Hi everyone,
FAST uses two text files in order to acquire blade and tower properties. Both of them use fractional length as HtFract and BlFract which must be varied from 0 to 1.
My question is regarding how to specify these sections. Here, it is an example of how specifying a tower segments in two way which could result in a single input file.
Tower height - representative height
(0-4) - 0
(4-8) - 6
(8-12) - 10
(12-16) - 16
(0-3) - 0
(3-9) - 6
(9-11) - 10
(11-16) - 16
I set the lower height in first section (0 in 0-4) as representative height and upper in last section (16 in 12-16). The other internal sections used an average value as representative height. But, you cannot recalculate the first column by just having the representative height column only. Then, how FAST deals with this representative height column?
Should it be any other relation between tower sections? Such as below
Tower height - representative height - section height
(0-2) - 0 - 2
(2-6) - 4 - 4
(6-10) - 8 - 4
(10-14) - 12 - 4
(14-16) - 16 - 2
Which means equal section height in internal sections and half of it in the first and last section.
Thanks in advance
