Ptfmsway is particularly large
Dear Jason:
The calculation example I used is IEA-15-240-RWT-UmaineSemi. The original water depth of this calculation example is 200 meters, the length of mooring line is 850 meters, and the horizontal displacement of anchor point from the platform center is 837.6 meters. I borrowed the model of the wind turbine and platform, modified the length of the mooring line to be 600 meters, and the horizontal displacement of the anchor point from the center of the platform to be 585 meters, which is used to calculate the mooring system applicable to the water depth of 30 meters. And my wind, wave and current are all 0 degrees, that is, they are all in the X direction, but why is there a large displacement in the Y direction of the platform calculated?
In my reply to this topic, I attach the hydrodyn file and the moordyn file.
The calculated platform displacement is particularly large.
This is not in line with the mooring system design standard, but I don’t know where the problem is. Please help me guide it. Thank you very much.
best regards,
False Echo - Echo the input file data (flag)
30 WtrDpth - Water depth (meters)
0 MSL2SWL - Offset between still-water level and mean sea level (meters) [positive upward; unused when WaveMod = 6; must be zero if PotMod=1 or 2]
2 WaveMod - Incident wave kinematics model {0: none=still water, 1: plane progressive (regular), 2: JONSWAP/Pierson-Moskowitz spectrum (irregular), 3: user-defind spectrum from routine UserWaveSpctrm (irregular)} (switch)
850.00 WaveTMax - Analysis time for incident wave calculations (sec) [unused when WaveMod=0; determines WaveDOmega=2Pi/WaveTMax in the IFFT]
0.25 WaveDT - Time step for incident wave calculations (sec) [unused when WaveMod=0; 0.1<=WaveDT<=1.0 recommended; determines WaveOmegaMax=Pi/WaveDT in the IFFT]
10.00 WaveHs - Significant wave height of incident waves (meters) [used only when WaveMod=1 or 2]
12.0 WaveTp - Peak spectral period of incident waves (sec) [used only when WaveMod=1 or 2]
3.30 WavePkShp - Peak-shape parameter of incident wave spectrum (-) or DEFAULT (string) [used only when WaveMod=2; use 1.0 for Pierson-Moskowitz]
0.111527 WvLowCOff - Low cut-off frequency or lower frequency limit of the wave spectrum beyond which the wave spectrum is zeroed (rad/s) [unused when WaveMod=0, 1, or 6]
0.7583827 WvHiCOff - High cut-off frequency or upper frequency limit of the wave spectrum beyond which the wave spectrum is zeroed (rad/s) [unused when WaveMod=0, 1, or 6]
0.00 WaveDir - Incident wave propagation heading direction (degrees) [unused when WaveMod=0 or 6]
0 WaveDirMod - Directional spreading function {0: none, 1: COS2S} (-) [only used when WaveMod=2,3, or 4]
1 WaveDirSpread - Wave direction spreading coefficient ( > 0 ) (-) [only used when WaveMod=2,3, or 4 and WaveDirMod=1]
1 WaveNDir - Number of wave directions (-) [only used when WaveMod=2,3, or 4 and WaveDirMod=1; odd number only]
90 WaveDirRange - Range of wave directions (full range: WaveDir +/- 1/2*WaveDirRange) (degrees) [only used when WaveMod=2,3,or 4 and WaveDirMod=1]
-561580799 WaveSeed(1) - First random seed of incident waves [-2147483648 to 2147483647] (-) [unused when WaveMod=0, 5, or 6]
-1669871451 WaveSeed(2) - Second random seed of incident waves [-2147483648 to 2147483647] (-) [unused when WaveMod=0, 5, or 6]
TRUE WaveNDAmp - Flag for normally distributed amplitudes (flag) [only used when WaveMod=2, 3, or 4]
“none” WvKinFile - Root name of externally generated wave data file(s) (quoted string) [used only when WaveMod=5 or 6]
1 NWaveElev - Number of points where the incident wave elevations can be computed (-) [maximum of 9 output locations]
0 WaveElevxi - List of xi-coordinates for points where the incident wave elevations can be output (meters) [NWaveElev points, separated by commas or white space; usused if NWaveElev = 0]
