Dear everyone,
I am currently using BeamDyn for simulating the behavior of a 5MW wind turbine blade and have encountered some unexpected results.
In my simulation, I applied a tip load of 100N while setting gravitational acceleration to zero and ensuring a damping-free condition. Under these conditions, I expected the blade tip deformation to exhibit smooth, regular oscillations around an equilibrium position, similar to the steady-state deformation results obtained with OpenFAST under uniform inflow conditions. However, the results from BeamDyn appear unusual and do not match this expected behavior.
I have attached the BeamDyn results and the case setup for your reference. Could you please help me understand why these discrepancies might be occurring? Any insights or suggestions would be greatly appreciated.
The following shows the deformation in the x-direction at the blade tip.
Here is my case setup.
------- BEAMDYN V1.00.00 Driver INPUT FILE -------------------------------------
Dynamic analysis of rotating NREL 5MW blade under gravity force
0 t_initial - Starting time of simulation (s)
20.0 t_final - Ending time of simulation (s)
0.001 dt - Time increment size (s)
---------------------- GRAVITY PARAMETER --------------------------------------
0.0 Gx - Component of gravity vector along X direction (m/s^2)
0.0 Gy - Component of gravity vector along Y direction (m/s^2)
0.0 Gz - Component of gravity vector along Z direction (m/s^2)
---------------------- FRAME PARAMETER --------------------------------------
0.0 GlbPos(1) - Component of position vector of the reference blade frame along X direction (m)
0.0 GlbPos(2) - Component of position vector of the reference blade frame along Y direction (m)
1.0 GlbPos(3) - Component of position vector of the reference blade frame along Z direction (m)
—The following 3 by 3 matrix is the direction cosine matirx ,GlbDCM(3,3),
—relates global frame to reference blade frame
1.000E+00 0.000E+00 0.000E+00
0.000E+00 1.000E+00 0.000E+00
0.000E+00 0.000E+00 1.000E+00
---------------------- ROOT VELOCITY PARAMETER ----------------------------------
0.0 RootVel(4) - Component of angular velocity vector of the beam root about X axis (rad/s)
0.0 RootVel(5) - Component of angular velocity vector of the beam root about Y axis (rad/s)
0.0 RootVel(6) - Component of angular velocity vector of the beam root about Z axis (rad/s)
---------------------- APPLIED FORCE ----------------------------------
0.0 DistrLoad(1) - Component of distributed force vector along X direction (N/m)
0.0 DistrLoad(2) - Component of distributed force vector along Y direction (N/m)
0.0 DistrLoad(3) - Component of distributed force vector along Z direction (N/m)
0.0 DistrLoad(4) - Component of distributed moment vector along X direction (N-m/m)
0.0 DistrLoad(5) - Component of distributed moment vector along Y direction (N-m/m)
0.0 DistrLoad(6) - Component of distributed moment vector along Z direction (N-m/m)
100.0 TipLoad(1) - Component of concentrated force vector at blade tip along X direction (N)
0.0 TipLoad(2) - Component of concentrated force vector at blade tip along Y direction (N)
0.0 TipLoad(3) - Component of concentrated force vector at blade tip along Z direction (N)
0.0 TipLoad(4) - Component of concentrated moment vector at blade tip along X direction (N-m)
0.0 TipLoad(5) - Component of concentrated moment vector at blade tip along Y direction (N-m)
0.0 TipLoad(6) - Component of concentrated moment vector at blade tip along Z direction (N-m)
---------------------- PRIMARY INPUT FILE --------------------------------------
“Dynamic_BeamDyn_Input_5MW.inp” InputFile - Name of the primary input file
------- BEAMDYN V1.00.* INDIVIDUAL BLADE INPUT FILE --------------------------
NREL5MW Blade
---------------------- BLADE PARAMETERS --------------------------------------
49 station_total - Number of blade input stations (-)
0 damp_type - Damping type (switch): 0: no damping; 1: viscous damping
---------------------- DAMPING COEFFICIENT------------------------------------
mu1 mu2 mu3 mu4 mu5 mu6
(s) (s) (s) (s) (s) (s)
1.0e-3 1.0e-3 1.0e-3 1.0e-3 1.0e-3 1.0e-3
--------- BEAMDYN V1.01.* INPUT FILE -------------------------------------------
NREL 5MW blade primary input file
2 analysis_type - 1: Static analysis; 2: Dynamic analysis (switch)
0.0 rhoinf - Numerical Damping Parameter for Generalized-alpha integrator
2 quadrature - 1: Gauss; 2: Trapezoidal (switch)
DEFAULT refine - Refinement factor for quadrature 2 (-). DEFAULT = 1
DEFAULT n_fact - Factorization frequency (-). DEFAULT = 5
DEFAULT DTBeam - Time step size (s).
DEFAULT NRMax - Max number of iterations in Newton-Ralphson algorithm (-). DEFAULT = 10
DEFAULT stop_tol - Tolerance for stopping criterion (-)
Thank you for your time and assistance.
