Dear Cheng,
The MBC3 software will apply the necessary transformations directly. If you have states and outputs in the rotating frame, you should use MBC_AvgB and MBC_AvgD rather than AvgBMat and AvgDMat.
Dear Cheng,
Then, BldPitch1 shoud = BldPitch2 = BldPitch3 = input. but the result shows that input = BldPitch1. BldPitch2 and BldPitch3 are almost 0.
I don’t know the reason…
Cheng
Dear Cheng,
It sounds like you’ve applied the MBC transform so that while the linear model generated by FAST has individual outputs BldPitch1, BldPitch2, and BldPitch3, once you apply the MBC transform, these outputs are transformed to BldPitch_collective, Bld_Pitch_cosine, and Bld_Pitch_sine. So, the response you are getting is expected.
Yes, you are right, I applied MBC transform.
So the MBC just transfer the 3 blade pitch angles outputs to BldPitch_collective, Bld_Pitch_cosine, and Bld_Pitch_sine. It does not affect the input. That is to say, the linear model I got from FAST is right? Even the output blade pitch angles are different, I still can use CBP as an input?
Actually, I compare the two linear model, one is applied MBC3 and another is not. I got the almost same output from these two models, it’s strange.
furthermore, I also compare these two models’ outputs with the FAST model (In FAST, I used the inverse MBC transform to the rotating output), both the two linear models’ outputs are coincident with FAST nonlinear model.
It surprised me. I don’t know which model I should use…
Cheng
Dear Cheng,
Correct.
I’m not sure I know enough about the details to comment.
I want to use mlife to calculate the Damage Equivalent Load (DEL) as a performance index for my controller, and I read the topic concerning the Mlife and the Mlife_user, but I still don’t understand how to calculate it.
For example.
If I want to calculate the DEL of blade flap-wise bending (RootMxb1) and tower fore-aft bending (TwrBsMyt).
How can I choose the parameters of NSlopes, SNslopeLst, BinFlag, BinWidth/Number, TypeLMF, LUlt.
I read a paper that you are a co-author [url]AIAA Aerospace Research Central. In this paper, you also use DEL as a performance index (e.g. ‘Flap DEQL’, ‘Tower FA DEQL’, ‘Tower SS DEQL’, ‘LSS DEQL’). Could you tell me how to calculate the DEL of those item?
Thank you!
Cheng
Dear Cheng,
SNslopeLst is the slope of the SN curve. If not known for the specific components you are analyzing, it is often appropriate to assume the slope is 3, 4, or 5 for steel structures or 8, 10, or 12 for composite structures (you can choose one or use all three to assess the sensitivity). You can check the sensitivity of the binning based on your own results. TypeLMF and LUlt are discussed in our FAQ (nwtc.nrel.gov/FAQ#TypeLMF), but are unused if you are not using the Goodman correction to account for the influence of the load means on the DELs.
Dear Jason
Here, “Aero twist = pitch angle + twist angle”, I believe twist angle meant structural twist. But is the Pitch angle same as “The blade-pitch angle is the angle (about minus z) from the hub to the blade coordinate system and is constant along the blade.”? (Defined by you in topic: Definition of parameters)
By the definition, Pitch angle must be the angle between local elastic axis and the chord. Am I correct?
In the document “Definition of a 5-MW Reference Wind Turbine for Offshore System Development” Aero twist and structural twist are assumed to be identical so that the pitch angle will be zero along the blade. So if I use this data can I ignore pitch angle in my calculations? or Can you please provide different values of Aero and Structural twist?
But Dear Jason in the book “http://www.innwind.eu/-/media/Sites/innwind/Publications/Deliverables/DeliverableD1-21ReferenceWindTurbinereport_INNWIND-EU.ashx?la=da&hash=14D9E77225A5F451D153082579B808E7C9E4C75C” in the section 4.1.3 third paragraph, the definition of structural twist angle is mentioned as the angle between principal elastic axis and chord. I am baffled. Please help me go through this.