0 WaveElevyi - List of yi-coordinates for points where the incident wave elevations can be output (meters) [NWaveElev points, separated by commas or white space; usused if NWaveElev = 0]
True WvDiffQTF - Full difference-frequency 2nd-order wave kinematics (flag)
False WvSumQTF - Full summation-frequency 2nd-order wave kinematics (flag)
0 WvLowCOffD - Low frequency cutoff used in the difference-frequencies (rad/s) [Only used with a difference-frequency method]
0.737863 WvHiCOffD - High frequency cutoff used in the difference-frequencies (rad/s) [Only used with a difference-frequency method]
0.314159 WvLowCOffS - Low frequency cutoff used in the summation-frequencies (rad/s) [Only used with a summation-frequency method]
3.2 WvHiCOffS - High frequency cutoff used in the summation-frequencies (rad/s) [Only used with a summation-frequency method]
1 CurrMod - Current profile model {0: none=no current, 1: standard, 2: user-defined from routine UserCurrent} (switch)
0 CurrSSV0 - Sub-surface current velocity at still water level (m/s) [used only when CurrMod=1]
0 CurrSSDir - Sub-surface current heading direction (degrees) or DEFAULT (string) [used only when CurrMod=1]
20 CurrNSRef - Near-surface current reference depth (meters) [used only when CurrMod=1]
2.0 CurrNSV0 - Near-surface current velocity at still water level (m/s) [used only when CurrMod=1]
0 CurrNSDir - Near-surface current heading direction (degrees) [used only when CurrMod=1]
0 CurrDIV - Depth-independent current velocity (m/s) [used only when CurrMod=1]
0 CurrDIDir - Depth-independent current heading direction (degrees) [used only when CurrMod=1]
1 PotMod - Potential-flow model {0: none=no potential flow, 1: frequency-to-time-domain transforms based on WAMIT output, 2: fluid-impulse theory (FIT)} (switch)
1 ExctnMod - Wave-excitation model {0: no wave-excitation calculation, 1: DFT, 2: state-space} (switch) [only used when PotMod=1; STATE-SPACE REQUIRES .ssexctn INPUT FILE]
1 RdtnMod - Radiation memory-effect model {0: no memory-effect calculation, 1: convolution, 2: state-space} (switch) [only used when PotMod=1; STATE-SPACE REQUIRES .ss INPUT FILE]
60 RdtnTMax - Analysis time for wave radiation kernel calculations (sec) [only used when PotMod=1; determines RdtnDOmega=Pi/RdtnTMax in the cosine transform; MAKE SURE THIS IS LONG ENOUGH FOR THE RADIATION IMPULSE RESPONSE FUNCTIONS TO DECAY TO NEAR-ZERO FOR THE GIVEN PLATFORM!]
“DEFAULT” RdtnDT - Time step for wave radiation kernel calculations (sec) [only used when PotMod=1; DT<=RdtnDT<=0.1 recommended; determines RdtnOmegaMax=Pi/RdtnDT in the cosine transform]
1 NBody - Number of WAMIT bodies to be used (-) [>=1; only used when PotMod=1. If NBodyMod=1, the WAMIT data contains a vector of size 6
NBody x 1 and matrices of size 6
NBody x 6*NBody; if NBodyMod>1, there are NBody sets of WAMIT data each with a vector of size 6 x 1 and matrices of size 6 x 6]
1 NBodyMod - Body coupling model {1: include coupling terms between each body and NBody in HydroDyn equals NBODY in WAMIT, 2: neglect coupling terms between each body and NBODY=1 with XBODY=0 in WAMIT, 3: Neglect coupling terms between each body and NBODY=1 with XBODY=/0 in WAMIT} (switch) [only used when PotMod=1]
“HydroData/IEA-15-240-RWT-UMaineSemi” PotFile - Root name of potential-flow model data; WAMIT output files containing the linear, nondimensionalized, hydrostatic restoring matrix (.hst), frequency-dependent hydrodynamic added mass matrix and damping matrix (.1), and frequency- and direction-dependent wave excitation force vector per unit wave amplitude (.3) (quoted string) [MAKE SURE THE FREQUENCIES INHERENT IN THESE WAMIT FILES SPAN THE PHYSICALLY-SIGNIFICANT RANGE OF FREQUENCIES FOR THE GIVEN PLATFORM; THEY MUST CONTAIN THE ZERO- AND INFINITE-FREQUENCY LIMITS!]
