schedule table: pitch controller tf gains (derivative filter)
1.570800000000 ! PC_MaxPit - Maximum physical pitch limit, [rad].
0.000000000000 ! PC_MinPit - Minimum physical pitch limit, [rad].
0.034900000000 ! PC_MaxRat - Maximum pitch rate (in absolute value) in pitch controller, [rad/s].
-0.03490000000 ! PC_MinRat - Minimum pitch rate (in absolute value) in pitch controller, [rad/s].
0.791670000000 ! PC_RefSpd - Desired (reference) HSS speed for pitch controller, [rad/s].
0.000000000000 ! PC_FinePit - Record 5: Below-rated pitch angle set-point, [rad]
0.017450000000 ! PC_Switch - Angle above lowest minimum pitch angle for switch, [rad]
!------- INDIVIDUAL PITCH CONTROL -----------------------------------------
0.0 ! IPC_IntSat - Integrator saturation (maximum signal amplitude contribution to pitch from IPC), [rad]
0.0 0.0 ! IPC_KI - Integral gain for the individual pitch controller: first parameter for 1P reductions, second for 2P reductions, [-]
0.0 0.0 ! IPC_aziOffset - Phase offset added to the azimuth angle for the individual pitch controller, [rad].
0.0 ! IPC_CornerFreqAct - Corner frequency of the first-order actuators model, to induce a phase lag in the IPC signal {0: Disable}, [rad/s]
!------- VS TORQUE CONTROL ------------------------------------------------
96.55000000000 ! VS_GenEff - Generator efficiency mechanical power → electrical power, [should match the efficiency defined in the generator properties!], [%]
19624409.75999 ! VS_ArSatTq - Above rated generator torque PI control saturation, [Nm]
4500000.000000 ! VS_MaxRat - Maximum torque rate (in absolute value) in torque controller, [Nm/s].
21586850.73599 ! VS_MaxTq - Maximum generator torque in Region 3 (HSS side), [Nm].
0.000000000000 ! VS_MinTq - Minimum generator (HSS side), [Nm].
0.523600000000 ! VS_MinOMSpd - Optimal mode minimum speed, cut-in speed towards optimal mode gain path, [rad/s]
31255062.12922 ! VS_Rgn2K - Generator torque constant in Region 2 (HSS side), [N-m/(rad/s)^2]
15000000.00000 ! VS_RtPwr - Wind turbine rated power [W]
19624409.75999 ! VS_RtTq - Rated torque, [Nm].
0.791670000000 ! VS_RefSpd - Rated generator speed [rad/s]
1 ! VS_n - Number of generator PI torque controller gains
-36454628.62851 ! VS_KP - Proportional gain for generator PI torque controller [1/(rad/s) Nm]. (Only used in the transitional 2.5 region if VS_ControlMode =/ 2)
-2039220.08320 ! VS_KI - Integral gain for generator PI torque controller [1/rad Nm]. (Only used in the transitional 2.5 region if VS_ControlMode =/ 2)
9.00 ! VS_TSRopt - Power-maximizing region 2 tip-speed-ratio [rad].
!------- SETPOINT SMOOTHER ---------------------------------------------
1.00000 ! SS_VSGain - Variable speed torque controller setpoint smoother gain, [-].
0.00100 ! SS_PCGain - Collective pitch controller setpoint smoother gain, [-].
!------- WIND SPEED ESTIMATOR ---------------------------------------------
120.000 ! WE_BladeRadius - Blade length (distance from hub center to blade tip), [m]
1 ! WE_CP_n - Amount of parameters in the Cp array
0.0 0.0 0.0 0.0 ! WE_CP - Parameters that define the parameterized CP(lambda) function
0.0 ! WE_Gamma - Adaption gain of the wind speed estimator algorithm [m/rad]
1.0 ! WE_GearboxRatio - Gearbox ratio [>=1], [-]
318628138.00000 ! WE_Jtot - Total drivetrain inertia, including blades, hub and casted generator inertia to LSS, [kg m^2]
1.225 ! WE_RhoAir - Air density, [kg m^-3]
“Cp_Ct_Cq.IEA15MW.txt” ! PerfFileName - File containing rotor performance tables (Cp,Ct,Cq)
101 73 ! PerfTableSize - Size of rotor performance tables, first number refers to number of blade pitch angles, second number referse to number of tip-speed ratios
44 ! WE_FOPoles_N - Number of first-order system poles used in EKF
3.00 3.50 4.00 4.50 5.00 5.50 6.00 6.50 7.00 7.50 8.00 8.50 9.00 9.50 10.00 10.50 11.24 11.74 12.24 12.74 13.24 13.74 14.24 14.74 15.24 15.74 16.24 16.74 17.24 17.74 18.24 18.74 19.24 19.74 20.24 20.74 21.24 21.74 22.24 22.74 23.24 23.74 24.24 24.74 ! WE_FOPoles_v - Wind speeds corresponding to first-order system poles [m/s]
