Hi Jason,
The Morison equation has two parts, the inertia part and the drag part.
I understand that the drag part is calculated from the MemberCd values in Hydrodyn. How is the inertia part calculated ? Is my understanding correct here?
In the DeepCwind platform case I can find the Cd values from the hydrodyn input files. Where can I find the Cm values for the members?
Rahul.
Dear @Rahul.Ramachandran,
In the strip-theory formulation of HydroDyn for the force per unit length along each member (via Morison’s equation), HydroDyn uses Cm = Cp+Ca, where Cp represents the pressure coefficient (often taken as 1.0) for the Froude-Kriloff force and Ca represents the added-mass coefficient for the scattering force (also used in the calculation of added mass).
That’s clear. Thank you so much.
Rahul.
