Dear Jason/Bonnie
I have a question re FAST v8 Simulink. I’m trying to re-compile the s-function so to generate c-code into a target processor for Hardware-in-the-loop simulation, using a dSPACE platform (ds1103) which is based on a PowerPC processor.
The compilation of the 64 bit FAST_SFunc.c into a MEX function into MATLAB’s workspace was successful (had to do it with Microsoft SDK 7.1 according to the dSPACE manufacturer guidelines).
The problem arises when I’m pressing ‘Build Model’ inside the Simulink environment. Here is where the entire Simulink model (including the FAST s-function) is converted into c code for the dSPACE to run it using a PowerPC specific compiler. After several trials I had to modify the FAST_SFunc.c file so to eliminate the following compilation errors:
COMPILING "C:\FAST_v8\Simulink\Source\FAST_SFunc.c"
(E) C0256; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 237 pos 28; invalid redeclaration of type name "mxArray" (declared at line 41 of "C:\PROGRA~1\MATLAB\R2016b\rtw\c\src\rt_matrx.h")
typedef struct mxArray_tag mxArray;
(E) C0256; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 257 pos 18; invalid redeclaration of type name "mxChar" (declared at line 44 of "C:\PROGRA~1\MATLAB\R2016b\rtw\c\src\rt_matrx.h")
typedef CHAR16_T mxChar;
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 264 pos 5; "mxUNKNOWN_CLASS" has already been declared in the current scope
mxUNKNOWN_CLASS = 0,
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 265 pos 5; "mxCELL_CLASS" has already been declared in the current scope
mxCELL_CLASS,
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 266 pos 5; "mxSTRUCT_CLASS" has already been declared in the current scope
mxSTRUCT_CLASS,
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 267 pos 5; "mxLOGICAL_CLASS" has already been declared in the current scope
mxLOGICAL_CLASS,
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 268 pos 5; "mxCHAR_CLASS" has already been declared in the current scope
mxCHAR_CLASS,
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 270 pos 5; "mxDOUBLE_CLASS" has already been declared in the current scope
mxDOUBLE_CLASS,
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 271 pos 5; "mxSINGLE_CLASS" has already been declared in the current scope
mxSINGLE_CLASS,
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 272 pos 5; "mxINT8_CLASS" has already been declared in the current scope
mxINT8_CLASS,
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 273 pos 5; "mxUINT8_CLASS" has already been declared in the current scope
mxUINT8_CLASS,
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 274 pos 5; "mxINT16_CLASS" has already been declared in the current scope
mxINT16_CLASS,
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 275 pos 5; "mxUINT16_CLASS" has already been declared in the current scope
mxUINT16_CLASS,
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 276 pos 5; "mxINT32_CLASS" has already been declared in the current scope
mxINT32_CLASS,
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 277 pos 5; "mxUINT32_CLASS" has already been declared in the current scope
mxUINT32_CLASS,
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 278 pos 5; "mxINT64_CLASS" has already been declared in the current scope
mxINT64_CLASS,
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 279 pos 5; "mxUINT64_CLASS" has already been declared in the current scope
mxUINT64_CLASS,
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 282 pos 5; "mxOBJECT_CLASS" has already been declared in the current scope
mxOBJECT_CLASS, /* keep the last real item in the list */
(E) C0256; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 290 pos 3; invalid redeclaration of type name "mxClassID" (declared at line 33 of "C:\PROGRA~1\MATLAB\R2016b\rtw\c\src\rt_mxclassid.h")
} mxClassID;
(E) C0101; "C:\PROGRA~1\MATLAB\R2016b\extern\include\matrix.h", line 297 pos 5; "mxREAL" has already been declared in the current scope
mxREAL,
20 Errors
COMPILING FAILED (1)
After commenting the problematic code lines, the compilation of ‘FAST_SFunc.c’ seems to be getting somewhere, however there is only one remaining error which I’m showing you with at the screenshot:
I tried the same in another piece of RT Hardware (from another manufacturer) that uses the gcc compiler and the error seems to be similar:
Latest logbook entries:
33 I 0x3a43 mMSYS 04-18-2017 16.44.31.474+0000 SYS_MAIN: MSys-Software successfully started.
34 I 0x4220 mRES 04-18-2017 16.44.32.481+0000 DBG_INIT: 'DBG' successfully started.
35 I 0x98ea bSWGIO212 04-18-2017 16.44.43.590+0000 SWGIO212: Module deleted.
36 E 0x8d73a9 mMOD 04-18-2017 18.01.39.109+0000 Undefined symbol: _FAST_End (binding 1 type 0)
37 E 0x8d73a9 mMOD 04-18-2017 18.01.39.109+0000 Undefined symbol: _FAST_Sizes (binding 1 type 0)
38 E 0x8d73a9 mMOD 04-18-2017 18.01.39.110+0000 Undefined symbol: _FAST_Update (binding 1 type 0)
39 E 0x8d73aa mMOD 04-18-2017 18.01.39.110+0000 Undefined symbol: _FAST_Start (binding 1 type 0)
40 E 0x8d73b9 mMOD 04-18-2017 18.01.39.117+0000 MOD_LOADVXW: Error mod=028 status=01 in loadModule() file '/ram0/wt21_v.o'!
41 I 0x8d73b9 mMOD 04-18-2017 18.01.39.117+0000 MOD_LOADVXW: Unloading Module /ram0/wt21_v.o because of unresolved symbols
42 E 0x8d73bc mMOD 04-18-2017 18.01.39.119+0000 MOD_RPCINST1: Module not installed!
The call to m1target_make_rtw_hook, during the exit hook generated the following error:
Could not install SW-Module on the M1 controller
The build process will terminate as a result.
Caused by:
Component: Simulink | Category: Model error
I would appreciate any light on this problem.
Many thanks,
Juan Pablo
