Dear Jason
Thank you very much for your quick reply! It definitely gives me some hints of the modeling.
I am not very familiar with the Blade Property Extractor (BPE) post-processing tool, so it may take me some time to learn it before I can derive equivalent beam properties from 3D ANSYS model.
I do carry out the analysis to check how sensitive the blade natural frequencies of the NREL 5-MW baseline turbine are to the structural pretwist. As mentioned in post NREL 5MW Blade Mode Shape - #5 by Paul.Feja, I set very small number for flp_iner & edge_iner, and very high number for tor_stff & axial_stff. I have tested three senarios, str_tw=0, str_tw=13.308 and str_tw=StrcTwst in Table 2-1. The results are summarized as below:
I am not able to find the reference value for BModes analysis results, but I compare the results with several previous posts like NREL 5MW Blade Eigenfrequencies with Bmodes - #2 by Ivano.Quarta. Seems we have got similar results. The 1st flapwise bending frequency is around 0.69Hz. This value also matches the full system frequencies in Table 9-1. However, as can be seen from the table above, the results obatined when considering the structural pretwist are still quite different from the reference values provided by Sandia report (Table 15) prod-ng.sandia.gov/techlib-noau … 132569.pdf. In my understanding, both the 3D ANSYS model in Sandia report and the BModes model consider the structural pretwist, and the boundary conditions are same (both cantilever), similar results are expected. The differences are around 20% bewtween the two models. I am now quite confusing about these results. I wonder if there are anything wrong in my understanding or calculation? I would be appreciate it if you could shed some light on this.
Zimo
[code]====================== BModes v1.03 Main Input File ==================
Sample non-uniform blade (output is space-delimited)
--------- General parameters ---------------------------------------------------------------------
False Echo Echo input file contents to *.echo file if true.
1 beam_type 1: blade, 2: tower (-)
0. romg: rotor speed, automatically set to zero for tower modal analysis (rpm)
1.0 romg_mult: rotor speed muliplicative factor (-)
63.0 radius: rotor tip radius measured along coned blade axis OR tower height (m)
1.5 hub_rad: hub radius measured along coned blade axis OR tower rigid-base height (m)
2.5 precone: built-in precone angle, automatically set to zero for a tower (deg)
0. bl_thp: blade pitch setting, automatically set to zero for a tower (deg)
1 hub_conn: hub-to-blade connection [1: cantilevered; other options not yet available] (-)
20 modepr: number of modes to be printed (-)
f TabDelim (true: tab-delimited output tables; false: space-delimited tables)
t mid_node_tw (true: output twist at mid-node of elements; false: no mid-node outputs)
0. tip_mass blade-tip or tower-top mass (kg)
0. cm_loc tip-mass c.m. offset from the blade axis measured along the tip section y reference axis (m)
