Thank you for your answer and the URL.
I found the report “Floquet Modal Analysis of a Teetered-Rotor Wind Turbine” and I’m trying to understand the method. I linearized the turbine model with FAST and used the state matrices A from the .lin-output to recreate the Floquet approach with Matlab, i.e. computing the transition matrix Φ after one period. But unfortunately the results weren’t correct yet, so now I’m trying to understand the linearization process of FAST first, to get the correct A matrices.
I linearized a 3-blade rotor without control and wind disturbance inputs, so the state space model should be: x’ =A(t) * x, where x= [Δq, Δq’] and x’ = [Δq’, Δq’’].
The model has 9 DOFs, which are the 1st & 2nd flapwise and 1st edgewise bending modes of each of the 3 blades.
The states are:
Row/column 1 = 1st flapwise bending-mode DOF of blade 1 (internal DOF index = DOF_BF(1,1))
Row/column 2 = 1st flapwise bending-mode DOF of blade 2 (internal DOF index = DOF_BF(2,1))
Row/column 3 = 1st flapwise bending-mode DOF of blade 3 (internal DOF index = DOF_BF(3,1))
Row/column 4 = 1st edgewise bending-mode DOF of blade 1 (internal DOF index = DOF_BE(1,1))
Row/column 5 = 1st edgewise bending-mode DOF of blade 2 (internal DOF index = DOF_BE(2,1))
Row/column 6 = 1st edgewise bending-mode DOF of blade 3 (internal DOF index = DOF_BE(3,1))
Row/column 7 = 2nd flapwise bending-mode DOF of blade 1 (internal DOF index = DOF_BF(1,2))
Row/column 8 = 2nd flapwise bending-mode DOF of blade 2 (internal DOF index = DOF_BF(2,2))
Row/column 9 = 2nd flapwise bending-mode DOF of blade 3 (internal DOF index = DOF_BF(3,2))
Row/column 10 to 18 = First derivatives of row/column 1 to 9.
From the.lin-file at Azimuth = 0.00°:
x’ and x have the following values:
[code]op State | op
Derivativs | States
2.547E-01 | -4.121E-04
-1.286E-01 | 1.693E-01
-1.258E-01 | -1.689E-01
-5.541E-01 | 8.301E-04
2.745E-01 | -3.749E-01
2.795E-01 | 3.741E-01
-6.048E-02 | 5.423E-05
3.007E-02 | -4.097E-02
3.041E-02 | 4.091E-02
-1.928E-03 | 2.547E-01
-2.253E-01 | -1.286E-01
2.272E-01 | -1.258E-01
-3.705E-03 | -5.541E-01
5.848E-01 | 2.745E-01
-5.811E-01 | 2.795E-01
-2.667E-04 | -6.048E-02
6.377E-02 | 3.007E-02
-6.350E-02 | 3.041E-02
[/code]
But now my question is: If I am multiplying the state matrix A with the current state vector x (‘op States’) manually, I am getting different second derivatives as opposed to the ones in the x’-vector from the .lin-output (‘op State Derivatives’ from line 10/after the blank line). It seems that I misinterpreted something here. Are there perhaps conversions involved, which I missed?
I posted the A-matrix and attached the .lin, .fst and linear.dat files at the end of this post. I hope someone can explain this discrepancy, thank you in advance!
x’ = A(t) * x → manually multiplied
[code] 0.2547
-0.1286
-0.1258
-0.5541
0.2745
0.2795
-0.0604
0.0300
0.0304
-0.0019
-4.2694
4.2714
-0.0036
18.2634
-18.2609
-0.0002
2.9202
-2.9185
[/code]
Linearization.zip (465 KB)
The A-Matrix has the following form:
Removed (see .lin file)