1 WAMITULEN - Characteristic body length scale used to redimensionalize WAMIT output (meters) [only used when PotMod=1]
1.0 PtfmRefxt - The xt offset of the body reference point(s) from (0,0,0) (meters) [1 to NBody] [only used when PotMod=1]
1.0 PtfmRefyt - The yt offset of the body reference point(s) from (0,0,0) (meters) [1 to NBody] [only used when PotMod=1]
1.0 PtfmRefzt - The zt offset of the body reference point(s) from (0,0,0) (meters) [1 to NBody] [only used when PotMod=1. If NBodyMod=2,PtfmRefzt=0.0]
1.0 PtfmRefztRot - The rotation about zt of the body reference frame(s) from xt/yt (degrees) [1 to NBody] [only used when PotMod=1]
20206.34889 PtfmVol0 - Displaced volume of water when the platform is in its undisplaced position (m^3) [only used when PotMod=1; USE THE SAME VALUE COMPUTED BY WAMIT AS OUTPUT IN THE .OUT FILE!]
0 PtfmCOBxt - The xt offset of the center of buoyancy (COB) from the platform reference point (meters) [only used when PotMod=1]
0 PtfmCOByt - The yt offset of the center of buoyancy (COB) from the platform reference point (meters) [only used when PotMod=1]
0 MnDrift - Mean-drift 2nd-order forces computed {0: None; [7, 8, 9, 10, 11, or 12]: WAMIT file to use} [Only one of MnDrift, NewmanApp, or DiffQTF can be non-zero]
0 NewmanApp - Mean- and slow-drift 2nd-order forces computed with Newman’s approximation {0: None; [7, 8, 9, 10, 11, or 12]: WAMIT file to use} [Only one of MnDrift, NewmanApp, or DiffQTF can be non-zero. Used only when WaveDirMod=0]
12 DiffQTF - Full difference-frequency 2nd-order forces computed with full QTF {0: None; [10, 11, or 12]: WAMIT file to use} [Only one of MnDrift, NewmanApp, or DiffQTF can be non-zero]
0 SumQTF - Full summation -frequency 2nd-order forces computed with full QTF {0: None; [10, 11, or 12]: WAMIT file to use}
---------------------- PLATFORM ADDITIONAL STIFFNESS AND DAMPING --------------
0 AddF0 - Additional preload (N, N-m)
0
0
0
0
0
0 0 0 0 0 0 AddCLin - Additional linear stiffness (N/m, N/rad, N-m/m, N-m/rad)
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0 AddBLin - Additional linear damping(N/(m/s), N/(rad/s), N-m/(m/s), N-m/(rad/s))
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
0 0 0 0 0 0
9.23E+05 0.00E+00 0.00E+00 0.00E+00 -8.92E+06 0.00E+00 AddBQuad - Additional quadratic drag(N/(m/s)^2, N/(rad/s)^2, N-m(m/s)^2, N-m/(rad/s)^2)
0.00E+00 9.23E+05 0.00E+00 8.92E+06 0.00E+00 0.00E+00
0.00E+00 0.00E+00 2.30E+06 0.00E+00 0.00E+00 0.00E+00
0.00E+00 8.92E+06 0.00E+00 1.68E+10 0.00E+00 0.00E+00
-8.92E+06 0.00E+00 0.00E+00 0.00E+00 1.68E+10 0.00E+00
0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 4.80E+10
1 NAxCoef - Number of axial coefficients (-)
AxCoefID AxCd AxCa AxCp
1 0.00 0.00 0.00
2 NJoints - Number of joints (-) [must be exactly 0 or at least 2]
