could you please send me the Unofficial Fast Theory Manual as well?
BS
BS
Sent.
Dear Dr. Jonkman,
Could you please send me the unofficial theory manual for FAST?
My e-mail: adrien.hirvoas@france-energies-marines.org
Thank you in advance,
Adrien Hirvoas
Sent.
Dear Dr. Jonkman,
Could you kindly send the manual to this email javier.contreras-lopez@strath.ac.uk?
Javier.
Sent.
Dear Dr. Jonkman,
Iâm a first year PhD. student studying OpenFast for my load control research.
Could you kindly send the unofficial manual to this email ee_ziyang@zju.edu.cn ?
Kind regards.
Sent.
Very Sorry for my mistake, sir. I find that I wrote an invalid e-mail address for receiving before. Could you please resent the unofficial manual to the correct address: ee_ziyang@zju.edu.cn?
Sorry again for troubling you!
Best regards.
Resent.
Hi Jason,
I am new to the forum and trying to get started. Could you please help me with the following when you have time?
Thanks in advance,
Sri
Dear Sri,
Iâve e-mailed you the âUnofficial FAST Theory Manualâ.
Are you intending to run OpenFAST on Windows?
Thanks for your eloborate email with the necessary documents
Yes, I intend to run OpenFAST on Windows. Can you please help with a baseline set-up along with necessary controller DLLs?
Thanks in Advance,
Sri
Dear Sri,
You can find precompiled binary Windows executables of various releases of OpenFAST here: github.com/OpenFAST/openfast/releases. Presumably youâd want to start with the newest version (v3.0.0).
You can find the corresponding OpenFAST sample models / input files in the release page of the OpenFAST r-test: github.com/OpenFAST/r-test/releases.
I just noticed that the precompiled controller DLLs used with the various models of the NREL 5-MW baseline wind turbine r-test cases are not in the archives of OpenFAST v3.0.0 and v2.6.0, but you can find these in the v2.5.0 archive (see: github.com/OpenFAST/openfast/re ⌠tag/v2.5.0), and should not change with v2.6.0 and v3.0.0. We should get this fixed soon.
Dear Sri,
The precompiled controller DLLs have now been posted together with the precompiled binary Windows executables for OpenFAST v3.0.0 and v2.6.0.
Iâm a doctoral student developing control schemes structural load mitigation and lifetime control of wind turbines.
I have been using FAST v7 and would like to switch to OpenFAST.
Could you please send me the Unofficial FAST Theory Manual to this email? ekiped@gmail.com
Edwin
Sent.
Iâm a Ph.D. student working on wind turbine control systems. I am also getting started with openfast (and with open-source projects and I have a few questions,
Could you please also share the Unofficial FAST Theory Manual (and mention the documentation that, in your opinion, I should get familiar with)? juan.lopezmuro@rutgers.edu
I have access to Windows and Linux/Ubuntu. In the near future, I aim to use the Simulink interface to use the ROSCO controller and to test different custom controller designs. Do you suggest using one operating system over the other (e.g. Linux over Windows)? Will I need to compile the source code in order to test custom controller designs?
I read the âreadthedocsâ documentation to get started and familiarized myself, but I am not sure of doing everything correctly.
I have installed OpenFAST (in Linux through the conda installation and in Windows downloading the precompiled binaries from the GitHub repo, as suggested in openfast.readthedocs.io/en/main ⌠g-openfast).
Then, I did download the r-test repository from github.com/openfast/r-test.
I tried running the 5MW_Land_DLL_WTurb by running:
openfast r-test-main/glue-codes/openfast/5MW_Land_DLL_WTurb/5MW_Land_DLL_WTurb.fst
but I did obtain the following fatal error:
I really appreciate any help you can provide.
Juan
Dear Juan,
I have sent you what is known as the âUnofficial FAST Theory Manualâ, but this is definitely not the first documentation I would read. As discussed in prior posts on this topic, this document is mostly useful if you want to understand the theory and structure of the ElastoDyn module. For new beginners of OpenFAST, unfortunately we donât have detailed step-by-step instructions for how to make use of OpenFAST. Regardless, a good way to learn OpenFAST is to review the presentations and sample models/simulations that were presented at our last modeling workshop. These are available for FAST v8.08 (not quite the newest version, but I donât have newer materials that are so comprehensive) in my in my Sep 15, 2014 post in the forum topic found here: Modeling Workshops. After that, I suggest that you study the various userâs guides and theory manuals.
I would use whichever operating system you are most comfortable with; OpenFAST should work on both Windows and Linux/Ubuntu. You shouldnât need to compile the source code unless you want to change the source code or implemented custom controls in source code. The Simulink interface and ROSCO controller provide convenient ways of implementing control systems without compiling.
It looks like you are running OpenFAST correctly. Are you showing the OpenFAST output from a virtual Windows machine? The model you are running requires the use of a controller (DISCON) precompiled as a dynamic library. On Windows, this library should have a .dll extension. It doesnât look like the path to these files is correct. You can find the files available for download here: github.com/OpenFAST/openfast/re ⌠N_DLLS.zip.
Dear Mr. Jonkman
I am writing my thesis on offshore wind turbine structural health monitoring and I am interested in understanding the theory behind the Elastodyn module. Would it be possible to send me the unofficial theory manual?
email: up1047349@upnet.gr
Nikolas Anastasiadis
