Thanks @Jason.Jonkman. I will take this first approach.
AOAW
AOAW
Hi @Jason.Jonkman I have set GenDOF = false and RotSpeed = 0 and I received the following error:
violated in SUBROUTINE SmllRotTrans() due to a large blade deflection (ElastoDyn SetCoordSy). The
be suppressed. Additional debugging message from SUBROUTINE SmllRotTrans(): 0.75 s
FAST_Solution:FAST_AdvanceStates:SolveOption2c_Inp2AD_SrvD:InflowWind_CalcOutput:CalcOutput:IfW_FF
Wind_CalcOutput [position=(-230.26, -245.8, 117.55) in wind-file coordinates]: FF wind array
boundaries violated: Grid too small in Y direction. Y=-245.8; Y boundaries = [-200, 200]
OpenFAST encountered an error at simulation time 1 of 3600 seconds. Simulation error level: FATAL ERROR
By way of reminder, I am parking turbine in extreme wind so wind speed is 45 m/s. Let me know how I could solve this problem.
Thank you.
AOAW
Hi @Jason.Jonkman just checking if you were able to figure out what might be the cause of this error. I am still trying to decipher but no luck as yet.
AOAW
Dear @Andre.White,
It sounds like your model has gone unstable. Can you clarify your simulation settings? It sounds like youâve parked the rotor with GenDOF
= False and RotSpeed
= 0.0 rpm and have set the pitch angles to BlPitch
= 91.5deg. Can you confirm? Are you getting these errors only for certain yaw misalignments (wind directions)?
Hi @Jason.Jonkman I have responded to this on another forum I have created as it deals with modelling a parked turbine and think it is more appropriate to shift the discussion there.
AOAW
Dear @Jason.Jonkman ,
I am doing simulations of monopile-supported offshore wind turbines using OPENFAST (including soildyn module) downloaded from GitHub. Only DISCON and OPENFAST source code have been recompiled, and all input files have not been modified. Three foundation models including fixed bottom model, REDWIN model and CS model in OC6 phaseII have been used for simulations. However, the simulations with fixed bottom model and REDWIN model aborted with a few errors, and relevant information was attached below. And can you provide another available OPENFAST resource code and r-test file?
Thanks in advance.
Dear @Kevin.Chang,
The issue with your fixed-bottom set-up sounds like a numerical instability. Have you set solver settings typical for fixed offshore wind turbines with SubDyn enabled, e.g., DT
sufficiently small to solve the natural frequencies and excitation frequencies of your model, NumCrctn
= 1, and UJacSclFact
equal to a value roughly the same order of magnitude as the total system mass in kg?
The issue with your REDWIN set-up is that the DLL cannot be loaded. Does DLL_FileName
in your SoilDyn input file refer to the correct name and location of the DLL?
Iâm not sure I understand your last question, but the OC6 Phase II model is likely the best example model with SoilDyn available so far.
(1) After setting NumCrctn=1, the same error presented above still occurs. Here is my input files.
------- OpenFAST EXAMPLE INPUT FILE -------------------------------------------
FAST Certification Test #19: NREL 5.0 MW Baseline Wind Turbine with OC3 Monopile RF Configuration, for use in offshore analysis
True Echo - Echo input data to <RootName>.ech (flag)
"FATAL" AbortLevel - Error level when simulation should abort (string) {"WARNING", "SEVERE", "FATAL"}
60 TMax - Total run time (s)
0.0001 DT - Recommended module time step (s)
1 NumCrctn - Number of correction iterations (-) {0=explicit calculation, i.e., no corrections}
99999 DT_UJac - Time between calls to get Jacobians (s)
1E+06 UJacSclFact - Scaling factor used in Jacobians (-)
1 CompHydro - Compute hydrodynamic loads (switch) {0=None; 1=HydroDyn}
1 CompSub - Compute sub-structural dynamics (switch) {0=None; 1=SubDyn; 2=External Platform MCKF}
0 CompMooring - Compute mooring system (switch) {0=None; 1=MAP++; 2=FEAMooring; 3=MoorDyn; 4=OrcaFlex}
0 CompSoil - Compute soil-structural dynamics (switch) {0=None; 1=with SubDyn mesh}
