Tower vibration model and analysis problem in FAST v8
Hi everyone, I am working on the modal analysis of the turbine tower. However, I have some confusion on fore-aft vibration modelling and the related output data from FAST.
After enabling both the first and second modein ElastoDyn.dat, I obtained the output from the tower gages (TwHt1ALxt-TwHt9ALxt ), and the tower top acceleration (YawBrTAxp) for the fore-aft vibration. And then implement an power spectural density analysis on the data. My confusion is that there is two peaks in the PSD of the tower gages data, while only one peak for the first mode in the PSD of ‘YawBrRAxp’. (Show in the left column in the figure).
And I also try to enable only one mode, the first and the second, and then derive PSD of the ‘YawBrTAxp’. And I can derive the two peaks corresponding to the first and second mode, respetively. But if I enable both two modes, again there is only one peak in the PSD. (Shown in the right column in the figure).
So I am confused on these results. I would expect to get two peaks corresponding to two modes from the tower-top measurement as in the tower gages. Does this expectation make sense? And should I make some more modification on the ‘ElastoDyn.dat’ file? (the current one is also attached here)
And I am also wondering how FAST derives the acceleration while both two modes are enabled. (Since it seems that it is not simply adding two modes together). Is there references for the theory part?
(The data sampling time is 0.01s in the simulation. The wind speed is step steady wind at 10m/s, the controller is the k_omega_Square torque controller.)
Thanks in advance for your help!
The details of ElastroDyn.dat are as below:
False         Echo        - Echo input data to "<RootName>.ech" (flag)
          3   Method      - Integration method: {1: RK4, 2: AB4, or 3: ABM4} (-)
"DEFAULT"     DT          - Integration time step (s)
    9.80665   Gravity     - Gravitational acceleration (m/s^2)
False         FlapDOF1    - First flapwise blade mode DOF (flag)
False         FlapDOF2    - Second flapwise blade mode DOF (flag)
False         EdgeDOF     - First edgewise blade mode DOF (flag)
False         TeetDOF     - Rotor-teeter DOF (flag) [unused for 3 blades]
True          DrTrDOF     - Drivetrain rotational-flexibility DOF (flag)
True          GenDOF      - Generator DOF (flag)
False         YawDOF      - Yaw DOF (flag)
True          TwFADOF1    - First fore-aft tower bending-mode DOF (flag)
True          TwFADOF2    - Second fore-aft tower bending-mode DOF (flag)
True          TwSSDOF1    - First side-to-side tower bending-mode DOF (flag)
True          TwSSDOF2    - Second side-to-side tower bending-mode DOF (flag)
False         PtfmSgDOF   - Platform horizontal surge translation DOF (flag)
False         PtfmSwDOF   - Platform horizontal sway translation DOF (flag)
False         PtfmHvDOF   - Platform vertical heave translation DOF (flag)
False         PtfmRDOF    - Platform roll tilt rotation DOF (flag)
False         PtfmPDOF    - Platform pitch tilt rotation DOF (flag)
False         PtfmYDOF    - Platform yaw rotation DOF (flag)
          0   OoPDefl     - Initial out-of-plane blade-tip displacement (meters)
          0   IPDefl      - Initial in-plane blade-tip deflection (meters)
      0.0000   BlPitch(1)  - Blade 1 initial pitch (degrees)
      0.0000   BlPitch(2)  - Blade 2 initial pitch (degrees)
      0.0000   BlPitch(3)  - Blade 3 initial pitch (degrees) [unused for 2 blades]
          0   TeetDefl    - Initial or fixed teeter angle (degrees) [unused for 3 blades]
          0   Azimuth     - Initial azimuth angle for blade 1 (degrees)
        9.2   RotSpeed    - Initial or fixed rotor speed (rpm)
          0   NacYaw      - Initial or fixed nacelle-yaw angle (degrees)
          0   TTDspFA     - Initial fore-aft tower-top displacement (meters)
          0   TTDspSS     - Initial side-to-side tower-top displacement (meters)
          0   PtfmSurge   - Initial or fixed horizontal surge translational displacement of platform (meters)
          0   PtfmSway    - Initial or fixed horizontal sway translational displacement of platform (meters)
          0   PtfmHeave   - Initial or fixed vertical heave translational displacement of platform (meters)
          0   PtfmRoll    - Initial or fixed roll tilt rotational displacement of platform (degrees)
          0   PtfmPitch   - Initial or fixed pitch tilt rotational displacement of platform (degrees)
