In order to run ADAMS for OC3-Hywind for time duration up to 5000 second, I faced with memsize limitation error. So I modified Adams - Settings> MSCA>ASolver.Prefrences>memSIZE to Custom. Then using command window to set custom memsize i encountered with following errors:
c:\MyProject>mdadams2010 cmm
The default value for MDSIZ is 60000000
Enter a new value or to accept default: 150000000
The default value for OSSIZ is 200000
Enter a new value or to accept default: 500000
The default value for CDSIZ is 16000
Enter a new value or to accept default: 35000
The default value for LDSIZ is 50000
Enter a new value or to accept default: 120000
The default value for LCEXPR is 1000
Enter a new value or to accept default: 2500
The default value for FPSIZE is 3000
Enter a new value or to accept default: 7000
The default value for NINSIZ is 15000
The default value for MXSTAK is 300
Directory of custom memory model is C:\MSC~1.SOF\MD_Adams\2010\win32\uconfg_use
r …
ifort -c /nologo /automatic /MD /Ob2 /Gm C:\MSC~1.SOF\MD_Adams\2010\win32\uconfg
_user\uconfg.f
link /dll uconfg.obj /out:C:\MSC~1.SOF\MD_Adams\2010\win32\uconfg_user\uconf
g.dll /libpath:C:\MSC~1.SOF\MD_Adams\2010\win32 msvcrt.lib /machine:x86 /expo
rt:_UCONFG@12 /export:DDATA,DATA /export:CSDATA,DATA /export:LSDATA,DATA /export
:CEXPR,DATA /export:UFUNC1,DATA /export:UFUNC2,DATA /export:STKAR1,DATA /export:
STKAR2,DATA
Microsoft (R) Incremental Linker Version 9.00.21022.08
Copyright (C) Microsoft Corporation. All rights reserved.
Creating library C:\MSC~1.SOF\MD_Adams\2010\win32\uconfg_user\uconfg.lib and
object C:\MSC~1.SOF\MD_Adams\2010\win32\uconfg_user\uconfg.exp
msvcrt.lib(crtdll.obj) : error LNK2019: unresolved external symbol __imp__Interl
ockedExchange@8 referenced in function __CRT_INIT@12
msvcrt.lib(crtdll.obj) : error LNK2019: unresolved external symbol __imp__Sleep@
4 referenced in function __CRT_INIT@12
ockedCompareExchange@12 referenced in function __CRT_INIT@12
msvcrt.lib(dllmain.obj) : error LNK2019: unresolved external symbol __imp__Disab
leThreadLibraryCalls@4 referenced in function _DllMain@12
msvcrt.lib(gs_support.obj) : error LNK2019: unresolved external symbol __imp__Qu
eryPerformanceCounter@4 referenced in function ___security_init_cookie
msvcrt.lib(gs_support.obj) : error LNK2019: unresolved external symbol __imp__Ge
tTickCount@0 referenced in function ___security_init_cookie
tCurrentThreadId@0 referenced in function ___security_init_cookie
tCurrentProcessId@0 referenced in function ___security_init_cookie
tSystemTimeAsFileTime@4 referenced in function ___security_init_cookie
msvcrt.lib(gs_report.obj) : error LNK2019: unresolved external symbol __imp__Ter
minateProcess@8 referenced in function ___report_gsfailure
msvcrt.lib(gs_report.obj) : error LNK2019: unresolved external symbol __imp__Get
CurrentProcess@0 referenced in function ___report_gsfailure
msvcrt.lib(gs_report.obj) : error LNK2019: unresolved external symbol __imp__Unh
andledExceptionFilter@4 referenced in function ___report_gsfailure
msvcrt.lib(gs_report.obj) : error LNK2019: unresolved external symbol __imp__Set
UnhandledExceptionFilter@4 referenced in function ___report_gsfailure
msvcrt.lib(gs_report.obj) : error LNK2019: unresolved external symbol __imp__IsD
ebuggerPresent@0 referenced in function ___report_gsfailure
C:\MSC~1.SOF\MD_Adams\2010\win32\uconfg_user\uconfg.dll : fatal error LNK1120: 1
4 unresolved externals
*** Error *** Adams link step failed.
************* Deleted new library file.
if exist C:\MSC~1.SOF\MD_Adams\2010\win32\uconfg_user\uconfg.dll.manifest mt.exe
-outputresource:C:\MSC~1.SOF\MD_Adams\2010\win32\uconfg_user\uconfg.dll;#2 -man
ifest C:\MSC~1.SOF\MD_Adams\2010\win32\uconfg_user\uconfg.dll.manifest
‘mt.exe’ is not recognized as an internal or external command,
operable program or batch file.
*** Error *** Adams manifest step failed.
Note i am using IVF 11.00.066 32bit with VS2008.
Is there anyone to have experience in this case or know how to fix this problem.
Any comment will be appreciable.
Mehdi,
