Dear All
I am trying to build a S-function for FAST_v7.02.00d-bjj. I know the S-function has been built by developers while I just want to do some modification of the source code hence I try to build the S-function before I do any change of the code to ensure that I could build it after I do any changes of the source code.
I follow the instructions in make_FAST_SFunc.m and change all the directories. But the result is shown below.
I have installed Microsoft Visual Studio 2012 and 2013 in my computer as well as Intel Parallel Studio XE 2013 and 2016. I followed the instructions to copy “intelf13msvs2012opts.bat” from %MATLABROOT%\bin\win32\mexopts and also modify the PATH, LIB, INCLUDE in the “intelf13msvs2012opts.bat”.
I open the IVF command called “IA-32 Visual Studio 2012 mode” and type “echo PATH=%PATH%; LIB=%LIB%; INCLUDE=%INCLUDE%” and get the results shown below.
I replaced the value of PATH, LIB, and INCLUDE in “intelf13msvs2012opts.bat” with the value I got in picture 2. In addition, I also added /assume:byterecl /traceback /real_size:64 /Qzero /Qsave and removed /fpp /fixed in COMPFLAGS. By the way, I set the Fortran compiler in MATLAB 2015a as follows but the error is still there.
I am wondering if it is the problem of the version of IVF or VS I used or any other reasons. Hope you can help me figure it out.
Regards
XING WEI