0. ixx_tip blade lag mass moment of inertia about the tip-section x reference axis (kg-m^2)
0. iyy_tip blade flap mass moment of inertia about the tip-section y reference axis (kg-m^2)
0. izz_tip torsion mass moment of inertia about the tip-section z reference axis (kg-m^2)
0. ixy_tip cross product of inertia about x and y reference axes(kg-m^2)
0. izx_tip cross product of inertia about z and x reference axes(kg-m^2)
0. iyz_tip cross product of inertia about y and z reference axes(kg-m^2)
1 id_mat: material_type [1: isotropic; non-isotropic composites option not yet available]
‘test03_blade_sec_props.dat’ sec_props_file name of beam section properties file (-)
Property scaling factors…
1.04536 sec_mass_mult: mass density multiplier (-)
1.0 flp_iner_mult: blade flap or tower f-a inertia multiplier (-)
1.0 lag_iner_mult: blade lag or tower s-s inertia multiplier (-)
1.0 flp_stff_mult: blade flap or tower f-a bending stiffness multiplier (-)
1.0 edge_stff_mult: blade lag or tower s-s bending stiffness multiplier (-)
1.0 tor_stff_mult: torsion stiffness multiplier (-)
1.0 axial_stff_mult: axial stiffness multiplier (-)
1.0 cg_offst_mult: cg offset multiplier (-)
1.0 sc_offst_mult: shear center multiplier (-)
1.0 tc_offst_mult: tension center multiplier (-)
48 nselt: no of blade or tower elements (-)
0 0.00325 0.01951 0.03577 0.05203 0.06829 0.08455 0.10081 0.11707 0.13335 0.14959 0.16585 0.18211 0.19837 0.21465 0.23089 0.24715 0.26341 0.29595
0.32846 0.36098 0.3935 0.42602 0.45855 0.49106 0.52358 0.5561 0.58862 0.62115 0.65366 0.68618 0.7187 0.75122 0.78376 0.81626 0.84878 0.8813
0.89756 0.91382 0.93008 0.93821 0.94636 0.95447 0.9626 0.97073 0.97886 0.98699 0.99512 1
--------- Properties of tension wires suporting the tower --------------------------------
0 n_attachments: no of wire-attachment locations on tower, maxm allowable is 2; 0: no tension-wire support (-)
3 3 n_wires: no of wires attached at each location (must be 3 or higher) (-)
6 9 node_attach: node numbers of attacments location (node number must be more than 1 and less than nselt+2) (-)
0.e0 0.e0 wire_stfness: wire spring constant in each set (see users’ manual) (N/m)
0. 0. th_wire: angle of tension wires wrt the tower axis at each attachment point (deg)
[/code]
[code]Blade section properties
49 n_secs: number of blade sections at which properties are specified (-)
sec_loc str_tw tw_iner mass_den flp_iner edge_iner flp_stff edge_stff tor_stff axial_stff cg_offst sc_offst tc_offst
(-) (deg) (deg) (kg/m) (kg-m) (kg-m) (Nm^2) (Nm^2) (Nm^2) (N) (m) (m) (m)
0.00000 13.308 13.308 678.94 1.39402795E-17 1.39454166E-17 1.811000E+10 1.811360E+10 5.56440000E+29 1.394285E+30 0.0 0.0 0.0
0.00325 13.308 13.308 678.94 1.39402795E-17 1.39454166E-17 1.811000E+10 1.811360E+10 5.56440000E+29 1.394285E+30 0.0 0.0 0.0
0.01951 13.308 13.308 773.36 1.54056463E-17 1.47041778E-17 1.942490E+10 1.955860E+10 5.43159000E+29 1.505491E+30 0.0 0.0 0.0