0 MHK - MHK turbine type (switch) {0=Not an MHK turbine; 1=Fixed MHK turbine; 2=Floating MHK turbine}
1027 WtrDens - Water density (kg/m^3)
1.464E-05 KinVisc - Kinematic viscosity of working fluid (m^2/s)
335 SpdSound - Speed of sound in working fluid (m/s)
103500 Patm - Atmospheric pressure (Pa) [used only for an MHK turbine cavitation check]
1700 Pvap - Vapour pressure of working fluid (Pa) [used only for an MHK turbine cavitation check]
20 WtrDpth - Water depth (m)
0 MSL2SWL - Offset between still-water level and mean sea level (m) [positive upward]
"NRELOffshrBsline5MW_OC3Monopile_ElastoDyn.dat" EDFile - Name of file containing ElastoDyn input parameters (quoted string)
"../5MW_Baseline/NRELOffshrBsline5MW_BeamDyn.dat" BDBldFile(1) - Name of file containing BeamDyn input parameters for blade 1 (quoted string)
"../5MW_Baseline/NRELOffshrBsline5MW_BeamDyn.dat" BDBldFile(2) - Name of file containing BeamDyn input parameters for blade 2 (quoted string)
"../5MW_Baseline/NRELOffshrBsline5MW_BeamDyn.dat" BDBldFile(3) - Name of file containing BeamDyn input parameters for blade 3 (quoted string)
"../5MW_Baseline/NRELOffshrBsline5MW_InflowWind_12mps.dat" InflowFile - Name of file containing inflow wind input parameters (quoted string)
"NRELOffshrBsline5MW_OC3Monopile_AeroDyn15.dat" AeroFile - Name of file containing aerodynamic input parameters (quoted string)
"NRELOffshrBsline5MW_OC3Monopile_ServoDyn.dat" ServoFile - Name of file containing control and electrical-drive input parameters (quoted string)
"NRELOffshrBsline5MW_OC3Monopile_HydroDyn.dat" HydroFile - Name of file containing hydrodynamic input parameters (quoted string)
"NRELOffshrBsline5MW_OC3Monopile_SubDyn.dat" SubFile - Name of file containing sub-structural input parameters (quoted string)
"unused" MooringFile - Name of file containing mooring system input parameters (quoted string)
"unused" IceFile - Name of file containing ice input parameters (quoted string)
"unused" SoilFile - Name of the file containing the SoilDyn input parameters (quoted string)
------- SERVODYN v1.05.* INPUT FILE --------------------------------------------
NREL 5.0 MW Baseline Wind Turbine for Use in Offshore Analysis. Properties from Dutch Offshore Wind Energy Converter (DOWEC) 6MW Pre-Design (10046_009.pdf) and REpower 5M 5MW (5m_uk.pdf);
False Echo - Echo input data to <RootName>.ech (flag)
"default" DT - Communication interval for controllers (s) (or "default")
5 PCMode - Pitch control mode {0: none, 3: user-defined from routine PitchCntrl, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
0 TPCOn - Time to enable active pitch control (s) [unused when PCMode=0]
2 PitManRat(1) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 1 (deg/s)
2 PitManRat(2) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 2 (deg/s)
2 PitManRat(3) - Pitch rate at which override pitch maneuver heads toward final pitch angle for blade 3 (deg/s) [unused for 2 blades]
0 BlPitchF(1) - Blade 1 final pitch for pitch maneuvers (degrees)
0 BlPitchF(2) - Blade 2 final pitch for pitch maneuvers (degrees)
0 BlPitchF(3) - Blade 3 final pitch for pitch maneuvers (degrees) [unused for 2 blades]
5 VSContrl - Variable-speed control mode {0: none, 1: simple VS, 3: user-defined from routine UserVSCont, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
0 TimGenOn - Time to turn on the generator for a startup (s) [used only when GenTiStr=True]
0 YawNeut - Neutral yaw position--yaw spring force is zero at this yaw (degrees)
9.02832E+09 YawSpr - Nacelle-yaw spring constant (N-m/rad)
1.916E+07 YawDamp - Nacelle-yaw damping constant (N-m/(rad/s))
2 YawManRat - Yaw maneuver rate (in absolute value) (deg/s)
0 NacYawF - Final yaw angle for override yaw maneuvers (degrees)
---------------------- AERODYNAMIC FLOW CONTROL --------------------------------
0 AfCmode - Airfoil control mode {0: none, 1: cosine wave cycle, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
