Dear Dr. Jonkman,
I try to calculate the moments of inertia for the RNA of an onshore reference turbine (130-3.4MW, see nrel.gov/docs/fy19osti/73492.pdf). Therfore, I followed the steps described in post http://forums.nrel.gov/t/ansys-model-tower/1722/4. I converted the input files of the WT to the FASTv7-Format.
I created the following files:
130_lin.fst
130_AD.ipt
Blade_NoDamp.dat
Tower_NoDamp.dat
Platform.dat
Linear_130.dat (Control)
When I run the .fst-file I get an AeroDyn error:
I checked the AD.ipt-file but I cannot find the problem.
3.4 MW onshore reference turbine aerodynamic parameters.
SI SysUnits - System of units for used for input and output [must be SI for FAST] (unquoted string)
STEADY StallMod - Dynamic stall included [BEDDOES or STEADY] (unquoted string)
NO_CM UseCm - Use aerodynamic pitching moment model? [USE_CM or NO_CM] (unquoted string)
EQUIL InfModel - Inflow model [DYNIN or EQUIL] (unquoted string)
SWIRL IndModel - Induction-factor model [NONE or WAKE or SWIRL] (unquoted string)
1.0E-6 AToler - Induction-factor tolerance (convergence criteria) (-)
PRANDtl TLModel - Tip-loss model (EQUIL only) [PRANDtl, GTECH, or NONE] (unquoted string)
PRANDtl HLModel - Hub-loss model (EQUIL only) [PRANdtl or NONE] (unquoted string)
"12ms.wnd" WindFile - Name of file containing wind data (quoted string)
220.436 HH - Wind reference (hub) height [TowerHt+Twr2Shft+OverHang*SIN(ShftTilt)] (m)
0.0 TwrShad - Tower-shadow velocity deficit (-)
9999.9 ShadHWid - Tower-shadow half width (m)
9999.9 T_Shad_Refpt - Tower-shadow reference point (m)
1.4639E-5 KinVisc - Kinematic air viscosity (m^2/sec)
0.005 DTAero - Time interval for aerodynamic calculations (sec)
30 NumFoil - Number of airfoil files (-)
"Airfoils/Cylinder1.dat" FoilNm - Names of the airfoil files [NumFoil lines] (quoted strings)
"Airfoils/DU21_A17.dat"
"Airfoils/DU35_A17.dat"
"Airfoils/DU40_A17.dat"
29 BldNodes - Number of blade nodes used for analysis (-)
RNodes AeroTwst DRNodes Chord NFoil PrnElm
0.63000 19.86 1.26000 2.600 1 NOPRINT
2.52000 19.16 2.52000 2.740 2 NOPRINT
5.04000 17.77 2.52000 3.090 2 NOPRINT
7.47000 15.98 2.34000 3.490 2 NOPRINT
9.81000 14.02 2.35000 3.880 2 NOPRINT
12.17000 12.02 2.35000 4.180 2 NOPRINT
14.47000 10.19 2.25000 4.290 2 NOPRINT
16.71000 8.54 2.25000 4.250 2 NOPRINT
18.96000 6.91 2.25000 4.150 2 NOPRINT
21.16000 5.36 2.15000 4.010 2 NOPRINT
23.31000 4.08 2.15000 3.860 2 NOPRINT
25.46000 3.15 2.15000 3.690 2 NOPRINT
27.61000 2.50 2.15000 3.460 2 NOPRINT
29.76000 1.98 2.15000 3.200 2 NOPRINT
31.91000 1.54 2.15000 2.940 3 NOPRINT
33.96000 1.18 1.95000 2.760 3 NOPRINT
35.91000 0.87 1.95000 2.590 3 NOPRINT
37.85000 0.61 1.95000 2.430 3 NOPRINT
39.80000 0.37 1.95000 2.290 3 NOPRINT
41.75000 0.15 1.95000 2.170 3 NOPRINT
43.68000 -0.07 1.92000 2.090 3 NOPRINT
45.60000 -0.28 1.92000 2.030 3 NOPRINT
47.52000 -0.46 1.92000 1.990 3 NOPRINT
49.44000 -0.64 1.92000 1.950 3 NOPRINT
51.42000 -0.86 2.03000 1.890 3 NOPRINT
53.45000 -1.17 2.03000 1.770 4 NOPRINT
55.48000 -1.62 2.03000 1.540 4 NOPRINT
57.86000 -2.40 2.73000 1.060 4 NOPRINT
61.11000 -3.77 3.78000 0.200 4 NOPRINT
Regarding the error message, I am not sure what is meant by “AeroDyn element table”. I assume it is the table at the end of the file? I hope my desription is sufficient to comprehend the problem.
Thank you very much in advance!
