The torsion stiffness of the dirvetrain mainly included the low speed shaft ,gearbox, flexible support and so on,I think the stiffness of the gearbox is the most importrant part, but i don’t know how we set the damping, we set the damping of tower and blades by the damping ratio, Do drivetrain have the same case? Usually I think the drivetrain also have the little damping ,so we can control the torque to increase the damping.
My question is how much drivetrain’s damping ratio usually is ,generally I set the damping ratio to 0.5%,then calculated the damping out .What do you think about my way to calculate the damping,and what’s your method to calculate the damping?
Like for steel towers, I would typically assume a damping ratio of 0.5-1.5% for drivetrains in the absence of more information. But the drivetrain damping is specified in the ElastoDyn module of FAST as a torsional damping constant (DTTorDmp) rather than a damping ratio. The drivetrain torsional stiffness and damping constants (DTTorSpr and DTTorDmp) have been discussed a few times on this forum e.g. see: http://forums.nrel.gov/t/drivetrain-2-2hz-frequency-and-natural-frequency-0-625hz-def/987/1.
When I read the paper “Dynamic modeling and loads analysis of an offshore floating wind turbine”,I found you set the damping ratio to 5% critical,
As you said the steel structure’s damping ratio is 0.5%-1.5%, Why did you set the vaule to 5%
As I know If we increase the value to 5%,maybe the LSSMx will be fine.If we set to 0.5%,I think the Mx have large oscillation,we have to improve the drivet%.rain damping additionally.
Could you explain that ?
Good question. If I recall correctly, the NREL 5-MW baseline turbine used a simplified control system that does not attempt to damp structural vibrations in the drivetrain. Instead, the structural damping of the drivetrain was artificially increased.