0 AfC_Mean - Mean level for cosine cycling or steady value (-) [used only with AfCmode==1]
0 AfC_Amp - Amplitude for for cosine cycling of flap signal (-) [used only with AfCmode==1]
0 AfC_Phase - Phase relative to the blade azimuth (0 is vertical) for for cosine cycling of flap signal (deg) [used only with AfCmode==1]
---------------------- STRUCTURAL CONTROL --------------------------------------
0 NumBStC - Number of blade structural controllers (integer)
"unused" BStCfiles - Name of the files for blade structural controllers (quoted strings) [unused when NumBStC==0]
0 NumNStC - Number of nacelle structural controllers (integer)
"unused" NStCfiles - Name of the files for nacelle structural controllers (quoted strings) [unused when NumNStC==0]
0 NumTStC - Number of tower structural controllers (integer)
"unused" TStCfiles - Name of the files for tower structural controllers (quoted strings) [unused when NumTStC==0]
0 NumSStC - Number of substructure structural controllers (integer)
"unused" SStCfiles - Name of the files for substructure structural controllers (quoted strings) [unused when NumSStC==0]
---------------------- CABLE CONTROL -------------------------------------------
0 CCmode - Cable control mode {0: none, 4: user-defined from Simulink/Labview, 5: user-defined from Bladed-style DLL} (switch)
"../5MW_Baseline/ServoData/DISCON.dll" DLL_FileName - Name/location of the dynamic library {.dll [Windows] or .so [Linux]} in the Bladed-DLL format (-) [used only with Bladed Interface]
"DISCON.IN" DLL_InFile - Name of input file sent to the DLL (-) [used only with Bladed Interface]
"DISCON" DLL_ProcName - Name of procedure in DLL to be called (-) [case sensitive; used only with DLL Interface]
"default" DLL_DT - Communication interval for dynamic library (s) (or "default") [used only with Bladed Interface]
false DLL_Ramp - Whether a linear ramp should be used between DLL_DT time steps [introduces time shift when true] (flag) [used only with Bladed Interface]
9999.9 BPCutoff - Cutoff frequency for low-pass filter on blade pitch from DLL (Hz) [used only with Bladed Interface]
0 NacYaw_North - Reference yaw angle of the nacelle when the upwind end points due North (deg) [used only with Bladed Interface]
0 Ptch_SetPnt - Record 5: Below-rated pitch angle set-point (deg) [used only with Bladed Interface]
0 Ptch_Min - Record 6: Minimum pitch angle (deg) [used only with Bladed Interface]
0 Ptch_Max - Record 7: Maximum pitch angle (deg) [used only with Bladed Interface]
0 PtchRate_Min - Record 8: Minimum pitch rate (most negative value allowed) (deg/s) [used only with Bladed Interface]
0 PtchRate_Max - Record 9: Maximum pitch rate (deg/s) [used only with Bladed Interface]
0 Gain_OM - Record 16: Optimal mode gain (Nm/(rad/s)^2) [used only with Bladed Interface]
0 GenSpd_MinOM - Record 17: Minimum generator speed (rpm) [used only with Bladed Interface]
0 GenSpd_MaxOM - Record 18: Optimal mode maximum speed (rpm) [used only with Bladed Interface]
0 GenSpd_Dem - Record 19: Demanded generator speed above rated (rpm) [used only with Bladed Interface]
0 GenTrq_Dem - Record 22: Demanded generator torque above rated (Nm) [used only with Bladed Interface]
0 GenPwr_Dem - Record 13: Demanded power (W) [used only with Bladed Interface]
GenSpd_TLU GenTrq_TLU
(rpm) (Nm)
------- ELASTODYN for OpenFAST INPUT FILE -------------------------------------------
False Echo - Echo input data to "<RootName>.ech" (flag)
"default" DT - Integration time step (s)
True YawDOF - Yaw DOF (flag)
3 RotSpeed - Initial or fixed rotor speed (rpm)
-0.0009 PtfmHeave - Initial or fixed vertical heave translational displacement of platform (meters)
63 TipRad - The distance from the rotor apex to the blade tip (meters)
-5.0191 OverHang - Distance from yaw axis to rotor apex [3 blades] or teeter pin [2 blades] (meters)
-5 ShftTilt - Rotor shaft tilt angle (degrees)
10 TowerBsHt - Height of tower base above ground level [onshore] or MSL [offshore] (meters)