0.03577 13.308 13.308 740.55 1.26030747E-17 1.48128106E-17 1.745590E+10 1.949780E+10 4.99398000E+29 1.370794E+30 0.0 0.0 0.0
0.05203 13.308 13.308 740.04 1.03174827E-17 1.63429855E-17 1.528740E+10 1.978880E+10 4.66659000E+29 1.333023E+30 0.0 0.0 0.0
0.06829 13.308 13.308 592.50 7.09915447E-18 1.28635531E-17 1.078240E+10 1.485850E+10 3.47471000E+29 9.981354E+29 0.0 0.0 0.0
0.08455 13.308 13.308 450.28 4.63334462E-18 9.13918803E-18 7.229720E+09 1.022060E+10 2.32354000E+29 6.886266E+29 0.0 0.0 0.0
0.10081 13.308 13.308 424.05 3.78312628E-18 8.31293078E-18 6.309540E+09 9.144700E+09 1.90787000E+29 6.048029E+29 0.0 0.0 0.0
0.11707 13.308 13.308 400.64 3.08588692E-18 7.47312401E-18 5.528360E+09 8.063160E+09 1.57036000E+29 5.279505E+29 0.0 0.0 0.0
0.13335 13.308 13.308 382.06 2.61556115E-18 6.30591497E-18 4.980060E+09 6.884440E+09 1.15826000E+29 4.460738E+29 0.0 0.0 0.0
0.14959 13.308 13.308 399.66 2.30631196E-18 6.35229712E-18 4.936840E+09 7.009180E+09 1.00212000E+29 4.329305E+29 0.0 0.0 0.0
0.16585 13.308 13.308 426.32 1.96237798E-18 6.95957884E-18 4.691660E+09 7.167680E+09 8.55899000E+28 4.460978E+29 0.0 0.0 0.0
0.18211 13.181 13.181 416.82 1.45862352E-18 7.79188452E-18 3.949460E+09 7.271660E+09 6.72268000E+28 4.625254E+29 0.0 0.0 0.0
0.19837 12.848 12.848 406.19 1.14769873E-18 8.90082570E-18 3.386520E+09 7.081700E+09 5.47485000E+28 5.024262E+29 0.0 0.0 0.0
0.21465 12.192 12.192 381.42 9.17898818E-19 7.83188211E-18 2.933740E+09 6.244530E+09 4.48844000E+28 4.374890E+29 0.0 0.0 0.0
0.23089 11.561 11.561 352.82 7.33254659E-19 6.22654873E-18 2.568960E+09 5.048960E+09 3.35918000E+28 3.479902E+29 0.0 0.0 0.0
0.24715 11.072 11.072 349.48 6.31492382E-19 5.89160478E-18 2.388650E+09 4.948490E+09 3.11345000E+28 3.261549E+29 0.0 0.0 0.0
0.26341 10.792 10.792 346.54 5.68060945E-19 5.49111062E-18 2.271990E+09 4.808020E+09 2.91939000E+28 3.029586E+29 0.0 0.0 0.0
0.29595 10.232 10.232 339.33 4.57599820E-19 4.67238898E-18 2.050050E+09 4.501400E+09 2.60995000E+28 2.564994E+29 0.0 0.0 0.0
0.32846 9.672 9.672 330.00 3.62773543E-19 3.97273878E-18 1.828250E+09 4.244070E+09 2.28820000E+28 2.167756E+29 0.0 0.0 0.0
0.36098 9.110 9.110 321.99 2.76513885E-19 3.48562482E-18 1.588710E+09 3.995280E+09 2.00750000E+28 1.881069E+29 0.0 0.0 0.0
0.39350 8.534 8.534 313.82 2.05186540E-19 3.03415442E-18 1.361930E+09 3.750760E+09 1.74378000E+28 1.619670E+29 0.0 0.0 0.0
0.42602 7.932 7.932 294.73 1.33275021E-19 2.36229130E-18 1.102380E+09 3.447140E+09 1.44469000E+28 1.247783E+29 0.0 0.0 0.0
0.45855 7.321 7.321 287.12 8.50710178E-20 1.95722944E-18 8.758000E+08 3.139070E+09 1.19982000E+28 1.021150E+29 0.0 0.0 0.0
0.49106 6.711 6.711 263.34 5.29502622E-20 1.46490556E-18 6.813000E+08 2.734240E+09 8.11924000E+27 7.589279E+28 0.0 0.0 0.0
0.52358 6.122 6.122 253.21 3.35460545E-20 1.28443992E-18 5.347200E+08 2.554870E+09 6.90910000E+27 6.589930E+28 0.0 0.0 0.0
0.55610 5.546 5.546 241.67 2.03280769E-20 1.09167905E-18 4.089000E+08 2.334030E+09 5.74541000E+27 5.560036E+28 0.0 0.0 0.0