-0.02216823 -0.02586293 -0.02955764 -0.03325234 -0.03694705 -0.04064175 -0.04433646 -0.04803116 -0.05172586 -0.05542057 -0.05911527 -0.06280998 -0.06650468 -0.07019939 -0.07389409 -0.07758880 -0.05251672 -0.05513898 -0.06148410 -0.06972031 -0.07936618 -0.09012729 -0.10180682 -0.11430744 -0.12756388 -0.14140211 -0.15579992 -0.17087585 -0.18664824 -0.20256185 -0.21931321 -0.23633449 -0.25391169 -0.27192045 -0.29039596 -0.30912439 -0.32872385 -0.34790708 -0.36846338 -0.38842442 -0.40898909 -0.43103810 -0.45141978 -0.47294282 ! WE_FOPoles - First order system poles
!------- YAW CONTROL ------------------------------------------------------
0.0 ! Y_ErrThresh - Yaw error threshold. Turbine begins to yaw when it passes this. [rad^2 s]
0.0 ! Y_IPC_IntSat - Integrator saturation (maximum signal amplitude contribution to pitch from yaw-by-IPC), [rad]
1 ! Y_IPC_n - Number of controller gains (yaw-by-IPC)
0.0 ! Y_IPC_KP - Yaw-by-IPC proportional controller gain Kp
0.0 ! Y_IPC_KI - Yaw-by-IPC integral controller gain Ki
0.0 ! Y_IPC_omegaLP - Low-pass filter corner frequency for the Yaw-by-IPC controller to filtering the yaw alignment error, [rad/s].
0.0 ! Y_IPC_zetaLP - Low-pass filter damping factor for the Yaw-by-IPC controller to filtering the yaw alignment error, [-].
0.0 ! Y_MErrSet - Yaw alignment error, set point [rad]
0.0 ! Y_omegaLPFast - Corner frequency fast low pass filter, 1.0 [Hz]
0.0 ! Y_omegaLPSlow - Corner frequency slow low pass filter, 1/60 [Hz]
0.0 ! Y_Rate - Yaw rate [rad/s]
!------- TOWER FORE-AFT DAMPING -------------------------------------------
-1 ! FA_KI - Integral gain for the fore-aft tower damper controller, -1 = off / >0 = on [rad s/m] - !NJA - Make this a flag
0.0 ! FA_HPF_CornerFreq - Corner frequency (-3dB point) in the high-pass filter on the fore-aft acceleration signal [rad/s]
0.0 ! FA_IntSat - Integrator saturation (maximum signal amplitude contribution to pitch from FA damper), [rad]
!------- MINIMUM PITCH SATURATION -------------------------------------------
44 ! PS_BldPitchMin_N - Number of values in minimum blade pitch lookup table (should equal number of values in PS_WindSpeeds and PS_BldPitchMin)
3.00 3.50 4.00 4.50 5.00 5.50 6.00 6.50 7.00 7.50 8.00 8.50 9.00 9.50 10.00 10.50 11.24 11.74 12.24 12.74 13.24 13.74 14.24 14.74 15.24 15.74 16.24 16.74 17.24 17.74 18.24 18.74 19.24 19.74 20.24 20.74 21.24 21.74 22.24 22.74 23.24 23.74 24.24 24.74 ! PS_WindSpeeds - Wind speeds corresponding to minimum blade pitch angles [m/s]
0.06981317 0.06981317 0.06544985 0.05672320 0.04799655 0.03490659 0.02181662 0.00872665 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 0.00000000 ! PS_BldPitchMin - Minimum blade pitch angles [rad]
!------- SHUTDOWN -------------------------------------------
0.399370000000 ! SD_MaxPit - Maximum blade pitch angle to initiate shutdown, [rad]
0.418880000000 ! SD_CornerFreq - Cutoff Frequency for first order low-pass filter for blade pitch angle, [rad/s]
!------- Floating -------------------------------------------
0.000000000000 ! Fl_Kp - Nacelle velocity proportional feedback gain [s]
!------- FLAP ACTUATION -----------------------------------------------------
0.000000000000 ! Flp_Angle - Initial or steady state flap angle [rad]
0.00000000e+00 ! Flp_Kp - Blade root bending moment proportional gain for flap control [s]
0.00000000e+00 ! Flp_Ki - Flap displacement integral gain for flap control [s]
0.000000000000 ! Flp_MaxPit - Maximum (and minimum) flap pitch angle [rad][/code]
Indeed I am resonating the structure but I’m prescribing the exact force that will lead to the desired motion, even under resonating conditions which comes from the solution of a linear mechanical system when subjected to a sinusoidal force of constant amplitude. I didn’t have any force related tunning to do. The only parameter I had to tune was the prescribed mass/inertia. The force I’m prescribing is:
