Is there an analytical relationship between the integral gain on the fore-aft damper and the damping of the fore-aft mode in the ROSCO controller? I’m trying to reduce tower-fatigue.
Best wishes,
Sam
Best wishes,
Sam
Hi Sam,
Ervin Bossanyi (amongst others) has proposed a simple analytical relationship:
https://onlinelibrary.wiley.com/doi/abs/10.1002/we.95
For the tower fore-aft damping control, the FA_KI
term is multiplied times a high-pass filtered integrated tower-top fore-aft signal and added to the standard collective pitch command.
Additionally, you could use the “floating feedback” terms to achieve a similar goal. The only difference between the two is the filter for the feedback signals. The tower-top motion signal that Fl_Kp
is multiplied by is low-pass filtered by the filter defined by Fl_CornerFreq
and is notch filtered by the filter defined by the notch-filter parameters.
Best,
Nikhar
Hi Nikhar,
Thanks very much, think I’ve got it working now.
Best,
Sam