0.58862 4.971 4.971 220.64 1.36170572E-20 8.23933360E-19 3.145400E+08 1.828730E+09 4.59151000E+27 4.187752E+28 0.0 0.0 0.0
0.62115 4.401 4.401 200.29 8.83615884E-21 6.75317642E-19 2.386300E+08 1.584100E+09 3.59767000E+27 3.420769E+28 0.0 0.0 0.0
0.65366 3.834 3.834 179.40 5.53226673E-21 5.35084781E-19 1.758800E+08 1.323360E+09 2.74412000E+27 2.703085E+28 0.0 0.0 0.0
0.68618 3.332 3.332 165.09 3.23001429E-21 5.92782253E-19 1.260100E+08 1.183680E+09 2.09031000E+27 2.980061E+28 0.0 0.0 0.0
0.71870 2.890 2.890 154.41 2.50478757E-21 4.76571060E-19 1.072600E+08 1.020160E+09 1.85425000E+27 2.395379E+28 0.0 0.0 0.0
0.75122 2.503 2.503 138.94 1.93547705E-21 3.52327780E-19 9.088000E+07 7.978100E+08 1.62761000E+27 1.771316E+28 0.0 0.0 0.0
0.78376 2.116 2.116 129.56 1.46951003E-21 2.91133034E-19 7.631000E+07 7.096100E+08 1.45346000E+27 1.463013E+28 0.0 0.0 0.0
0.81626 1.730 1.730 107.26 1.05502194E-21 1.92533969E-19 6.105000E+07 5.181900E+08 9.07286000E+26 9.679450E+27 0.0 0.0 0.0
0.84878 1.342 1.342 98.78 7.65632246E-22 1.58521299E-19 4.948000E+07 4.548700E+08 8.05730000E+26 7.964347E+27 0.0 0.0 0.0
0.88130 0.954 0.954 90.25 5.42684525E-22 1.28783642E-19 3.936000E+07 3.951200E+08 7.07829000E+26 6.466316E+27 0.0 0.0 0.0
0.89756 0.760 0.760 83.00 4.50412928E-22 1.09274324E-19 3.467000E+07 3.537200E+08 6.09268000E+26 5.486237E+27 0.0 0.0 0.0
0.91382 0.574 0.574 72.91 3.94069136E-22 5.56944169E-20 3.041000E+07 3.047300E+08 5.75387000E+26 2.804424E+27 0.0 0.0 0.0
0.93008 0.404 0.404 68.77 3.22735664E-22 4.99038450E-20 2.652000E+07 2.814200E+08 5.33059000E+26 2.511329E+27 0.0 0.0 0.0
0.93821 0.319 0.319 66.26 2.71616888E-22 4.41651551E-20 2.384000E+07 2.617100E+08 4.93516000E+26 2.221839E+27 0.0 0.0 0.0
0.94636 0.253 0.253 59.34 2.04409601E-22 2.24633634E-20 1.963000E+07 1.588100E+08 4.23806000E+26 1.133389E+27 0.0 0.0 0.0
0.95447 0.216 0.216 55.91 1.42995713E-22 1.70703516E-20 1.600000E+07 1.378800E+08 3.65886000E+26 8.606674E+26 0.0 0.0 0.0
0.96260 0.178 0.178 52.48 9.70456723E-23 1.27896814E-20 1.283000E+07 1.187900E+08 3.12686000E+26 6.443364E+26 0.0 0.0 0.0
0.97073 0.140 0.140 49.11 6.36489939E-23 9.47217935E-21 1.008000E+07 1.016300E+08 2.64323000E+26 4.767914E+26 0.0 0.0 0.0
0.97886 0.101 0.101 45.82 3.80421843E-23 6.76168197E-21 7.550000E+06 8.507000E+07 2.17187000E+26 3.399862E+26 0.0 0.0 0.0
0.98699 0.062 0.062 41.67 1.53378029E-23 3.85801509E-21 4.600000E+06 6.426000E+07 1.58095000E+26 1.936676E+26 0.0 0.0 0.0
0.99512 0.023 0.023 11.45 1.07587362E-24 7.64479204E-22 2.500000E+05 6.610000E+06 2.53690000E+25 3.827775E+25 0.0 0.0 0.0
1.00000 0.000 0.000 10.32 5.48167599E-25 4.50813826E-22 1.700000E+05 5.010000E+06 1.86546400E+25 2.256810E+25 0.0 0.0 0.0
**Note: If the above data represents TOWER properties, the following are overwritten:
str_tw is set to zero
tw_iner is set to zero
cg_offst is set to zero
sc_offst is set to zero
tc_offst is set to zero
edge_iner is set equal to flp_iner
edge_stff is set equal to flp_stff
[/code]