          0   PtfmYaw     - Initial or fixed yaw rotational displacement of platform (degrees)
          3   NumBl       - Number of blades (-)
 63.0000      TipRad      - The distance from the rotor apex to the blade tip (meters)
 1.5000      HubRad      - The distance from the rotor apex to the blade root (meters)
  -2.5      PreCone(1)  - Blade 1 cone angle (degrees)
  -2.5      PreCone(2)  - Blade 2 cone angle (degrees)
  -2.5      PreCone(3)  - Blade 3 cone angle (degrees) [unused for 2 blades]
          0   HubCM       - Distance from rotor apex to hub mass [positive downwind] (meters)
          0   UndSling    - Undersling length [distance from teeter pin to the rotor apex] (meters) [unused for 3 blades]
          0   Delta3      - Delta-3 angle for teetering rotors (degrees) [unused for 3 blades]
          0   AzimB1Up    - Azimuth value to use for I/O when blade 1 points up (degrees)
 -5.01910      OverHang    - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
      1.912   ShftGagL    - Distance from rotor apex [3 blades] or teeter pin [2 blades] to shaft strain gages [positive for upwind rotors] (meters)
 -5.0      ShftTilt    - Rotor shaft tilt angle (degrees)
 1.90000      NacCMxn     - Downwind distance from the tower-top to the nacelle CM (meters)
          0   NacCMyn     - Lateral  distance from the tower-top to the nacelle CM (meters)
  1.75      NacCMzn     - Vertical distance from the tower-top to the nacelle CM (meters)
   -3.09528   NcIMUxn     - Downwind distance from the tower-top to the nacelle IMU (meters)
          0   NcIMUyn     - Lateral  distance from the tower-top to the nacelle IMU (meters)
    2.23336   NcIMUzn     - Vertical distance from the tower-top to the nacelle IMU (meters)
 2.40000      Twr2Shft    - Vertical distance from the tower-top to the rotor shaft (meters)
 87.60      TowerHt     - Height of tower above ground level [onshore] or MSL [offshore] (meters)
          0   TowerBsHt   - Height of tower base above ground level [onshore] or MSL [offshore] (meters)
          0   PtfmCMxt    - Downwind distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
          0   PtfmCMyt    - Lateral distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
          0   PtfmCMzt    - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
          0   PtfmRefzt   - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform reference point (meters)
          0   TipMass(1)  - Tip-brake mass, blade 1 (kg)
          0   TipMass(2)  - Tip-brake mass, blade 2 (kg)
          0   TipMass(3)  - Tip-brake mass, blade 3 (kg) [unused for 2 blades]
 5.678E+04      HubMass     - Hub mass (kg)
 1.159E+05      HubIner     - Hub inertia about rotor axis [3 blades] or teeter axis [2 blades] (kg m^2)
 534.116      GenIner     - Generator inertia about HSS (kg m^2)
 2.400E+05      NacMass     - Nacelle mass (kg)
 2.599E+06      NacYIner    - Nacelle inertia about yaw axis (kg m^2)
          0   YawBrMass   - Yaw bearing mass (kg)
          0   PtfmMass    - Platform mass (kg)
          0   PtfmRIner   - Platform inertia for roll tilt rotation about the platform CM (kg m^2)
          0   PtfmPIner   - Platform inertia for pitch tilt rotation about the platform CM (kg m^2)
          0   PtfmYIner   - Platform inertia for yaw rotation about the platform CM (kg m^2)
         48   BldNodes    - Number of blade nodes (per blade) used for analysis (-)
"ElastoDyn_blade.dat"    BldFile(1)  - Name of file containing properties for blade 1 (quoted string)
"ElastoDyn_blade.dat"    BldFile(2)  - Name of file containing properties for blade 2 (quoted string)
"ElastoDyn_blade.dat"    BldFile(3)  - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
          0   TeetMod     - Rotor-teeter spring/damper model {0: none, 1: standard, 2: user-defined from routine UserTeet} (switch) [unused for 3 blades]
          0   TeetDmpP    - Rotor-teeter damper position (degrees) [used only for 2 blades and when TeetMod=1]
          0   TeetDmp     - Rotor-teeter damping constant (N-m/(rad/s)) [used only for 2 blades and when TeetMod=1]
          0   TeetCDmp    - Rotor-teeter rate-independent Coulomb-damping moment (N-m) [used only for 2 blades and when TeetMod=1]
          0   TeetSStP    - Rotor-teeter soft-stop position (degrees) [used only for 2 blades and when TeetMod=1]
          0   TeetHStP    - Rotor-teeter hard-stop position (degrees) [used only for 2 blades and when TeetMod=1]