10 PtfmCMzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform CM (meters)
10 PtfmRefzt - Vertical distance from the ground level [onshore] or MSL [offshore] to the platform reference point (meters)
56780 HubMass - Hub mass (kg)
2.60789E+06 NacYIner - Nacelle inertia about yaw axis (kg m^2)
0 YawBrMass - Yaw bearing mass (kg)
0 PtfmMass - Platform mass (kg)
0 PtfmRIner - Platform inertia for roll tilt rotation about the platform CM (kg m^2)
0 PtfmPIner - Platform inertia for pitch tilt rotation about the platform CM (kg m^2)
1.534E+06 PtfmYIner - Platform inertia for yaw rotation about the platform CM (kg m^2)
17 BldNodes - Number of blade nodes (per blade) used for analysis (-)
"../5MW_Baseline/NRELOffshrBsline5MW_Blade.dat" BldFile(1) - Name of file containing properties for blade 1 (quoted string)
"../5MW_Baseline/NRELOffshrBsline5MW_Blade.dat" BldFile(2) - Name of file containing properties for blade 2 (quoted string)
"../5MW_Baseline/NRELOffshrBsline5MW_Blade.dat" BldFile(3) - Name of file containing properties for blade 3 (quoted string) [unused for 2 blades]
97 GBRatio - Gearbox ratio (-)
"unused" FurlFile - Name of file containing furling properties (quoted string) [unused when Furling=False]
"NRELOffshrBsline5MW_OC3Monopile_ElastoDyn_Tower.dat" TwrFile - Name of file containing tower properties (quoted string)
(2)How to obtain REDWINmodel2-2.0_x86.dll? I canât find it on Github. Or what resource code can I compile to get it?
Thanks a lot!
Dear @Kevin.Chang,
Perhaps the issue is with the initial conditions you are using? I see that you are modeling the NREL 5-MW baseline wind turbine, but the initial rotor speed (RotSpeed
) youâve specified is below the cut-in speed for this turbine. We generally recommend to initialize RotSpeed
, as well as the initial blade-pitch angles to their expected (mean) value, conditioned the mean wind speed you are simulating.
The REDWIN DLL was developed by NGI, not NREL, and so, must be obtained through NGI. See the SoilDyn pull request comments for more information: SoilDyn â soil dynamics module by andrew-platt ¡ Pull Request #986 ¡ OpenFAST/openfast ¡ GitHub.
Dear NREL Communities
I got a tower strike error during the DLC 6.1 simulation.
I am trying to imitate the result of âTable 12. IEC Design Load Case Matrixâ
(IEA 15MW VolturnUS-S Reference Platform Technical Report: https://www.nrel.gov/docs/fy20osti/76773.pdf, 34 page)
I set âWakeMod = 0â, âAFAeroMod =1â, âPCMode = 0â, âVSContrl = 0â, âGenDOF = Falseâ, âBlPitch(1), (2), (3) = 90â, and âRotSpeed = 0â to simulate a parked condition turbine according to other relevant posts and OpenFAST documentation.
First, I ran the simulation with a yaw error of -8, +8 (IEC DLC 6.1 condition), but a tower strike error occurred.
Second, I ran the simulation without Yaw error, but a tower strike occurred again.
Third, I tried to run simulation with disable âTwFADOF 2â and âTwSSDOF2â following Daniel.Zalkindâs temporary solution in this post, and simulation was finished normally.
I am wondering whether tower model instability or my simulation settings
FYI, I am using OpenFAST v3.5.1, IEA 15MW v1.1.8, ROSCO v2.8, mwLoADS v8.12.
Here are my OpenFAST settings, which I tried first.
Sangwon
Hi Sangwon,
Can you share some time-series figures of the OpenFAST outputs? Weâd ideally see the generator speed, blade pitch, out-of-plane tip deflection, and tower top deflection.
Best, Dan
Dear @Daniel.Zalkind
This error was caused by my mistake.
I found RotSpeed was set to 7.55.
After I set 0, the simulation was finished normally.
I still have a question about my abnormal results, but this topic is about Tower Strike, so I will post my question on another topic.
Thank you for your kind reply.
Sangwon.
Dear @Jason.Jonkman
When I try to simulate IEA 15MW with OpenFAST+Simulink, I found that as soon as I open the DrTrDOF ,there will be errors.
Could you please tell me why I cannot open the DrTrDOF? Will there exist the torsional motion when I disable DrTrDOF?
