Static Pushover Analysis
Sir,
In FAST, Is it possible to conduct Static pushover analysis to check the nonlinear behavior of monopile supported offshore wind turbine? I want to check the linear & nonlinear deformation at the tower top.
Thank you.
Dear Dhaneesh,
Not directly, but I’m sure this would be possible with a small change to the source code, e.g, by introducing a slowly increasing force applied to the tower top.
