Eigenvalue in BModes
After reading your reply, I get something new. Could you please help me to correct my understanding?
  1. In Elastodyn, we defined a critical damping ratio for blade and tower. But when implementing this critical damping ratio in code, it is transformed to a stiffness-proportional constant.
  2. After doing linearization and running runCampbell.m Matlab code, we also get a damping ratio:
    In above figure, Damping ratio is a stiffness-proportional constant for entire system’s stiffness matrix.
  3. Here damping ratio (stiffness-proportional constant) = 0.003683, natural frequency = 0.313523, so the critical damping ratio:
critical damping ratio = stiffness-proportional constant * pi * natural frequency
                       =  0.003683 * 3.14159 * 0.313523
                       = 0.00362
                       = 0.36 %
I am not sure whether this derived critical damping ratio is reasonable. This is an onshore wind turbine, without wind and wave. I assigned 1% critical damping ratio for both blade and tower in Elastodyn. No intial rotor speed was assigned. I would assume that hub mass and nacelle mass increase the mass matrix for entire system, and then decrease the critical damping ratio to 0.36% for entire system.
Ran