JointID Jointxi Jointyi Jointzi JointAxID JointOvrlp [JointOvrlp= 0: do nothing at joint, 1: eliminate overlaps by calculating super member]
(-) (m) (m) (m) (-) (switch)
1 0.00000 0.00000 -13.18 1 0
2 0.00000 0.00000 -14.18 1 0
1 NPropSets - Number of member property sets (-)
PropSetID PropD PropThck
(-) (m) (m)
1 .00001 0.000001
---------------------- SIMPLE HYDRODYNAMIC COEFFICIENTS (model 1) --------------
SimplCd SimplCdMG SimplCa SimplCaMG SimplCp SimplCpMG SimplAxCd SimplAxCdMG SimplAxCa SimplAxCaMG SimplAxCp SimplAxCpMG
0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
---------------------- DEPTH-BASED HYDRODYNAMIC COEFFICIENTS (model 2) ---------
0 NCoefDpth - Number of depth-dependent coefficients (-)
Dpth DpthCd DpthCdMG DpthCa DpthCaMG DpthCp DpthCpMG DpthAxCa DpthAxCaMG DpthAxCp DpthAxCpMG
(m) (-) (-) (-) (-) (-) (-) (-) (-) (-) (-)
---------------------- MEMBER-BASED HYDRODYNAMIC COEFFICIENTS (model 3) --------
0 NCoefMembers - Number of member-based coefficients (-)
MemberID MemberCd1 MemberCd2 MemberCdMG1 MemberCdMG2 MemberCa1 MemberCa2 MemberCaMG1 MemberCaMG2 MemberCp1 MemberCp2 MemberCpMG1 MemberCpMG2 MemberAxCa1 MemberAxCa2 MemberAxCaMG1 MemberAxCaMG2 MemberAxCp1 MemberAxCp2 MemberAxCpMG1 MemberAxCpMG2
1 NMembers - Number of members (-)
MemberID MJointID1 MJointID2 MPropSetID1 MPropSetID2 MDivSize MCoefMod PropPot [MCoefMod=1: use simple coeff table, 2: use depth-based coeff table, 3: use member-based coeff table] [ PropPot/=0 if member is modeled with potential-flow theory]
(-) (-) (-) (-) (-) (m) (switch) (flag)
1 1 2 1 1 1 1 TRUE
0 NFillGroups - Number of filled member groups (-) [If FillDens = DEFAULT, then FillDens = WtrDens; FillFSLoc is related to MSL2SWL]
FillNumM FillMList FillFSLoc FillDens
(-) (-) (m) (kg/m^3)
---------------------- MARINE GROWTH -------------------------------------------
0 NMGDepths - Number of marine-growth depths specified (-)
MGDpth MGThck MGDens
(m) (m) (kg/m^3)
---------------------- MEMBER OUTPUT LIST --------------------------------------
0 NMOutputs - Number of member outputs (-) [must be < 10]
MemberID NOutLoc NodeLocs [NOutLoc < 10; node locations are normalized distance from the start of the member, and must be >=0 and <= 1] [unused if NMOutputs=0]
---------------------- JOINT OUTPUT LIST ---------------------------------------
0 NJOutputs - Number of joint outputs [Must be < 10]
1 2 JOutLst - List of JointIDs which are to be output (-)[unused if NJOutputs=0]
TRUE HDSum - Output a summary file [flag]
False OutAll - Output all user-specified member and joint loads (only at each member end, not interior locations) [flag]
2 OutSwtch - Output requested channels to: [1=Hydrodyn.out, 2=GlueCode.out, 3=both files]
“ES11.4e2” OutFmt - Output format for numerical results (quoted string) [not checked for validity!]
“A11” OutSFmt - Output format for header strings (quoted string) [not checked for validity!]