Thanks in advance.
Dear Kamineni,
I’ve defined the structural twist, aerodynamic twist, and blade-pitch angle in the forum topic you quoted. I’m not sure how to define these any clearer.
I don’t agree with your statement “Aero twist = pitch angle + twist angle” or your conclusion that pitch is zero. Instead, I would say that the angle (about minus z) from the rotor plane to the chord equals pitch + aerodynamic twist. Likewise, I would say that the angle (about minus z) from the rotor plane to the principle axis equals pitch + structural twist.
DTU uses the same definition I use, except that DTU defines the twist and pitch angles about positive z (so, you must flip the sign for use in FAST).
Dear Dr. Jonkman
I’m working on LPV modeling of NREL 5 MW wind Turbine. I started with a simple 2 DOF model(Generator,Drive Train). For evaluation of FAST v8 linear models I used a uniform wind speed with small wind speed step change but linear and nonlinear models don’t comply. I have read all your hints on forum like NLin>=18, TLin=500, and considering one complete revolution.
I checked this problem with FAST v7 and something that made me more confused is that the operating point for this 2 DOF model in FAST v8 is:
wr=12.1 Betta=15.85052 wind=18
But, in FAST v7 for this 2 DOF model I have:
wr=12.1 Betta=14.75951 wind=18
Do you have any idea about the point where this difference stems from?
Dear Behnam,
Yes, I can’t comment on your specific results, but I would expect some small differences in the steady-state pitch angle associated with a given mean wind speed and rotor speed between FAST v8 and FAST v7 due to differences in the BEM solution between AeroDyn v15 in FAST v8 and AeroDyn v13 in FAST v7.
FYI: We’ve been working with Envision Energy recently to introduce a steady-state (with controller trim) solution in OpenFAST. While we haven’t yet released this capability, it will be very useful for calculating pertinent operating points (including controller trim) before linearization.
Dear Dr. Jonkman
Thanks for your response
I think 1 degree difference for blade pitch angle is remarkable.
In FAST V8, I calculated the operating points by means of baseline controller. I mean by choosing a steady wind, I ran the model with baseline and after 500 seconds all the states were in equilibrium(for 2 dof) model. Then I set the initial conditions for pitch angle equal to the calculated ones from previous run and started the linearization. But, linear models dc gains in comparison with nonlinear model for 0.5 m/s wind speed step change around a operating point is very smal. I mean generator speed change in FAST is four times the linear model output. I checked outputs during linearization and everything was ok at the time of linearization. Is there any required setting in input files before linearization?
I’m working on Spar Buoy Platform.
Dear Behnam,
In general, I would expect the linear and nonlinear system should have similar behavior for small perturbations about the operating point for models that are set up the same. I don’t see any problem with the approach from your overview, but the devil is in the details.
I would recommend upgrading to OpenFAST because there have been several issues with AeroDyn that have been fixed between FAST v8 and OpenFAST v2.
Dear Dr. Jason,
I made several kinds of sliding mode controllers of floating wind turbines with OC3 spar-buoy platform, and I calculated the DEL (TwrBsMxt, TwrBsMyt, TwrBsMzt, RootMxb1, RootMyb1) by using Mlife.
However, the DEL results of different controllers are similar.
For example, I compared the DEL of GSPI and ASTW (the controllers I designed), see the figure , you can find the normalized RMS and DEL of different performance index, as I said, the DEL of the two controllers are very close, it seems unreasonable.
I’m not sure whether the DEL results I got are correct, and I can’t find anyone who can help me with that. So could you help check the .mlif file? Also, you can find the results I got in the Excel file, is it reasonable?
I very appreciate for your help!
Cheng
[code]----- MLife version 1.0 Input File -------------------------------------------
Test #02 Testing %12.4e formatting, NamesLIne=0, NumChans>0, WrDELsXLS=true
----- Job Options ------------------------------------------------------------
true EchoInp Echo input to .echo as this file is being read.
false StrNames Use channel names following a “$” instead of numbers when specifying channels in this input file.
false OutData Output modified data array after scaling and calculated channels. (currently unavailable)
“%12.4e” RealFmt Format for outputting floating-point values.
