Dear Dr. Jonkman,
I encountered the same problem with the OC3 Spar platform under wave characteristics of Hs=3.75m and Tp=6.50s and turbulent wind with a reference wind speed of 12.0m/s and TI=8%. Different from the simulations here, I employed the FAST.Farm to finish the calculation, including the wake-meandering effect. The blade pitch and torque speed are set below:
12.1 RotSpeed - Initial or fixed rotor speed (rpm)
When AFAeroMod=2 and SkewMod=2, the warning information is:
T1:FARM_UpdateStates:FWrap_Increment:FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:Rot
CalcOutput:BEMT_CalcOutput(node 15, blade 1):UA_CalcOutput:Mach number exceeds 0.3. Theory is
invalid. This warning will not be repeated though the condition may persist.
Time: 95 of 4000 seconds. Estimated final completion at 01:18:03.
T2:FARM_UpdateStates:FWrap_Increment:FAST_Solution:FAST_AdvanceStates:AD_UpdateStates:BEMT_UpdateS
tates:UpdatePhi(node 16, blade 3):BEMT_UnCoupledSolve:There is no valid value of phi for these
operating conditions: Vx = 0.39827, Vy = -35.182, rlocal = 56.124, theta = -1.5349, geometric phi
= 3.1303. This warning will not be repeated though the condition may persist. (See GeomPhi output
channel.)
Time: 97 of 4000 seconds. Estimated final completion at 01:43:59.
The BEM solution is being turned off due to low TSR. (TSR = 1.8361). This warning will not be
Time: 98 of 4000 seconds. Estimated final completion at 01:43:59.
T1:FARM_UpdateStates:FWrap_Increment:FAST_Solution:FAST_AdvanceStates:AD_UpdateStates:BEMT_UpdateS
tates:UpdatePhi(node 5, blade 1):BEMT_UnCoupledSolve:There is no valid value of phi for these
operating conditions: Vx = 15.39, Vy = -1.2619, rlocal = 11.73, theta = 0.7657, geometric phi =
1.6526. This warning will not be repeated though the condition may persist. (See GeomPhi output
channel.)
Time: 115 of 4000 seconds. Estimated final completion at 03:04:38.
CalcOutput:BEMT_CalcOutput(node 16, blade 3):**UA_CalcOutput:Mach number exceeds 1.0**. Equations
cannot be evaluated.
When AFAeroMod=2 and SkewMod=1
operating conditions: Vx = 12.782, Vy = -1.169, rlocal = 11.724, theta = 0.98488, geometric phi =
1.662. This warning will not be repeated though the condition may persist. (See GeomPhi output
channel.)
tates:UpdatePhi(node 18, blade 1):BEMT_UnCoupledSolve:There is no valid value of phi for these
operating conditions: Vx = 1.9063, Vy = -27.249, rlocal = 61.546, theta = 0.75118, geometric phi
= 3.0717. This warning will not be repeated though the condition may persist. (See GeomPhi output
channel.)
Time: 123 of 4000 seconds. Estimated final completion at 17:14:21.
T1:FARM_UpdateStates:FWrap_Increment:FAST_Solution:FAST_AdvanceStates:ED_ABM4:ED_CalcContStateDeri
v:SetCoordSy:Small angle assumption violated in SUBROUTINE SmllRotTrans() due to a large blade
deflection (ElastoDyn SetCoordSy). The solution may be inaccurate. Simulation continuing, but
future warnings from SmllRotTrans() will be suppressed.
Additional debugging message from SUBROUTINE SmllRotTrans(): 123.18 s
FWrap_Increment:FAST_Solution:CalcOutputs_And_SolveForInputs:SolveOption2:RotCalcOutput:BEMT_CalcO
utput(node 17, blade 1):UA_CalcOutput:**Mach number exceeds 1.0**. Equations cannot be evaluated.
When AFAeroMod=1 and SkewMod=1
tates:UpdatePhi(node 16, blade 2):BEMT_UnCoupledSolve:There is no valid value of phi for these
operating conditions: Vx = 7.4405, Vy = -83.447, rlocal = 56.134, theta = 0.5481, geometric phi =
3.0527. This warning will not be repeated though the condition may persist. (See GeomPhi output
channel.)
Time: 102 of 4000 seconds. Estimated final completion at 05:21:26.
v:SetCoordSy:Small angle assumption violated in **SUBROUTINE SmllRotTrans() due to a large blade**
**deflection** (ElastoDyn SetCoordSy). The solution may be inaccurate. Simulation continuing, but
Additional debugging message from SUBROUTINE SmllRotTrans(): 102.24 s
Time: 104 of 4000 seconds. Estimated final completion at 05:52:54.
T1:FARM_UpdateStates:FWrap_Increment:FAST_Solution:FAST_AdvanceStates:AD_UpdateStates:SetDisturbed
Inflow:TwrInfl:getLocalTowerProps:Tower strike.
The cases worked well under the reference wind tubine of 4m/s, but something wrong happened under the 12.0m, mainly for WT1.
Could you give more suggestions? Many thanks
