Hi, I wanted to ask a clarification.
In the OpenFAST readthedocs manual, in modeling considerations for subdyn Link and hydrodyn (strip theory) Link, the following is suggested:
Due to the exponential decay of hydrodynamic loads with depth, a higher resolution near the water free surface is required to capture hydrodynamic loading as waves oscillate about SWL. It is recommended, for instance, that the HydroDyn discretization not exceed element lengths of 0.5 m in the region of the free surface (5 to 10 m above and below SWL), 1.0 m between 25 and 50 m depth, and 2.0 m in deeper waters. When HydroDyn is coupled to SubDyn through FAST for the analysis of fixed-bottom systems, it is recommended that the length ratio between elements of HydroDyn and SubDyn not exceed 10 to 1.
My question is:
- does this mean that I need to have a subdyn member for every 20m between seabed and -50m water level, for every 10m between -50m and -25m water level, etc, if I set
NDivto 1 in subdyn? BUT that I do not have to do so inhydrodyn.dat, i.e. I can have a single member from seabed to transition piece, and specifyMDivSizeequal to 0.5m? - OR i need to have a similar discretization (but with members 1/10th of the subdyn members as suggested)? This would be more cumbersome, and keeps giving the error “The lowest element of a member must not cross the free surface…”
Many thanks
