Thanks for your reply Jason.
You made me question myself but I downloaded a new copy of the DC version from the website wind.nrel.gov/designcodes/preprocessors/bmodes/ to be sure. The additional supports section including draft etc. is included in the design codes website version. Line 590 onwards in bmodes.f90 are:
[code] if ( tow_support == 2 ) then
! platform data
CALL ReadVar ( UnIn, InFile, draft, 'draft', 'depth of tower base from the MSL (mean sea level) (m)' )
CALL ReadVar ( UnIn, InFile, cm_pform, 'cm_pform', 'distance of platform c.m. below the MSL (m)' )
CALL ReadVar ( UnIn, InFile, mass_pform, 'mass_pform', 'platform mass (kg)' )[/code]
Here is the header from the .out file for CS_monopile.bmi:
Results generated by BModes (v3.00.00, 20-Mar-2008, compiled using double precision) on 22-Jan-2013 at 16:17:20.
NREL 5MW Tower
and here is the echo file:
[code] T Echo - Echo input file contents to *.echo file if true
2 beam_type - beam type, 1: blade; 2: tower
0.0000E+00 rot_rpm - rotor speed (rpm)
1.0000E+00 rpm_mult - rotor speed multiplicative factor
8.7600E+01 radius - rotor tip radius or tower height above ground (m)
0.0000E+00 rroot - hub radius or tower-base height (m)
0.0000E+00 btp - precone (deg)
0.0000E+00 bl_thp - blade pitch setting (deg)
3 hub_conn - hub-to-blade connectivity identifier
20 modepr - number of modes to be printed
T TabDelim - output format (t: std; f: tab-delimited)
F mid_node_tw - t: output twist at mid nodes; f: do otherwise
3.5000E+05 tip_mass - tip mass
-4.1378E-01 cm_loc - tip-mass c.m. location wrt the reference axis
1.9670E+00 cm_axial - tip-mass c.m. axial offset wrt tip
4.3700E+07 ixx_tip - mass moment of inertia about x axis (wt-specific)
2.3530E+07 iyy_tip - mass moment of inertia about y axis
2.5420E+07 izz_tip - mass moment of inertia about z axis
0.0000E+00 ixy_tip - cross product of inertia
1.1690E+06 izx_tip - cross product of inertia
0.0000E+00 iyz_tip - cross product of inertia
1 id_mat - material isotropy identifier (not used; use later)
sec_props_file - name of beam section properties file (-)
“CS_monopile_tower_secs.dat”
Property scaling factors…
1.0000E+00 sec_mass_mult - mass density multiplier (-)
1.0000E+00 flp_iner_mult - blade flap or tower f-a inertia multiplier (-)
1.0000E+00 lag_iner_mult - blade lag or tower s-s inertia multiplier (-)
1.0000E+00 flp_stff_mult - blade flap or tower f-a bending stiffness multiplier (-)
1.0000E+00 edge_stff_mult - blade lag or tower s-s bending stiffness multiplier (-)
1.0000E+00 tor_stff_mult - torsion stiffness multiplier (-)
1.0000E+00 axial_stff_mul - axial stiffness multiplier (-)
1.0000E+00 cg_offst_mult - cg offset multiplier (-)
1.0000E+00 sc_offst_mult - shear center multiplier (-)
1.0000E+00 tc_offst_mult - tension center multiplier (-)
61 nselt - number of blade or tower elements (-)
0.0000E+00 el_loc - array of normalized element locations (-)
3.4819E-03 el_loc - array of normalized element locations (-)
1.0446E-02 el_loc - array of normalized element locations (-)
1.7409E-02 el_loc - array of normalized element locations (-)
2.4373E-02 el_loc - array of normalized element locations (-)
3.1337E-02 el_loc - array of normalized element locations (-)
3.8301E-02 el_loc - array of normalized element locations (-)
