From a coupled dynamic analysis of a semi-submersible FOWT, platform motion responses in the turbulent wind are obtained as one-hour time series. Later, these time series (for different values of Hs, Tp, and turbulent wind field) are transferred into the spectral density plots (w (rad/s) vs. S(w)). Wind and waves are aligned along the x-axis of the platform.
I know the 1P & 3P frequencies of the rotor, w_p (2*pi/T_p) from the wave spectrum, and natural frequencies of the platform from decay tests.
Now, using the spectral plots,
Is it possible to comment/explain why the spectral peaks are at a certain frequency?
When there are multiple peaks in a single plot, “peaks within the wave frequency range are due to the wave and outside wave frequency are due to non-linear effects” can I comment like that?
MDTI
