I am trying to run the Simulink examples in the FAST archive in Matlab/Simulink R2007b. I am using the FAST files from this topic: [FAST S-Func MEXing process)
After following the procedure is FAST.pdf, I am still unable to run the Simulink files. Below are the errors from Simulink and Console.txt. The files shown below in Console.txt do not exist in Wind/AWT27/ folder. Please let me know if I am missing anything simple.
Bhaskara
Error in ‘OpenLoop/FAST Nonlinear Wind Turbine/S-Function’ while executing FORTRAN MEX S-function ‘FAST_SFunc’, flag = 3 (output), at time 0. MATLAB error message:.
FAST certification Test #01: AWT-27CR2 with many DOFs with fixed yaw error
and steady wind.
Heading of the aerodyn.ipt file :
AWT-27CR aerodynamic parameters for FAST certification test #1.
Could not find hub-height wind file:
“Wind/AWT27/Shr12_30.wnd”
Could not find full-field wind file:
“Wind/AWT27/Shr12_30.wnd.wnd”"
Could not find coherent turbulence wind parameter file:
“Wind/AWT27/Shr12_30.wnd.ctp”"
Could not find 4D-wind parameter file:
“Wind/AWT27/Shr12_30.wnd.fdp”"
Check your AeroDyn input for proper wind file name.
FATAL ERROR in Subroutine CheckWindType.
Error reading wind file name. Could not find HH, FF, 4D, or CT file.
0 warnings recorded in error.log file for this simulation.
1 errors recorded in error.log file for this simulation.
Errors logged by AeroDyn(12.58, 28-Jun-2005) in FAST (v6.02c-jmj, 02-Feb-2007)
on 02-Mar-2009 at 14:47:51.
Simulation Error # 1
Simulation Time = 0 seconds.
Error detected in Subroutine CheckWindType.
FATAL ERROR. SIMULATION ABORTED.
