Thank you so much for your answers.
I did receive the “Unofficial FAST Theory Manual”. Thank you very much. Anyway, as a new beginner of OpenFAST, I want to follow your advice and review your last modeling workshop. Unfortunately, the link in your Sep 15, 2014 post in the forum topic is broken.
1.a. Could you please provide me with a new link?
1.b. Also, is there a website/repository where I could find the user’s guides and theory manuals? -
Ok, thanks. Now I am using both (as you will notice in the next point), but I will try to use Ubuntu in the future.
I am showing the OpenFAST output from an Ubuntu virtual machine, a guest in a Windows host (I am using Oracle VirtualBox). I created this Ubuntu virtual machine to try the installation process before making it in my “real” Ubuntu system. Since I was running into the error mentioned above, I also downloaded the precompiled binaries from the GitHub repo to Windows. So, I have the same setup, and I was finally running into the same error in both OS. I hope this makes sense.
Now, I followed your instructions, and I did add the DISCON.dll file you provided to the path indicated in the “NRELOffshrBsline5MW_Onshore_ServoDyn.dat” file. That solved the problem in Windows, but the problem persists in Ubuntu.
Which file should I add to my Ubuntu machine to fix the problem and make it work?
Many thanks,
Juan