Dear @Yinghan.Liu,
The IEA Wind 15-MW reference wind turbine has a direct-drive generator and the shaft is expected to be stiff in torsion, and so, the default way of modeling this turbine in OpenFAST is to keep the DrTrDOF
disabled. If you were to enable DrTrDOF
, you should define reasonable values of the drivetrain stiffness and damping (DTTorSpr
and DTTorDmp
), and you would likely need to reduce the time step to capture the likely high frequency of the drivetrain torsional mode.
Dear Jasonďź
For direct drive wind turbine, why do we consider the shaft to be stiff in OpenFAST? Is that because the lack of gearbox enhance the stiff property?
I see that in ElastoDyn.dat file, there are default DTTorSpr and DTTorDmp parameters. Can we use that parameters directly? If we cannot, how do we define reasonable stiffness and damping parameters?
Thank you so much!
---- Replied Message ----
From | Jason Jonkman via NREL Forumnotifications@nrel.discoursemail.com |
Date | 04/16/2024 00:33 |
To | camille0327camille0327@126.com |
Subject | [NREL Forum] [Wind & Water/Computer-Aided Engineering Software Tools] Tower strike with latest versions of OpenFAST and IEA 15MW |
| Jason.Jonkman
April 15 |
Dear @Yinghan.Liu,
and DTTorDmp
Dear @Jason.Jonkman
Thank you so much!
Dear @Yinghan.Liu,
I was not the one to develop the OpenFAST model of the IEA Wind 15-MW reference wind turbine, but my understanding is that the drivetrain torsion was not modeled because the direct drive shaft was deemed stiff enough that the torsional natural frequency is so high that it would not be excited by aerodynamic loads. Iâm not sure if the values of DTTorSpr
and DTTorDmp
in the OpenFAST model, which are not used because DrTrDOF
= FALSE, are reasonable for this turbine, or are simply carryovers from a different OpenFAST model.
For information on drivetrain properties of the IEA Wind 15-MW reference wind turbine, see the specifications report: https://www.nrel.gov/docs/fy20osti/75698.pdf.
Got it!
Thank you so much for your quick reply!
Hello All,
I was having the same error " SetDisturbedInflow:TwrInfl:Tower strike", so I did not want to post somewhere else. I am using AMR-Wind (v.2.1.0) coupled with OpenFAST (v.3.5.0) and ROSCO (v.2.9) for my research. I have a couple of questions so I will post them all here.
I am using IEA-3.4-130-RWT, and downloaded from [GitHub - IEAWindTask37/IEA-3.4-130-RWT: This repository contains the model data of the land-based reference wind turbine developed within IEA Wind Task 37], my question is that apart from this [[4.1.2. API changes between versions â OpenFAST v3.5.3 documentation] which is very hard for a new user like me to update OpenFAST files with the version, anywhere else instruction to do that and easily explain?
Previously, I was using AMR-Wind (v.1.0), OpenFAST(v.3.1.0), and ROSCO (v.2.9), and I was having the same âTower Strikeâ problem while using NREL-2p5-116 wind turbine, so I did [âTwrPotent = 0, TwrShadow =0â], then I get âMach number exceeds 1.0â so there is also someone reported the same problem, after looking into the solution from that post I did âAFAeroMod =1, SkewMod =1â, simulation was run for 700s seconds, it completed normally, but having some problem in plotting the AMR-Wind output files, I did all these steps for IEA-3.4-130-RWT but I am getting tower strike after 12s here also.
Besides this [GitHub - NREL/openfast-turbine-models: A repository of OpenFAST turbine models developed by NREL researchers.] is there anywhere else I can download OpenFAST turbine files for different models?
P.S. I cannot attach files for IEA-3.4-130-RWT, and NREL-2p5-116 in the attachment is there any way to do that, so that an expert can look into it? I have attached a screenshot of the AMR-Wind error file.
Thank you in advance
Asim
Dear @Raja.Asim,
Regarding (1), the IEA Wind 3.4-MW repository says that the model is compatible with v3.5, so, you shouldnât have to upgrade the input files to use this version.
Regarding (3), the IEA Wind Task 37 repository that you linked to contains OpenFAST models of the IEA Wind reference wind turbines. The OpenFAST r-test also contains many sample OpenFAST models including those from the original FAST CertTests and various configurations of the NREL 5-MW baseline wind turbine: r-test/glue-codes/openfast at main ¡ OpenFAST/r-test ¡ GitHub.
Iâm not an expert on the OpenFAST interface to AMR-Wind; Iâll let someone else respond regarding (2).