---------------------- OUTPUT CHANNELS -----------------------------------------
“Wave1Elev” - Wave elevation at the platform reference point ( 0, 0)
END of output channels and end of file. (the word “END” must appear in the first 3 columns of this line)
--------------------- MoorDyn Input File ------------------------------------
IEA 15 MW offshore reference model on UMaine VolturnUS-S semi-submersible floating platform mooring model- C. Allen UMaine
FALSE Echo - echo the input file data (flag)
----------------------- LINE TYPES ------------------------------------------
1 NTypes - number of LineTypes
Name Diam MassDen EA BA/-zeta Can Cat Cdn Cdt
(-) (m) (kg/m) (N) (N-s/-) (-) (-) (-) (-)
main 0.333 685.00 3.27E+09 -1 0.82 0.27 1.11 0.20
---------------------- CONNECTION PROPERTIES --------------------------------
6 NConnects - number of connections including anchors and fairleads
Node Type X Y Z M V FX FY FZ CdA CA
(-) (-) (m) (m) (m) (kg) (m^3) (kN) (kN) (kN) (m^2) (-)
1 Vessel -58.000 0.000 -14.000 0 0 0 0 0 0 0
2 Fixed -585.000 0.000 -30.000 0 0 0 0 0 0 0
3 Vessel 29.000 50.229 -14.000 0 0 0 0 0 0 0
4 Fixed 292.500 506.624 -30.000 0 0 0 0 0 0 0
5 Vessel 29.000 -50.229 -14.000 0 0 0 0 0 0 0
6 Fixed 292.500 -506.624 -30.000 0 0 0 0 0 0 0
---------------------- LINE PROPERTIES --------------------------------------
3 NLines - number of line objects
Line LineType UnstrLen NumSegs NodeAnch NodeFair Flags/Outputs CtrlChan
(-) (-) (m) (-) (-) (-) (-) (-)
1 main 600.00 50 2 1 - 0
2 main 600.00 50 4 3 - 0
3 main 600.00 50 6 5 - 0
---------------------- SOLVER OPTIONS ---------------------------------------
0.001 dtM - time step to use in mooring integration (s)
3.0e6 kbot - bottom stiffness (Pa/m)
3.0e5 cbot - bottom damping (Pa-s/m)
1.0 dtIC - time interval for analyzing convergence during IC gen (s)
60.0 TmaxIC - max time for ic gen (s)
4.0 CdScaleIC - factor by which to scale drag coefficients during dynamic relaxation (-)
0.001 threshIC - threshold for IC convergence (-)
------------------------ OUTPUTS --------------------------------------------
FairTen1
FairTen2
FairTen3
AnchTen1
AnchTen2
AnchTen3
Con1fx
Con3fx
Con5fx
Con1fy
Con3fy
Con5fy
Con1fz
Con3fz
Con5fz
Con2fx
Con4fx
Con6fx
Con2fy
Con4fy
Con6fy
Con2fz
Con4fz
Con6fz
fx
fy
fz
END
------------------------- need this line --------------------------------------
Dear @Cuizhi.Zhu,
What conditions are you simulating that lead to a large sway offset and how large of an offset are you talking about? I see from your HydroDyn file that your sea state is quite severe with WaveHs = 10 m, WaveTp = 12 s, and CurrNSV0 = 2 m/s. Do you get a large sway offset with just these conditions, or only with wind and aerodynamics enabled as well?
Dear Jason:
Only when wind and aerodynamics are enabled, I will also get a large swing offset.
best regards,
When the wind and aerodynamics are not started, the displacement is also large, and the ptfmsurge will reach more than 100 meters.
Dear @Cuizhi.Zhu,
I’m not sure I really understand your question, but it sounds like the transverse motion (sway) is caused by the aerodynamic loads and the in-line motion (surge) is caused by a combination of second-order difference-frequency effects (mean and slow drift) as a result of the severe sea state, a strong current, and aerodynamic thrust (when enabled).
Dear Jason:
Thank you for your reply. I have solved this problem. But I still have a question to ask, can we see the movement of mooring system or can we only see the rotation of wind turbine by using WrVTK for visualization in openfast?
best regards,
Dear @Cuizhi.Zhu,
You can use the visualization functionality of OpenFAST to visualize the wind turbine (including its rotor rotation and floater-induced motion), but the following known (still unresolved) issues prevent OpenFAST from generating visual representations of the floater (Visualizing Offshore Support Structures · Issue #776 · OpenFAST/openfast · GitHub) and moorings (Visualize mooring lines with VTK · Issue #539 · OpenFAST/openfast · GitHub).