          0   TeetSSSp    - Rotor-teeter soft-stop linear-spring constant (N-m/rad) [used only for 2 blades and when TeetMod=1]
          0   TeetHSSp    - Rotor-teeter hard-stop linear-spring constant (N-m/rad) [used only for 2 blades and when TeetMod=1]
 100.0      GBoxEff     - Gearbox efficiency (%)
  97.0      GBRatio     - Gearbox ratio (-)
8.67637E+08   DTTorSpr    - Drivetrain torsional spring (N-m/rad)
  6.215E+06   DTTorDmp    - Drivetrain torsional damper (N-m/(rad/s))
False         Furling     - Read in additional model properties for furling turbine (flag) [must currently be FALSE)
"unused"      FurlFile    - Name of file containing furling properties (quoted string) [unused when Furling=False]
  40        TwrNodes    - Number of tower nodes used for analysis (-)
"ElastoDyn_tower.dat"    TwrFile     - Name of file containing tower properties (quoted string)
True          SumPrint    - Print summary data to "<RootName>.sum" (flag)
          1   OutFile     - Switch to determine where output will be placed: {1: in module output file only; 2: in glue code output file only; 3: both} (currently unused)
True          TabDelim    - Use tab delimiters in text tabular output file? (flag) (currently unused)
"ES10.3E2"    OutFmt      - Format used for text tabular output (except time).  Resulting field should be 10 characters. (quoted string) (currently unused)
          0   TStart      - Time to begin tabular output (s) (currently unused)
          1   DecFact     - Decimation factor for tabular output {1: output every time step} (-) (currently unused)
          9   NTwGages    - Number of tower nodes that have strain gages for output [0 to 9] (-)
          1,          2,          3,          4,          5,          6,          7,          8,          9    TwrGagNd    - List of tower nodes that have strain gages [1 to TwrNodes] (-) [unused if NTwGages=0]
          0   NBlGages    - Number of blade nodes that have strain gages for output [0 to 9] (-)
          5,          9,         13    BldGagNd    - List of blade nodes that have strain gages [1 to BldNodes] (-) [unused if NBlGages=0]
              OutList     - The next line(s) contains a list of output parameters.  See OutListParameters.xlsx for a listing of available output channels, (-)
"OoPDefl1"
"OoPDefl2"
"OoPDefl3"
"IPDefl1"
"IPDefl2"
"IPDefl3"
"NcIMUTAxs"
"NcIMUTAys"
"NcIMUTAzs"
"NcIMUTVxs"
"NcIMUTVys"
"NcIMUTVzs"
"NcIMURAxs"
"NcIMURAys"
"NcIMURAzs"
"RootMOoP1"
"RootMOoP2"
"RootMOoP3"
"RootMIP1"
"RootMIP2"
"RootMIP3"
"RootMFlp1"
"RootMFlp2"
"RootMFlp3"
"RootMEdg1"
"RootMEdg2"
"RootMEdg3"
"TwrBsMxt"
"TwrBsMyt"
"TwrBsMzt"
"LSSTipMya"
"LSSTipMza"
"LSSTipVxa"
"GenSpeed"
"BlPitch1"
"BlPitch2"
"BlPitch3"
"Azimuth"
"RotPwr"
"RotThrust"
"RotSpeed"
"HSShftTq"
"LSShftFya"
"LSShftFza"
"LSShftFys"
"LSShftFzs"
"YawBrFyp"
"YawBrTDyt"
"RotTorq"
"TwHt1ALxt"
"TwHt1ALyt"
"TwHt2ALxt"
"TwHt2ALyt"
"TwHt3ALxt"
"TwHt3ALyt"
"TwHt4ALxt"
"TwHt4ALyt"
"TwHt5ALxt"
"TwHt5ALyt"
"TwHt6ALxt"
"TwHt6ALyt"
"TwHt7ALxt"
"TwHt7ALyt"
"TwHt8ALxt"
"TwHt8ALyt"
"TwHt9ALxt"
"TwHt9ALyt"
"TwHt1TDxt"
"TwHt1TDYt"
"TwHt2TDxt"
"TwHt2TDyt"
"TwHt3TDxt"
"TwHt3TDyt"
"TwHt4TDxt"
"TwHt4TDyt"
"TwHt5TDxt"
"TwHt5TDyt"
"TwHt6TDxt"
"TwHt6TDyt"
"TwHt7TDxt"
"TwHt7TDyt"
"TwHt8TDxt"
"TwHt8TDyt"
"TwHt9TDxt"
"TwHt9TDyt"
"YawBrTDxp"
"YawBrTDyp"
"YawBrTDzp"
"YawBrTDxt"
"YawBrTDyt"
"YawBrTDzt"
"YawBrTAxp"
"YawBrTAyp"
"YawBrTAzp"
"YawBrRDxt"
"YawBrRDyt"
"YawBrRDzt"
"YawBrRVxp"
"YawBrRVyp"
"YawBrRVzp"
"YawBrRAxp"
"YawBrRAyp"
"YawBrRAzp"
Dear @Zhixin.Feng,
I would generally expect that you’d see both peaks in the acceleration PSD output if both modes are excited. I do see that your tower gage nodes are all located near the bottom of the tower, so, perhaps the contribution of the second mode in your model is more important lower down? I would expect the acceleration output from the tower-gage nodes to approach the result at the yaw bearing as you increase the location of the tower-gage nodes (e.g., increase TwrGagNd up to TwrNodes = 40).
The contribution of each tower bending mode is summed via superposition in the calculation of overall tower motions. See the “FASTKinematics” documentation in the ElastoDyn Users Guide and Theory Manual for more information: 4.2.7. ElastoDyn Users Guide and Theory Manual — OpenFAST v3.3.0 documentation.
Thanks a lot. You are right that the second mode is more obvious close to the bottom.
Best,
Zhixin
