I want to generate 1-hour wind files with wind speed 44.2m/s, but after the simulation, I checked the time series, I noticed that the wind speed output is only 33.54m/s, which is far away from my setup wind speed. I attached the time series and wind input file also.
Could you give me some hint what could be the reason for this? Thanks.
TurbSim Input File.
2250 RandSeed1 - First random seed (-2147483648 to 2147483647)
RanLux RandSeed2 - Second random seed (-2147483648 to 2147483647) for intrinsic pRNG, or an alternative pRNG: “RanLux” or “RNSNLW”
False WrBHHTP - Output hub-height Turbulence Parameters in binary form? (Generates RootName.bin)
False WrFHHTP - Output hub-height Turbulence Parameters in formatted form? (Generates RootName.dat)
False WrACT - Output Coherent Turbulence time steps in AeroDyn form? (Generates RootName.cts)
1 ScaleIEC - Scale IEC turbulence models to exact target standard deviation? [0=no additional scaling; 1=use hub scale uniformly; 2=use individual scales]
0.02 TimeStep - Time step [seconds]
3900 AnalysisTime - Length of analysis time series [seconds]
3900 UsableTime - Usable length of output time series [seconds] (program will add GridWidth/MeanHHWS seconds) [bjj: was 630]
123.1 HubHt - Hub height [m] (should be > 0.5GridHeight)
210 GridHeight - Grid height [m]
210 GridWidth - Grid width [m] (should be >= 2(RotorRadius+ShaftLength))
IECKAI TurbModel - Turbulence model (“IECKAI”=Kaimal, “IECVKM”=von Karman, “GP_LLJ”, “NWTCUP”, “SMOOTH”, “WF_UPW”, “WF_07D”, “WF_14D”, or “NONE”)
1-ed3 IECstandard - Number of IEC 61400-x standard (x=1,2, or 3 with optional 61400-1 edition number (i.e. “1-Ed2”) )
11 IECturbc - IEC turbulence characteristic (“A”, “B”, “C” or the turbulence intensity in percent) (“KHTEST” option with NWTCUP, not used for other models)
NTM IEC_WindType - IEC turbulence type (“NTM”=normal, “xETM”=extreme turbulence, “xEWM1”=extreme 1-year wind, “xEWM50”=extreme 50-year wind, where x=wind turbine class 1, 2, or 3)
default ETMc - IEC Extreme turbulence model “c” parameter [m/s]
PL WindProfileType - Wind profile type (“JET”=Low-level jet,“LOG”=Logarithmic,“PL”=Power law, or “default”, or “USR”=User-defined)
123.1 RefHt - Height of the reference wind speed [m]
44.2 URef - Mean (total) wind speed at the reference height [m/s]
0.14 PLExp - Power law exponent [-] (or “default”)
0.05 RICH_NO - Gradient Richardson Number
default PC_UW - Hub mean u’w’ Reynolds stress [(m/s)^2] (or “default”)
default PC_UV - Hub mean u’v’ Reynolds stress [(m/s)^2] (or “default”)
default PC_VW - Hub mean v’w’ Reynolds stress [(m/s)^2] (or “default”)
default IncDec1 - u-component coherence parameters (e.g. “10.0 0.3e-3” in quotes)
default IncDec2 - v-component coherence parameters (e.g. “10.0 0.3e-3” in quotes)
default IncDec3 - w-component coherence parameters (e.g. “10.0 0.3e-3” in quotes)
default CohExp - Coherence exponent (or “default”)
M:\coh_events\eventdata CTEventPath - Name of the path where event data files are located
Random CTEventFile - Type of event files (“random”, “les” or “dns”)
True Randomize - Randomize disturbance scale and location? (true/false)
1 DistScl - Disturbance scale (ratio of dataset height to rotor disk).
0.5 CTLy - Fractional location of tower centerline from right (looking downwind) to left side of the dataset.
0.5 CTLz - Fractional location of hub height from the bottom of the dataset.
10 CTStartTime - Minimum start time for coherent structures in RootName.cts [seconds]