“PI_SIM_18p15” AggRoot Root name for aggregate output files.
----- Input-Data Layout ------------------------------------------------------
5 TitleLine The row with the file title on it (zero if no title is available).
7 NamesLine The row with the channel names on it (zero if no names are available or are specified below).
8 UnitsLine The row with the channel units on it (zero if no units are available or are specified below).
9 FirstDataLine The first row of data.
0 NumChans The number of channels in each input file.
ChanTitle ChanUnits Scale Offset PSF_Type NumCols rows of data follow. Title and units strings must be 10 characters or less.
----- Calculated Channels ----------------------------------------------------
0 NumCChan The number calculated channels to generate.
1234567890 Seed The integer seed for the random number generator (-2,147,483,648 to 2,147,483,647)
Col_Title Units Equation Put each field in quotes. Titles and units are limited to 10 characters. NumCChan rows of data follow.
----- Load Roses -------------------------------------------------------------
0 NumRoses The number of load roses to generate.
Rose Name Units Channel1 Channel2 nSectors
----- Time and Wind Speed ----------------------------------------------------
1 TimeChan The channel containing time.
2 WSChan The primary wind-speed channel (used for mean wind speed and turbulence intensity, 0 for none)
----- Statistics and Extreme Events ------------------------------------------
true DoStats Generate statistics of all the channels.
true WrStatsTxt Write the stats to a text file?
false WrStatsXLS Write the stats to an Excel file?
0 NumSFChans Number of channels that will have summary statistics generated for them.
1 SFChans List of channels that will have summary statistics generated for them. Must number NumSFChans.
----- Distributions -----------------------------------------------------------
false UserDistrib User defined distribution? true = load user-specified distribution, false = only use Weibull wind distribution
2 WeibullShape Weibull shape factor. If WeibullShape=2, enter the mean wind speed for WeibullScale.
10 WeibullScale Weibull scale factor. If WeibullShape<>2. Otherwise, enter the mean wind speed.
3 WSin Cut-in wind speed for the turbine.
21 WSout Cut-out wind speed for the turbine.
31 WSmax Maximum wind speed value for the wind-speed bins.
2 WSMaxBinSize Maximum width of a wind-speed bin.
0 nDistribVars Number of independent variables in the user-specified distribution, ignored if UserDistrib = false
“” DistribName Filename of the user-supplied distribution table, ignored if UserDistrib = false
----- Fatigue ----------------------------------------------------------------
5 nFatigueChannels The number of rainflow channels. Next six lines ignored if zero.
0.0 FiltRatio The fraction of the maximum range of each channel used as a cutoff range for the racetrack filter. Use zero for no filter.
630720000 DesignLife Number of seconds in the design lifetime (20 years = 630720000 seconds).
1.0 Availability Fraction of the design life the turbine is operating when winds are between Vin and Vout
true BinCycles Bin the rainflow cycles?
0.5 UCMult Multiplier for binning unclosed cycles. (0 discards, 1 counts as a full cycle)
true DoShortTerm Compute simple (unweighted) damage-equivalent loads and damage rates.
true DoLife Do lifetime-related calculations?
false DoAggregate Compute a DELs and a damage result based on an aggregate of all the input files (does not use the wind spped distribution)
false WrShortTermTxt Write short-term results to plain-text files?
true WrShortTermXLS Write short-term resultsto an Excel workbook?
false WrLifeTxt Write lifetime results to plain-text files?
true WrLifeXLS Write lifetime results to an Excel workbook?