4.5265E-02 el_loc - array of normalized element locations (-)
5.2228E-02 el_loc - array of normalized element locations (-)
5.9192E-02 el_loc - array of normalized element locations (-)
6.6156E-02 el_loc - array of normalized element locations (-)
7.3120E-02 el_loc - array of normalized element locations (-)
8.0084E-02 el_loc - array of normalized element locations (-)
8.7047E-02 el_loc - array of normalized element locations (-)
9.4011E-02 el_loc - array of normalized element locations (-)
1.0097E-01 el_loc - array of normalized element locations (-)
1.0794E-01 el_loc - array of normalized element locations (-)
1.1490E-01 el_loc - array of normalized element locations (-)
1.2187E-01 el_loc - array of normalized element locations (-)
1.2883E-01 el_loc - array of normalized element locations (-)
1.3579E-01 el_loc - array of normalized element locations (-)
1.3990E-01 el_loc - array of normalized element locations (-)
1.4972E-01 el_loc - array of normalized element locations (-)
1.5669E-01 el_loc - array of normalized element locations (-)
1.6365E-01 el_loc - array of normalized element locations (-)
1.7061E-01 el_loc - array of normalized element locations (-)
1.7758E-01 el_loc - array of normalized element locations (-)
1.8454E-01 el_loc - array of normalized element locations (-)
1.9150E-01 el_loc - array of normalized element locations (-)
1.9847E-01 el_loc - array of normalized element locations (-)
2.0543E-01 el_loc - array of normalized element locations (-)
2.1240E-01 el_loc - array of normalized element locations (-)
2.1936E-01 el_loc - array of normalized element locations (-)
2.2632E-01 el_loc - array of normalized element locations (-)
2.3329E-01 el_loc - array of normalized element locations (-)
2.4025E-01 el_loc - array of normalized element locations (-)
2.4721E-01 el_loc - array of normalized element locations (-)
2.5070E-01 el_loc - array of normalized element locations (-)
3.2033E-01 el_loc - array of normalized element locations (-)
3.7971E-01 el_loc - array of normalized element locations (-)
4.2479E-01 el_loc - array of normalized element locations (-)
4.5961E-01 el_loc - array of normalized element locations (-)
4.8663E-01 el_loc - array of normalized element locations (-)
5.1366E-01 el_loc - array of normalized element locations (-)
5.4068E-01 el_loc - array of normalized element locations (-)
5.6770E-01 el_loc - array of normalized element locations (-)
5.9471E-01 el_loc - array of normalized element locations (-)
6.2173E-01 el_loc - array of normalized element locations (-)
6.4875E-01 el_loc - array of normalized element locations (-)
6.7577E-01 el_loc - array of normalized element locations (-)
7.0279E-01 el_loc - array of normalized element locations (-)
7.2981E-01 el_loc - array of normalized element locations (-)
7.5683E-01 el_loc - array of normalized element locations (-)
7.8385E-01 el_loc - array of normalized element locations (-)
8.1087E-01 el_loc - array of normalized element locations (-)
8.3789E-01 el_loc - array of normalized element locations (-)
8.6491E-01 el_loc - array of normalized element locations (-)
8.9192E-01 el_loc - array of normalized element locations (-)
9.1894E-01 el_loc - array of normalized element locations (-)
9.4596E-01 el_loc - array of normalized element locations (-)
