This may be a silly question but I’m an electrical engineer, so you’ll have to forgive my ignorance of most things mechanical. Would it be valid to model drive train torsion in a direct-drive wind turbine? In the FAST users manual the equation given (Tres = DTTorSpr•( RotorPos – GboxPos ) + DTTorDmp•( RotorSpeed – GboxSpeed )) is in terms of two gearbox quantities. In a direct-drive turbine would RotorPos=GboxPos and RotorSpeed=GboxSpeed or is that only valid if the shaft is stiff? The reason I ask is that I’m seeing some fairly high-frequency (>1kHz), low magnitude shaft torque oscillations in my FAST simulations for the SWRT, which doesn’t have data for drivetrain damping or spring constant. I’m trying to decide whether those are realistic or if they would normally just be damped away by the shaft (or something else). Thanks very much.
David Ochs