1 EquivalentFrequency The frequency of the damage equivalent load (Hz)
true DEL_AsRange true = report DELs as a range value, false = report as a one-sided amplitude
3 DEL_Type 1 = fixed mean, 2 = zero mean, 3 = both
0 GoodmanFlag 0 = no Goodman correction, 1 = use Goodman correction, 2 = compute results with and without Goodman correction
Channel# NSlopes SNslopeLst BinFlag BinWidth/Number TypeLMF LUlt BinWidth not used when BinCycles is false. nFatigueChannels rows of data follow. LUlt >> LMF
57 1 10 BN 128.0 161 5700
58 1 10 BN 128.0 33 5700
59 1 10 BN 128.0 490 13680
60 1 10 BN 128.0 490 13680
61 1 10 BN 128.0 490 13680
1 NumDELGroups
NChannels ChannelList
“OUT” 5 1 2 3 4 5
----- Input Files ------------------------------------------------------------
1 FileFormat Format of input files. 1 = FAST ascii, 2 = FAST binary
1 1.1 1.3 1.5 1.7 (Weibull-Weighted Normal Operation: NumNormFiles, PSF1, PSF2, PSF3, PSF4)
“PI_SIM_18p15.out”
0 1.1 1.3 1.5 1.7 (Weibull-Weighted Idling: NumIdleFiles, PSF1, PSF2, PSF3, PSF4)
0 1.2 1.3 1.4 1.6 (Discrete Events: NumDiscFiles, PSF1, PSF2, PSF3, PSF4)2 1.1 1.3 1.5 1.7 (Weibull-Weighted Normal Operation: NumNormFiles, PSF1, PSF2, PSF3, PSF4)
==EOF== DO NOT REMOVE OR CHANGE. MUST COME JUST AFTER LAST LINE OF VALID INPUT.
[/code]
PI_SIM_18p15_Lifetime.xlsx (15.2 KB)
Dear Cheng,
I’m not sure I know enough about your approach to offer a detailed response, but here are a few comments:
Dear Dr. Jason,
Thank you for your reply!
I made some modification according to your comments,
I still doubt the result, will Goodman correction help?
Which results are reasonable according to the RMS of platform and blade motion, DELs or STD?
Could I regard STD of the tower and blade moment as the reference of fatigue?
Thank you!
Cheng
Dear Cheng,
The Goodman correction will not contribute much for a single time series. The Goodman correction includes the effects of the mean load on the fatigue calculation (the higher the mean, the higher the fatigue damage for a given cyclic amplitude). So, if you have many time series with different means, the fatigue damage will be more accurately calculated with the Goodman correction.
A single time series will likely not be sufficient for statistical convergence. Typically, many time series are needed across different operating conditions to properly calculate fatigue.
A simple comparison of standard deviation or RMS may be sufficient for your purposes. Fatigue damage or DELs are more accurate representations of fatigue because they consider the S-N curve in the calculation. But if you don’t know the properties of the S-N curve (L_Ult and “m”), then there may be little use in calculating DELs.
Dear Dr. Jason,
Thank you very much for your detailed answer!
It’s very helpful.
Cheng
I understand this part of reply from you completely, but, I have one more question:
Dear Kamineni,
Can you please help me understand the sign convention followed in defining pitch in FAST. Whether the clockwise rotation (seen from root to tip of blade along pitch axis) of the blade is considered positive or negative? Thanks.
Kumara
One more question, rather would like to confirm my understanding.
In the input file to FAST (AeroDynV14), for each blade, the ‘AeroTwst’ align with chord,structural twist etc,is specified at different blade sections. And I observed that ‘AeroTwst’ value decreases from root section to tip section (with almost zero for the tip section) of the blade.
Assuming pitch angle is zero, the chord of the tip section will lie in the rotor plane. Correct?
Chords of airfoil at other sections along blade are making the corresponding ‘aerotwist’ angle with the rotor plane. Correct? If yes,when we define ‘aerotwst’ of at a particular section of blade to be +10 degrees, is it the angle between ‘rotor plane’ and ‘local chord’ (about minus z) in the clockwise or counter-clockwise direction? Thanks.
Kumara
[/quote]