9.7298E-01 el_loc - array of normalized element locations (-)
1.0000E+00 el_loc - array of normalized element locations (-)
--------- Properties of tower support subsystem (read only if beam_type is 2) ------------
2 tow_support - aditional tower support (-)
2.0000E+01 draft - depth of tower base from the MSL (mean sea level) (m)
0.0000E+00 cm_pform - distance of platform c.m. below the MSL (m)
0.0000E+00 mass_pform - platform mass (kg)
Platform mass inertia 3X3 matrix (i_matrix_pform):
0.0000E+00 i_matrix_pform - platform inertia matrix-row1
0.0000E+00 i_matrix_pform - platform inertia matrix-row2
0.0000E+00 i_matrix_pform - platform inertia matrix-row3
2.0000E+01 ref_msl - distance of platform reference point below the MSL (m)
Platform-reference-point-referred hydrodynamic 6X6 matrix (hydro_M):
0.0000E+00 hydro_M - platform added-mass inertia matrix
Platform-reference-point-referred hydrodynamic 6X6 stiffness matrix (hydro_K):
0.0000E+00 hydro_K - platform hydrodynamic stiffness matrix
Mooring-system 6X6 stiffness matrix (mooring_K):
2.5748E+09 mooring_K - platform mooring-system stiffness matrix
0.0000E+00 mooring_K - platform mooring-system stiffness matrix
-2.2532E+10 mooring_K - platform mooring-system stiffness matrix
2.6291E+11 mooring_K - platform mooring-system stiffness matrix
Distributed (hydrodynamic) added-mass per unit length along a flexible portion of the tower length:
0 n_secs_m_distr - number of points at which added mass per unit length is specified (-)
Distributed elastic stiffness per unit length along a flexible portion of the tower length:
0 n_secs_k_distr - number of points at which distributed stiffness per unit length is specified (-)
Tower section properties
13 n_secs - number of blade or tower sections (-)
sec_loc str_tw tw_iner mass_den flp_iner edge_iner flp_stff edge_stff tor_stff axial_stff cg_offst sc_offst tc_offst
(-) (deg) (deg) (kg/m) (kg-m) (kg-m) (Nm^2) (Nm^2) (Nm^2) (N) (m) (m) (m)
0.00000 0.000 0.000 9517.140 41979.200 41979.200 1.04E+12 1.04E+12 7.98E+11 2.35E+11 0.000 0.000 0.000
0.27881 0.000 0.000 9517.140 41979.200 41979.200 1.04E+12 1.04E+12 7.98E+11 2.35E+11 0.000 0.000 0.000
0.27882 0.000 0.000 4306.510 19205.600 19205.600 4.74E+11 4.74E+11 3.65E+11 1.06E+11 0.000 0.000 0.000
0.35094 0.000 0.000 4030.440 16720.000 16720.000 4.13E+11 4.13E+11 3.18E+11 9.96E+10 0.000 0.000 0.000
0.42306 0.000 0.000 3763.450 14483.400 14483.400 3.58E+11 3.58E+11 2.75E+11 9.30E+10 0.000 0.000 0.000
0.49517 0.000 0.000 3505.520 12478.700 12478.700 3.08E+11 3.08E+11 2.37E+11 8.66E+10 0.000 0.000 0.000
0.56729 0.000 0.000 3256.660 10689.200 10689.200 2.64E+11 2.64E+11 2.03E+11 8.05E+10 0.000 0.000 0.000
0.63941 0.000 0.000 3016.860 9098.900 9098.900 2.25E+11 2.25E+11 1.73E+11 7.45E+10 0.000 0.000 0.000
0.71153 0.000 0.000 2786.130 7692.700 7692.700 1.90E+11 1.90E+11 1.46E+11 6.88E+10 0.000 0.000 0.000
0.78365 0.000 0.000 2564.460 6455.700 6455.700 1.59E+11 1.59E+11 1.23E+11 6.34E+10 0.000 0.000 0.000
0.85576 0.000 0.000 2351.870 5373.900 5373.900 1.33E+11 1.33E+11 1.02E+11 5.81E+10 0.000 0.000 0.000
0.92788 0.000 0.000 2148.340 4433.600 4433.600 1.10E+11 1.10E+11 8.43E+10 5.31E+10 0.000 0.000 0.000
1.00000 0.000 0.000 1953.870 3622.100 3622.100 8.95E+10 8.95E+10 6.89E+10 4.83E+10 0.000 0.000 0.000
[/code]
All the best,
Rebecca
