Dear community,
I am puzzled by the result of FAST.Farm, when it simulates a step change in the wind speed as the change apparently arrives at wind turbine 2 (downstream) as the same time as at turbine 1.
Simulation setup
- As a starting point I used glue-codes/fast-farm/TSinflow/FAST.Farm.fstf from [1], where two wind turbines are located downwind (more or less).
- Of course, “…/5MW_Baseline/ServoData” contains the compiled DISCON.dll, DISCON_WT1.dll and DISCON_WT2.dll.
- Set in IW.dat and IW_WT.dat the parameter “WindType” to 2 and “Filename_Uni” to “UniformWind.dat” including (similar to [2] to simulate the step change):
# UAE Phase VI (Ames) wind for for a simple power curve.
# Time Wind Wind Vert. Horiz. Vert. LinV Gust
# Speed Dir Speed Shear Shear Shear Speed
00.0 8.0 0.0 0.0 0.0 0.0 0.0 0.0
70.0 8.0 0.0 0.0 0.0 0.0 0.0 0.0
70.1 9.0 0.0 0.0 0.0 0.0 0.0 0.0
999.9 9.0 0.0 0.0 0.0 0.0 0.0 0.0
- Remark: WindType etc. in IW_WT.dat should be ignored as described in Sections 3.4 and 3.5 in FAST.Farm User’s Guide, see [3].
Observation
The output file (.out) contains:
Time RtVAmbT1 RtVAmbT2 RtVRelT2 ...
69.0000 7.967E+00 7.969E+00 5.031E+00 ...
72.0000 8.963E+00 8.965E+00 5.877E+00 ...
I would not have expected that the effect of the step change arrives at the second turbine at the same time as at the first turbine (see RtVRelT2). There should be a time delay as the step change has to propagate. Am I misinterpreting something?
Since I have not been working with FAST.Farm for long, I would like to ask if a more experienced user can reproduce a similar behavior. I really wonder if I have missed something.
Florian
References:
[1] GitHub - OpenFAST/r-test
[2] Confusion about TurbSim
[3] Jason Jonkman and Kelsey Shaler: FAST.Farm User’s Guide and Theory Manual, Technical Report, National Renewable Energy Laboratory, 2021.
